Question about iTEKIRO Laptop AC Power Adapter Notebook Charger for Lenovo G770 103728U G770 10372KU G770 10372MU G770 10372VU G770 10372WU G770 10375FU G770 10375WU IdeaPad G430 G430-20003 G450 G450-20022 G460 G460-20041 G460AP G460AX G465 G560 G565 S205 U110 U110-2304-2A
LENOVO G770 LAPTOP NO POWER NOT CHARGING WON'T START
    Sergeant:
  • 324 Answers
The most common issue identified with the G770 is with the charger/ power adapter - If you can get your hands on one try it should do the trick
Posted on Oct 24, 2013
Webcam failed when upgraded to Win 10
What OS were you using when you upgraded? If you were using Windows 7, you could try to download and install the Windows 8 driver for the camera. These will often work under Windows 10.
http://support.lenovo.com/us/en/products/laptops-and-netbooks/lenovo-g-series-laptops/lenovo-g770-notebook
Nov 02, 2015 | Lenovo Essential G770 Intel Core I5 8gb...
How to find a Slimtype BD DS6E25H Driver for my Lenovo G770 Laptop
It is on the IBM web site, the manufacturer of your laptop, if it is software for your laptop..
Jun 05, 2014 | Computers & Internet
My husbands laptop a Lenova G770 the keyboard is locked & he cannot access any programmes, he has tried rebooting, turning off, and running system check nothing helps ...advice please
I've never seen or heard of a "keyboard lock" feature before, so it's probably a problem. As a temporary fix, I'd get an external USB keyboard so that the laptop is usable. A permanent fix would require opening up the machine and checking the ribbon cable that connects the keyboard to the motherboard. It's rare for this cable to have any issues, but I've found that on some laptops it can come unclipped if you drop the laptop or it's exposed to violent motion.
Sep 23, 2013 | Lenovo G770 10375FU Notebook
I have lenovo 44463fg laptop why it is not charge do you tell me the charging ic name thanks
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Nov 07, 2012 | Lenovo Computers & Internet
Lenovo 4446 NOT POWER ON
keep your laptop on charging for one hour and dont on. after one hour your laptop will show led on
Feb 19, 2012 | Computers & Internet
What should i do if my lenovo laptop is not turning on or charging
remove all power source (also battery) then replug the power source
Dec 23, 2011 | Lenovo ThinkPad Computers & Internet
HI, i Have lenovo 0769-A63 laptop i have problem in my battery, when i put AC then my laptop is start,battery shows 83%(pluged in,Not charging). when i remove the AC System is cloosed is just like Cpu, its...
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Aug 12, 2011 | Lenovo 3000 N200 Notebook
My Lenovo laptop show message "Plugged in, not cha...
  1. Shutdown your laptop, remove battery and power adapter.
  2. Press and hold the power button for 10 seconds to drain the power.
  3. I f still no go, change your battery.
Hope this works...
May 20, 2010 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Lenovo Y530 T 3200 3GHZ 4G Laptop not charging battery when plugged into outlet;also does not work on battery alone even though it is charged to 85%
Try to perfrom power drain. You must first turn off the computer. Take out the battery and unplug the power adapter. Press and hold the power button for 30 secs. Put the batter back in, plug in the power adapter and power ip the computer then observe.
Let me know if same issue will happen.
May 11, 2010 | Lenovo IdeaPad Y530-3231U Laptop Computer...
iTEKIRO Laptop AC Power Adapter Notebook Charger for Lenovo G770 103728U G770 10372KU G770 10372MU G770 10372VU G770 10372WU G770 10375FU G770 10375WU IdeaPad G430 G430-20003 G450 G450-20022 G460 G460-20041 G460AP G460AX G465 G560 G565 S205 U110 U110-2304-2A Logo
173 people viewed this question
Top iTEKIRO Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an iTEKIRO Audio Player and Recorder Expert? Answer questions, earn points and help others
