Question about Powermate 10 in. 43 cc Gas 2-Cycle Cultivator PCV43
Not getting gas in to carb on powermate 43cc cultivator. I sprayed in starter fluid and it started right up but would not keep running.
  • 2,113 Answers
You may have to rebuild the carburetor to find what is sticking inside.
Posted on Oct 23, 2013
How can you free fuel flow?
Hi Joe Rutkowski, Fuel lines with a pin hole can cause a problem with the fuel feed. The carb can have a closed choke or only halfway open. The return fuel line has junk in it, like dirt over a period of time. There is a screen inside the bottom part of the carb, it is called a manifold. When taken apart, you can see the screen or any other obstruction between the manifold. Be very careful not to tear the gasket, they are not easy to find sometimes. Be careful also and do this inspection on a clean surface where all the parts are visible. Good Luck!
Jun 06, 2014 | Powermate 10 in. 43 cc Gas 2-Cycle...
How do you clean carburetor powermate 43 cc
I'm sorry to say that I had a similar problem, and after two trips to the repair shop, I gave up and bought a new carburetor at eReplamentParts for about $40. The new carburetor is working quite nicely.
Jun 03, 2014 | Powermate 10 in. 43 cc Gas 2-Cycle...
My powermate 43cc cultivator not getting gas through carb
Replace the fuel filter. Check float bowl valve in carburettor
Oct 22, 2013 | Powermate 10 in. 43 cc Gas 2-Cycle...
What is the pston ring size
MIne too! I'm ordering some 43cc rings that seem to match the size of the one good one I had left. They are sold by many different eBay sellers and apparently are most all the same for a 43cc displacement piston....
43cc, OD=42mm, ID=38 mm, Thickness=1.5 mm
May 10, 2013 | Powermate 10 in. 43 cc Gas 2-Cycle...
Earthquake tiller viper 43cc engine will not start
I have the same issue, I thought it was the carburetor so I cleaned it and put it back together, same issue, I put a new carburetor on it same issue, has great spark, if I spray carb cleaner into it, it will start and run for a few seconds even throttle up, but then it dies, and will not start again without carb cleaner spray, and fuel is fresh and properly mixed, very confusing indeed.
Apr 17, 2012 | Ardisam Earthquake Mini Cultivator 43cc...
I cant get my coleman powermate 5000 MAXA ER to start. i have changed the oil, refilled the gas, changed the spark plug, and tried using starter fluid. what else can i try?
It's almost certainly gummed up gas in the carburetor. Get some carb cleaner, and some spray instant start. Drain the gas from the tank and put a small amount of 50/50 carb cleaner and gas in the tank. Remove the air cleaner, open the choke, spray a little instant start into the carb and start it. It may fire just a couple of time. Keep the choke on to try to pull a bit of gas through the carb. You may have to do this a few times. Once you can tell some gas is flowing, open the choke slowly to keep it running until you use up the 50/50 mix. Then try a small amount of straight gas in the tank to be sure it works right, before you refill the tank. Make sure you use a stabilizing additive in any gas that you store for more than a month. good luck, Al K
Feb 02, 2011 | Coleman Powermate Premium Plus 6250W...
Coleman Powermate 5000 with 10 HP Tecumseh engine. It had a float problem and leaked gas out the air filter. I replaced the float and stopped the leak, but now it won't start. It will start if engine...
I have a Coleman Powermate 5000 with 10 HP Tecumseh engine. It is very hard to get started. once started runs great . But when you shut it off and try to restart it it will not start.
I have plenty of fire. I also replace the carb.
I still have problems getting it started. I tried to start it with out the filter also. What can i try next?
Thanks for any help
Jun 18, 2010 | Coleman Powermate Powermate 5000W...
Have a 5hp honda motor ,good spark, good gas, but every third pull it just pops and blows a little smoke out the carb
Get a can of starter fluid and a helper. Spray some fluid into the air intake and then start it up. keep it running on starter fluid for a couple of minutes and this will clean out your carburator, the cause of your problem. Joe
Apr 24, 2010 | Garden
Coleman Powermate 5000 starts with starter fluid, but leaks gas into the air filter. Checked the float, it has no holes, and is not jammed. Fuel will go into the carburetor, but no fuel will reach the...
Sounds like you need to clean the carb ports, lines, jets, etc... purchase a carb spray cleaner with a tube to place on the spray head (Berryman's Chemtool B-12 is awesome). Take the carb loose from the generator, and remove the bowl, needle valve and spray carb cleaner thru all the holes, lines in the carb. Reinstall complete with air cleaner and retry... also if the gas is old, drain and replace with new...
May 25, 2009 | Coleman Powermate Powermate 5000W...
Powermate 10 in. 43 cc Gas 2-Cycle Cultivator PCV43 Logo
623 people viewed this question
Top Powermate Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Powermate Garden Expert? Answer questions, earn points and help others
