Question about Hitachi Televison & Video
I just bought a Hitachi rear projection tv off craigslist. Tv worked fine, I gently transported to get it home, plugged it in and for nothing. The red light comes on and it sounds like its trying to come on, but I have no picture and no sound, not even that snow screan you usually see when you do not hook cable up to your tv. What could it be?
  • Hitachi Master
  • 3,187 Answers
No matter how careful you going to be moving it something is going to come lose. may even be a bad soldering joint and it come away completely. you will need to check the power board very carefully looking for somthing that dont look right. also this can happen in transit the outer case for the bulb housing may have moved away from the switch that would make the tv not turn on at all as it needs to be pushed in. take the cover of it and then put back on locating the switch you will see the switch when the cover for the buld is removed..
Posted on Oct 23, 2013
4 Suggested Answers
  • 42 Answers
SOURCE: LG rear projection tv. sound but no picture.
Go to a repair centre, some parts must be fixed/replaced.
Posted on Jul 22, 2009
SOURCE: Have a Hitachi 53sdx89BA Rear Projection TV. Turn
Discharged Flyback Transformer. Removed main pc board from bottom of TV and flipped over, no apparent damaged components or blown board traces were found. Noticed a lot of flux in various areas on the board that seemed unusual (maybe TV was worked on before as I bought a showroom demo at Circuit City). Used a plastic screwdriver to remove all flux between connections on ICs, Transformers, Flyback Transformer, and various other components. Cleaned all debris, dust and crud accumulation (TV is over 10 years old and there was alot around the Flyback Transformer) from both sides of board using a lightweight paint brush.
Used a magnifying glass to check all solder joints for possible cold solders and found none. Did the same for Power Supply Board. Checked various ICs and Power Transistors for opens or shorts (in machine) and they seemed fine. Reinstalled boards, said a few Hail Mary's and fired it up.
The protector Led no longer flashed under power and lo and behold I got picture and sound!
I cleaned the lens on the projectors (again 10 years of dust accumulation) did a magic focus adjustment and it works fine!
After reading other fixes, I fully expected it to die after 10 minutes so I left it on all day and against all odds it still works.
What was the fix......Dirt buildup on and around Flyback and other components,,,,,,Flux conducting electricity between contacts on Flyback and other components.....or oxidation on connectors between Power Supply and Main Board.....I don't know.... all I know is that for the moment I saved around $ 300 - 400 in repair bills by doing it myself.
Posted on Feb 02, 2010
atelier mj
  • 70 Answers
SOURCE: 52 Hitachi rear projection T.V. (model #, 53FDX01B)
look for EP98, Q655 and D756.
Posted on Apr 22, 2010
I have a 1994 50ex8k hitachi rear projection tv that wont turn on
it has a built in safety. there's a problem with tv board
May 31, 2010 | Hitachi Televison & Video
Hitachi Rear Projection TV - C4678FS - No Sound
i am having the same problem with my hitachi.. if you find anything out plz let me kno
May 09, 2010 | Hitachi Televison & Video
Hitachi projection tv was turned on and off repeatedly by child
sounds like you have lost the power supply , probably high voltage. That is what drives the tubes. Your low voltage is working because you have audio.. Proably not an in home repair. Good luck
Jul 09, 2009 | Hitachi 61SWX10B 61" Rear Projection...
ROLLING PICTURE HATACHI
Replace Verical IC and componets in same circuit maybe 2or3 bad capacitors. 100uf 35v ,1uf or 2.2uf 50volt. you need to order vertical Kit.
Jan 08, 2009 | Hitachi 53UDX10B 53" Rear Projection...
TV wont stay on
Sounds like a short somewhere in there. I see old pre-HD big screen sets going for well under $200 on my local craigslist, so look there for a good replacement, because the repair will cost more.
Or fork over about $500 for a good used HD projection set.
Apr 06, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 50ux57B
First thing i would do is unplug it for a couple of hours then plug it back in.
Dec 08, 2007 | Hitachi 50UX57B 50" Rear Projection...
Hitachi 53SBX59b Rear projection TV out of convergence
from you bought the tv and notice that it has that stain on the edge you should have taken it back as it was covered under warranty.now it is getting worse it will cost you to get it fix your tv has a factory defect.you will have to call the repair man to fix your tv.good luck.
Apr 26, 2007 | Hitachi 53SBX59B 53" Rear Projection...
Televison & Video Logo
26 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
