Question about Motorola Audio Players & Recorders
I have Motorola Talkabout Radio HH230TPR and purchased the Motorola 56320 Headset.If I have the radio off when I plug my headset in and then turn it on it is on the VOX mode but my mic voice activates. If I plug my headset in after the radio is on it doesn't go to the VOX setting but it will start to squeal about 30 seconds late. I want to be able to use my headset but not have it voice activated. There is no mic button to push on the headset but it doesn't bother me to push the pitt button on the radio which is clipped on my belt when I talk
SOURCE: Cant recieve or make calls from my headset.
what headset are u using? i presume its the 's9', most connection problems are solved by disconnecting the headphone and then reconnect it.
or go to ur bluetooth devices on ur computer, and click on the device then properties, then services then, select all boxes. remember to apply the changes.
good luck
Posted on Jan 22, 2009
  • 3 Answers
SOURCE: Motorola S9 headset plays music in one ear
I had the same problem with a Samsung phone. There are two ways of fixing this; First, you can remove the S9 profile from your phone's bluetooth list, and then add it again, going through pairing and entering 0000 on your phone when asked for the code.
Alternatively, you might try pressing the "play" button on the right earpiece on the Motorola S9. This is supposed to kick it into the A2DP stereo mode for music listening.
Good luck.
And get a copy of the manual from the Motorola web site at http://direct.motorola.com/ens/s9/Headset_Home.asp I found this very handy for checking what the little flashing lights mean. When you get stereo reception, the little LED in the middle of the headset flashes green, not the usual blue and red and purple for voice calls.
In case you didn't know, as a phone headset, with the microphone activated, you only get sound in your left ear, and the light flashes blue. For music, you get both ears, and it flashes green. So if it ain't green, you are in mono mode.
Posted on Mar 28, 2009
SOURCE: Motorola S9 headset won't charge batteries
This might work if you aren't using the ORIGINAL charger. I had this problem when my cat chewed through the original Motorola charger. I figured my Blackberry charger would work fine, but it didn't. I then discovered that my Blackberry charger was 700mAH and the broken charger was only 550mAH. When I found another charger with the proper power it charged. I also found that it worked when plugging it into my computer with a standard mini USB. I hope this helps.
Posted on Jun 06, 2009
SOURCE: motorola s9 headset not charging
I had the same problem but instead of a red light it would flash green twice and stay off. I could not find the original charger and another plug in charger would not work. I plugged it into my computer with a usb cable and after several seconds it started charging.
Posted on Nov 20, 2009
solidstatedr
  • 33 Answers
SOURCE: Can get headset to work right
check your radios settings, this should be available in a menu on the radio... the user manual does not show a setting for non vox operation of the head set, (as this maybe a version difference it may be available in the menu) so if it is not available in the menu with the rest of the settings it is not an option.
Posted on Oct 23, 2013
Oct 22, 2013 | Motorola Walkie Talkie 2-Way Radio
Issue using headset with motorola talkabout md200
You may have one of the following issues:
1) Defective headset or non-compatible headset. Try the headset on the other radio to see if you experience the same problem.
2) Headset is not plugged in all the way, until you feel a click.
3) Your radio's jack is wobbled out, or defective. Try moving the plug in or out slightly in the jack to see if you can find a sweet spot. Jacks can be worn due to plugging and unplugging chargers or audio devices repeatedly.
Tips:
1) Just as you have been doing, make certain the radios are turned off before plugging in any audio device.
2) Once you plug in the device and turn on the radio, press the PTT button once to initialize the PTT capability.
3) If you continue to have difficulties, reprogram the radios back to a basic operation, shutting off any special features such as call tones, Qt filtering, interference eliminators, weather radio capabilities, etc. Sometimes going back to this basic mode will alleviate the problem. Then one by one you can add back in the features you desire.
Hope some of this helps. Best regards.
Mar 28, 2013 | Motorola Talkabout MD200 Two-way Radio
Motorola talkabout MR350 headset only sends audio and can not recieve
Likely not compatible. One thing to try is to make certain the transmitting unit is turned OFF when you initially plug in the headset. Sometimes if a headset is plugged into a radio when it is already ON, the headset will appear to be in VOX (voice activated) mode and will not allow the user to receive. Also, if this headset has an inline PTT, it may not be compatible with the radio and you would need to use the PTT on the radio.
If this doesn't work, you would need to use the TalkAbout headset designed for the MR350.
Best regards.
Mar 03, 2012 | Motorola MR350R Two Way Radio
We tried using a headset with it. Now, without the headset it goes back and forth between iVox and regular mode everytime you push the PTT button. Is there a way to stop it from going into Vox mode?
Here is a link to the user guide, reference page 22 for instructions on turning iVOX and VOX on or off: http://www.giantintl.com/ContentManage/manuals/Moto/T65xx.pdf (Double check you do not have the lock symbol showing while trying to change programming.)
Also, another phenomenon which can occur is when you unplug a headset or audio device while the radio is still turned on. This can leave the radio partially in VOX mode. You might try plugging in the device with the radio turned off. Then turn the radio on, use the device in VOX mode. Then shut the radio off and remove the device. See if it clears the radio's sense of having a headset plugged in.
A damaged jack can also cause the same problem.
Best regards.
Nov 05, 2010 | Motorola Talkabout T6500 (7 Channels)...
Hi I have the T5622 talkabout with a PTT headset. I can transmit OK but I am not receiving anything other than a ''click'' when the other person transmits. I have tested the headset and I am able to recive...
Here a few thoughts which come to mind.
1. You do not mention whether the radios communicate with the headset no on the radio. I will at this point, assume they do.
2. Be certain to have the radio SHUT OFF when plugging in the audio device.
3. Check your VOX settings. It could be your radio is going into VOX mode.
4. Only use the PTT button on the headset. Do not press the PTT on the radio at any time while using the headset.
5. Check that you have CALL TONES shut off.
6. Lastly, if nothing else works, go back to a basic mode, and set both radios where there are no special features turned on. ie turn off CODE, Qt Filter, VOX, Call Tones, etc.
Here is a link to the manual: http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T56XX_57XX_User_Manual_E.pdf
Best regards.
Feb 05, 2010 | Motorola Talkabout T5720 (7 Channels)...
Wiring diagram for accessory plug needed.
I am looking for the same wiring diagram. The headset Moto sells is a single earpiece with microphone, so how does that end up being a stereo connection Neto? Just curious how, or is there also a full headset with microphone? ( I dont' know, just asking)
Would this be a 4 ring TRS connector? Sleeve = ground, then left, right, and the tip as the microphone??
Jan 18, 2009 | Motorola Talkabout T5420 (14 Channels)...
Motorola T5500 - Continuous transmitt with headset
1) Be certain the radio is shut off when plugging in the audio device.
2) On most units, press the PTT button to turn off the VOX feature.
3) If you are not planning to use VOX. Turn the VOX feature off. Follow the programming instructions which came with the radio.
Hope this helps.
Jan 15, 2009 | Motorola Talkabout T5500A (14 Channels)...
Motorola T6310 Talkabout Sound only comes out of earphones
We have discussed your dilemma. Check your audio jack hole to be certain nothing is still in the hole. Check to see you have the VOX setting turned to a normal or off setting. Typically the radio will shut off the front speaker when an audio device is plugged into the jack. If the radio senses the device, or a small piece of the plug is stuck in the jack, or the jack is damaged, it will shut off the front speaker.
Since you can hear when using the headphone, it is apparent you have the radios programmed to the same frequency and code settings. This leads us to believe it is not a programming issue, short of the VOX feature, or mic gain. You might double check these settings.
Here is a link to the manual: http://www.usersmanualguide.com/motorola/2-way_radio/t6310
Nov 14, 2008 | Motorola Talkabout T6310 (14 Channels)...
Using headset jack - unit always transmits
Try plugging in headset BEFORE turning on radio. You should see the word VOX (not iVOX) on your display. At least this is what works for me.
May 11, 2008 | Motorola Talkabout FR60 (14 Channels)...
Top Motorola Audio Players & Recorders Experts
Steve
GASTON CHOUINARD
InstaRep
InstaRep
Are you a Motorola Audio Player and Recorder Expert? Answer questions, earn points and help others
