Question about Refrigerators
Fridge is cold but runs continually - Refrigerators
  • 45 Answers
It is likely the condenser fan is not functioning, or the condenser itself is dirty or plugged with hair/ fur/ lint or anything really. This would look like a small radiator or an long tube bent into an "s" shape. It would also be rather warm when you hear the fridge running. If this checks out, it is possibly, but unlikely your unit has lost some of its refrigerant. Try cleaning the warm parts.
Posted on Oct 23, 2013
Magic Chef Fridge & freezer not cold-both fans running-Compressor hot- cleaned drain tube-outside of fridg cold
Is compressor running continuously or is it clicking on and off every couple minutes? Is there any frost buildup on inside back wall of freezer?
Sep 26, 2017 | Magic Chef Refrigerators
My fridge is not cold
This normally indicates that the gas is low. If compressor runs continuously, but fridge does not cool, then you must have a regas done. Dont let it run like this cos it can damage compressor by overheating.
Aug 26, 2014 | Kenmore Refrigerators
My fridge runs continuously and the top of the rear inside panel seems to frost up. The fridge is about three years old.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 27, 2010 | Refrigerators
My freezer gets cold but fridge stays warm i have defrosted and the problem continues kenmore model# 9704284 any suggestions
heatman101
Oct 24, 2010 | Kenmore Refrigerators
Both fridge and freezer aren't getting cold enough in my Maytag Fridge
if they are both cold, but not cold enough, one of two likely scenarios, one minor, one major. the major one, you haev a sealed system leak of refrigerant, several hundred dollars to repair.
the minor, your condenser fan motor is not running, its job is to cool the compressor, if its not cooling the compressor, when the compressor gets too hot, it will shut itself down, while the fridge continues to run. when this happens, the unit seems fine first thing in the morning, but by evening it seems less fine...while everyone sleeping, doors have been closed, allowing unit to "catch up". replace fan motor.
Feb 27, 2010 | Refrigerators
Comperssor kicks on but quickly cuts off intermittently every 5 minutes on my frigidaire fridge side by side
Freezer defrosted everything fan continues to run but will not freeze. Compressor is cycling enough to keep refigerator section cold. 106 Series Kenmore. Turned up thermostat to keep fridge cold and a shorter intermittent compressor cycle run
Jun 06, 2009 | Frigidaire FRS26H5AS Side by Side...
GE fridge runs continuousely
Simple! The replacement fan ran the wrong way forcing air circulation the wrong way. Fortunately it was possible to reverse the moter shaft.
Dec 11, 2008 | GE GBS22HCR Bottom Freezer Refrigerator
Fridge does not stay cold
If the compressor is running continually, could be short of gas , or a compressor problem, ie not pumping properly,make sure it has plenty of ventilation
Dec 06, 2008 | Kenmore 53642 / 53644 Side by Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
