Question about E-Machines Computers & Internet
Fault finding dead red led blinks no blue led
  • 24 Answers
1.not much info here.
>> please leave a model number <<
2. more info on issue would help (wont power on, boots to bios but not windows) ill assume the word dead means the system wont power on.
3. if the system will not power up then the led is likely communicating a POST message. POST messages can be referenced on the e machines support site.
4. typically one would remove all non-essential hardware and try to boot (ram is pretty much the only essential hardware {depends on the model})
\/ if no info on POST messages is found or is not helpful \/
5. Power supply can be tested with a multi meter if you have a multi meter see here: http://pcsupport.about.com/od/toolsofthetrade/ht/power-supply-test-multimeter.htm
6. (WARNING there is a slight chance that you could harm the donor supply try this at your own risk) you can try swapping power supplies if you have one that is compatible (from an old machine or from a different machine for testing purposes). if it boots with diff PSU then that's the problem.
\/ for the brave \/
(de-soldering \ soldering can be difficult without the proper equipment and technique read up first)
7. look for bulging capacitors on the motherboard if caps are bulging they can be replaced with caps that are exactly the same.
Posted on Oct 22, 2013
By d'sign 32 inch led red and blue light on front of tv wont stop flashing red and blue light. and the volume simultaneously once put high reduces on its own to nothing
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
Nov 23, 2016 | Televison & Video
Led lite blue solid and led lite red solid when i turn on my pdp-5070pu
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Apr 03, 2014 | Pioneer Televison & Video
Just stand by led blue and red. it wont power on
Sounds like main board fault. These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Apr 03, 2014 | Pioneer PDP-5070HD 50 in. Plasma...
Bush led 26916hd
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/. If the blinks continues, and non-stop, the fault should be with its main system control IC, and with the memory IC.
Dec 13, 2013 | Bush LCD/ Plasma/ LED Pivot Mount in Black
Emachine 442 laptop dead red led blinks no blue led. laptop computer
You can try to unplug it and take the battery out for about 20 minutes then try again.
Oct 22, 2013 | Computers & Internet
I’m having a problem with my Toshiba 42HL196. Once or twice the red LED was flashing and I held the power button in for a bit and it started working again. Today I was having cable installed and after a...
http://homenol.blogspot.com/
Mar 13, 2017 | Toshiba 42HL196 42 in. LCD HDTV
The front LED flashes red & blue when I turn it on. What does this mean?
LED Indicators - LaCie 2big Network
The LED indicators above the drive bays and the front LED indicate drive status and activity.
During Startup
  • Front LED – blinks red/blue until both disks are powered on, then turns solid blue.
  • Rear LEDs – blinks red/blue until corresponding disk is powered on, then turns solid blue.
NOTE: If the device is not able to initiate the boot process following disk startup, the front is solid red.
During Bootup
  • Front LED – solid blue
  • Rear LEDs – solid blue
NOTE: If a disk is failing, both the disk’s corresponding rear LED and the front LED will be solid red.
During RAID Synchronization
  • Front LED – solid red
  • Rear LEDs – The LED corresponding to the original disk will be blinking blue and the one being synchronized is blinking red
  • Once both disks are synchronized, their corresponding rear LED and the front LED will be solid blue.
Apr 06, 2010 | LaCie 2 TB 2big Triple Interface External...
Free Pulse
The following procedure will re-establish the communication link between the Headphones and the Wireless adapter, this is called "pairing". Before you start please make sure both the headphones and the wireless adapter are fully charged and turned off.
Note: The headphones and the wireless adapter come pre-paired from the factory.
1. Press and hold the power button on the headphones. See Figure 1.
Figure 1
2. Continue to hold the button down until the LED starts flashing red/blue in an alternating pattern. Release the button when the LED starts flashing red/blue. See Figure 2.
Figure 2
3. Once the headphones LED is flashing red/blue, press and hold the power button on the wireless adapter. See Figure 3.
Figure 3
4. Hold down the button until the LED starts flashing red/blue in an alternating patter. The LED will blink blue, then turn off for a few seconds then blink red/blue. Release the button when the LED starts flashing red/blue. See Figure 4.
Figure 4
5. Once both the headphones LED and the adapter LED is blinking red/blue, press the volume up button once on the headphones. See Figure 5.
Figure 5
Once the headphones is paired with the adapter, the LED on the headphones will blink blue once every two seconds. See Figure 6.
Figure 6
When the adapter is paired the LED will be solid blue. See Figure 7.
Figure 7
The adapter may continue to blink red/blue for a few seconds even after the headphones LED starting blinking blue. This is normal; the adapter may take a few additional seconds before the LED turn solid blue.
Once the headphones and the adapter are paired, it is not necessary to pair them again even if the batteries on both units are completely drained.
Additional Note: Repeated pairing will not improve the sound quality or give the headphones and the adapter a cleaner connection.
Mar 11, 2008 | Logitech FreePulse Wireless Consumer...
No Picture, Power LED goes from Blue to Red
It sounds like the red LED is signifying a fault. Check your manual (or ring the manufacturer's support line) to find out what the red LED means. If it does in fact signify a fault, file a fault with the manufacturer and return it to them under warranty (if you still have it).
Sep 06, 2007 | Insignia IS-LCDTV32 32 in. Television
Computers & Internet Logo
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
