Panasonic pt 52lcx35
Color blotches all over screen
    Problem Solver:
  • 5 Answers
We recommend that you test other inputs and devices on the TV to see if the lines appear only on 1 device or type of cable connection.
Keywords: thin, red, pink, line, lines, bars, bar, vertical, up, down
Posted on Oct 22, 2013
SOURCE: my pt-52lcx35 has a red
The spots will continue to multiply. I had to go through several people at the panasonic customer service center, but they finally admitted that it was an issue that they were aware of and were covering - they sent a technician out who hooked up a device to the back of the tv and the spots went away after about 10 minutes. No charge, and tv works good as new.
Posted on Feb 18, 2009
SOURCE: cant find the air filter
Our TV did the same thing. After calling numerous repair shops, and hearing there was no such thing as an air filter, or they had never heard of one, I decided to try to fix it using a suggestion I read on-line.After disconnecting from all power, take off the back panel, and using some compressed air, blow out all of the dust that has accumulated. I had to use a box fan just to blow the dust out of the house! Afterwards replace the back cover and it should be good again. Hope this helps!
Posted on Jul 11, 2009
johnnydiode
  • 647 Answers
SOURCE: colored spots on PT-52LCX35 TV.The solution seems
Service Tech is required since they have the EEPROM tool and it's not available to the general public.
Posted on Nov 24, 2009
Testimonial: "service tech arrived ,done in less than a half hour."
  • 927 Answers
SOURCE: color spots on screen panasonic pt-61cx65
Howdy,
The problem is with the EEPROM in the TV that needs to be reprogrammed. But you need to have the proper Correction Tool (LSUQ0100).
I don't think it's available to the public. Call a Service Company, but make sure they have the “Correction Tool”.
Thanks for using FIXYA, big IRISH.
Posted on Jan 02, 2010
SOURCE: Panasonic pt-52lcx65-k color problem
I have the same problem. i called panasonic they said it was a on
going problem and they would send out a repair tech no charge to
fix problem.give them a call 1-888-843-9788
Posted on Mar 11, 2010
Where is the air filter located on panasonic tv PT-52LCX35
Download the manual. It should tell you there. You may need to locate the Repair and maintenance manual, not the user manual (and surely not the quick guide)
Oct 24, 2015 | Panasonic PT-52LCX35
Tip
PANASONIC WITH FUZZY SPOTS
FIXYA TIP PANASONIC
I hope this not AN old TIP, but I still see it asked and not answered properly by some.
TIP:
PANASONIC:
MODELS: PT-44LCX65, PT-52LCX15, PT-52LCX65, PT-52LCX35,
PT-61LCX65, PT-61LCX35.
SYMPTOMS:
1. FUZZY SPOTS
2. FUZZY SPOTS WITH STAINS
3. FUZZY SPOTS & UPSIDE DOWN
4.. FUZZY SPOTS WITH LINES
5. LOOK LIKE BAD LIGHT ENGINE.
CORRECTION: SYMPTOMS CAN BE CORRECTED BY EEPROM CORRECTION TOOL; (LSUQ0100).
It is an easy repair (about 7 minutes), it takes longer to take the back off to perform this procedure.
Can't be purchased unless you have an account, customers can not purchase.
Thanks, Big IRISH.
on Dec 15, 2009 | Dishwashers
I have a pt-52lcx35 and there are lines of either green or orange that appear and move about in various locations on my screen
YOUR TV HAS A CORRUPTER MICRO CONTROLER
YOU MUST GO TO A SERVICE CENTER THE SERVICE CENTER WITH A SPECIAL TOOL THATS AVAILABLE BY PANASONIC WILL REPROGRAMME YOUR EEPROM THIS SHOULD NOT COST MORE THAN 100 DOLLARS IT IS NOT NECESSARY TO OPEN TV
Jan 22, 2010 | Panasonic PT-52LCX65 44" HDTV
There are color spots all over screen-pt-61lcx35
This, sadly is getting to be a very common problem with all Projection LCD TV's
Colored Blotches on an LCD Projection TV are usually caused by defects or marks on filters or lenses or one of the LCD panels themselves which are all located in the light engine (or optical block) First confirm that the lamp or main lens is not discolored by removing the lamp (unplug set and let cool before removing!) and inspecting the lamp itself and the lens that it shine onto. The light engine is an expensive part ($600-$1200) to replace and requires major disassembly. Get an estimate -Be sure to vote/rate me if this helped Thanks!
Nov 06, 2009 | Panasonic PT-52LCX65 44" HDTV
I have a Panasonic lcd PT-52LCX35 that has spots all over the screen
Call The 1-800# in your manual. They'll fix it even if it's out of warranty. They did mine. It's a design flaw with something called an "Eprom".
Dec 07, 2008 | Panasonic PT-52LCX65 44" HDTV
Colored spots on dlp tv screen
coloue spots on screen. how do you fix with screwdriver?
Jul 22, 2008 | Panasonic PT-52LCX65 44" HDTV
Repair on problem blue dot
Good Day, flavrlen;
This is your fix it is not costly and if you handle a screwdriver you can do this in 30 minutes:
PANASONIC:
MODELS: PT-44LCX65, PT52LCX15, PT-52LCX65, PT-52LCX35, PT-61LCX65,
PT-61LCX35.
SYMPTOMS: 1. FUZZY SPOTS
2. FUZZY SPOTS
3. FUZZY SPOTS WITH STAINS
4. FUZZY SPOTS & UPSIDE DOWN
5. FUZZY SPOTS WITH LINES
Good Luck, big IRISH.
Jul 09, 2008 | Panasonic PT-52LCX65 44" HDTV
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
Electro Med Services...
