MY SHARP AR-5127 COPIER SHOWS "ADD TONER CAN NOT COPY OR PRINT" AFTER ADDING THE TONER THE SAMETHING STILL APPEARS.WHAT WILL I DO?
    Habit-Forming:
  • 190 Answers
Open front cover and close again.
Posted on Dec 25, 2013
  • 61 Answers
SOURCE: Sharp AR-5127, the error code U2-40
U2-40 is a board error, F1-15 is finisher lift motor error.
To reset: #, interrupt, clear, interrupt. (screen should say service mode), enter 16, print, are you sure? , yes.
For the finisher error, follow above procudure, entering 14 instead of 16. if error returns, disconnect the finisher
Posted on Nov 28, 2008
  • 126 Answers
SOURCE: Sharp AR-5127 H2-00 code reset
Sharp Fuser
H2-0 Fusing unit temperature error
H4-0 The fusing unit doesn't heat up.
***ALWAYS DISCONNECT POWER WHEN WORKING ON MACHINE***
You have to reset fuser errors with simulation 14. Push P * C * then 14 then Start (the button you use to make copies) and it should reset the code. If not then replace the fuser.
SM 5-1 should turn the lamp on. If lamp blinks on and off it is the thermistor, if it does not it is the lamp, but check the contacts on the lamp/fuser -- they have been known to erode.
Also check thermal fuse, if defective replace.
Posted on Feb 01, 2009
  • 30 Answers
it is a heater code. The thermostat has blown and resetting the code could cause a fire, but it probably won't do anything, the part will need to be replaced
Posted on Feb 25, 2009
  • 37 Answers
SOURCE: AR-5127 Counter Reset
Try these steps
1.Press continously #key then Interrupt key then CA key then # key
2.If the display turns off it means that you are inside the simulation but if not do again step 1.
3.Press 81 then press enter then press 1 then enter
Hope that this will help to reset .
Posted on Mar 03, 2009
  • 255 Answers
SOURCE: Solution for SHARP AR 5127 error U2-40 call for service
This means that the cartridge's sensor is miscommunicating with the copier memory thus the code U2 -40. You should clean the inner sensor connector and the toner sensor of the spilled toner by low blower. Perform this code ;# , interrupt , C, Interrupt keys in that order and press 16 then Print key and the code will be cleared.
Posted on Feb 12, 2010
Sharp AR-5127 error code F2-04
CRUM data read trouble
Replace the toner cartridge.
Replace MCU PWB.
Replace MCU PWB EEPROM
Check and fix connection between
CRUM (toner cartridge) and MCU
PWB.
May 18, 2014 | Sharp AR-5316 Advanced Digital Imager...
Hi i refil the toner for my sharp ar-m207 and later the copier say add toner can not print or copy help my please
You have to replace the whole toner cartridge because there is a crum chip on the back of the toner cartridge. When the cartridge reaches empty and the copier says change toner the copier burns that chip so it can not be reused again.
Aug 24, 2011 | Sharp AR-M207 All-In-One Laser Printer
Feb 02, 2010 | Sharp AR-5316 Advanced Digital Imager...
ERROR CODE U2-40: SHARP AR 5127
ERROR CODE U2-4 COULD BE RELATED TO THE MEMORY BATTERY BEING DEAD ON TEH MAIN BOSRD IF IT IS AN OLD MACHINE SO YOU COULD CHECK THSI OR REPLACE AND TRY WITH NEW
Jun 12, 2009 | Sharp AR-5316 Advanced Digital Imager...
Nov 26, 2008 | Office Equipment & Supplies
SOLUTION: ERROR MESSAGE U2-40, SHARP COPIER AR-5127
PRESS #
PRESS =
PRESS C
PRESS =
TYPE 16
PRESS ENTER BUTTON (the button for making photocopy)
PRESS 'OK' TWICE
Note: be fast in pressing all the buttons.
FROM EKPA ONU - (+2348055790979, NIGERIA,LAGOS)
Apr 18, 2008 | Sharp AR-5316 Advanced Digital Imager...
1,041 people viewed this question
k24674
