Question about Powermate Garden
My powermate 43 cc cultivator will not start. tried starter fluid and it starts but won't keep running. it's like it is not getting gass in to carb any suggestions
Tiller idles but drowns out when i try to till
Adjust carb. Turn speed/air mix needle counterclockwise 1\4 turn.
Oct 18, 2014 | Powermate 10 in. 43 cc Gas 2-Cycle...
What is a sparkplug gap for a powermate 43cc engine
Set spark plug gap to 0.024 - 0.028 in. (0.6 - 0.7mm).
Oct 11, 2014 | Powermate 10 in. 43 cc Gas 2-Cycle...
My powermate rear tine tiller is getting gas into the oil it will start and run as long as im am putting fuel into the carberator once i stop putting fuel the engine stops what is the problem. the til
This sounds like the float is sticking in the carb causing it to flood . You need to take the carb off and clean it and put a kit in adjusting the float per the instructions
Jun 27, 2014 | Powermate 18 in. 196 cc 4-Cycle Rear-Tine...
How do you clean carburetor powermate 43 cc
I'm sorry to say that I had a similar problem, and after two trips to the repair shop, I gave up and bought a new carburetor at eReplamentParts for about $40. The new carburetor is working quite nicely.
Jun 03, 2014 | Powermate 10 in. 43 cc Gas 2-Cycle...
My powermate 43cc cultivator not getting gas through carb
Replace the fuel filter. Check float bowl valve in carburettor
Oct 22, 2013 | Powermate 10 in. 43 cc Gas 2-Cycle...
Coleman Powermate 5000 with 10 HP Tecumseh engine. It had a float problem and leaked gas out the air filter. I replaced the float and stopped the leak, but now it won't start. It will start if engine...
I have a Coleman Powermate 5000 with 10 HP Tecumseh engine. It is very hard to get started. once started runs great . But when you shut it off and try to restart it it will not start.
I have plenty of fire. I also replace the carb.
I still have problems getting it started. I tried to start it with out the filter also. What can i try next?
Thanks for any help
Jun 18, 2010 | Coleman Powermate Powermate 5000W...
My Coleman OHV 3000 will not start
dont use starter fluid ,will ruin engine.Sounds like the float in the carb is stuck.and keep lookin for a filter.
Dec 21, 2008 | Coleman Powermate Premium Plus 6250W...
Garden Logo
591 people viewed this question
Top Powermate Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Powermate Garden Expert? Answer questions, earn points and help others
