Question about Jerdon Deluxe Lighted Makeup Mirror JGL9W
Bulbs wont light up all the way how do i replace them
1986 gmc c2500 tail light wont work replaced fuse and light bulbs still dont work ? I do have break light but when I turn on light the break lights wont work
you have either the wrong bulb or the bulb installed backwards.
the reason the bulb is not working right, is because the driving light is lighting brighter than the brake that's why it looks like is not working.
Dec 28, 2014 | AM Auto Parts 1986 GMC C2500 Truck Heater...
Mitsubishi space star parking light wont come on
Bad bulb, bad connection from bulb to socket, excessive use of contact grease. try a to clean out the socket or find a way to make the contact better between bulb and socket. May have to replace the socket.
Dec 13, 2013 | 1997 Chevrolet Malibu
Light inside fridge
unplug from power unscrew the bulb pull the bottom bulb contact out slightly replace the bulb plug in and, test
otherwise replace the bulb
Nov 18, 2013 | Furniture
Driver side break light will not work after replaceing the bulb a few times, tail light has no issue or the reverse light an blinker... any suggestions after replacing the bulb??
turn on 4 way flashes if that light is the same one,, start checking the ground wires and the way the bulbs fit in the sockets if the sockets are worn they wont hold the bulb right..if the ground is faulty the bulb will flash funny..good luck repost findings
Jan 19, 2013 | 2001 Cadillac Catera
My head light on my 1998 Chevy malibu went out but when I replace the bulb it still wont work
When you replaced bulb,all wiring and bulb connector looked good,no corrusion,wires not burned or strayed.With dim lights,means just a little power going to light bulb.Did you check the fuse in fuse box,could be a loose connectoion,check both fuses,left and right headlight.swap them out and see,if fuses are good then,it may be the headlight switch,which cost the most.Here's a link on how to replace.Here's the part.
Dec 07, 2012 | 1998 Chevrolet Malibu
I changed my low beam lights and now they wont come on.
Make sure u have connected the connectors back properly.
Jul 30, 2010 | Chevrolet Impala Cars & Trucks
Tail lights wont work on my 1996 explorer
pull the bulb and check for power to the bulb socket if there is power replace the bulb because what happens is the bulbs get so hot they melt the sawder contacts at the bottom and that causes them not to work
Aug 19, 2009 | 1996 Ford Explorer
Put new bulbs in fog lights, now fog lights wont come on. 98 cadi catera. replaced old bulbs with new halogen bulbs now neither fog light will come on
Halogen bulbs are brighter and generally draw more current than standard filament ones.
Have you check that the supply fuse has not popped ?
Jun 21, 2009 | 1998 Cadillac Catera
Right brake light out; tail light works fine
most rear tail lights and turn/stop lights are the same dual filiment bulb. it is possible for your tail light to work and your brake light not to and still have a bad bulb. I would check the bulb first, your brake light works on the left yes? this would mean that the fuse is fine
Mar 31, 2009 | 2006 Dodge Stratus
Jerdon Deluxe Lighted Makeup Mirror JGL9W Logo
44 people viewed this question
Top Jerdon Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Jerdon Health and Beauty Expert? Answer questions, earn points and help others
