Question about Insignia NS-L42Q-10A LCD TV
Dead TV ; No power led ; has 12 & 24 volts at power supply .
    Scholar:
    New Friend:
  • 118 Answers
I would recommend calling our Product Support Team, so you can schedule repairs at:
U.S. and Canada - 1-877-467-4289
Mexico - 01-800-926-3000
We're here to answer your requests daily from 7 am - 12 am CT.
However, if it requires repair, it may be more cost effective to purchase a new TV.
Posted on Oct 22, 2013
I have a 50 inch Samsung Smart TV UN50EH5300 that went dead...so I replaced the voltage supply board and it came on sound but no picture.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Nov 29, 2016 | Samsung UN50EH5300 - 50" 5 Series...
D-link router (with 1 antenna and no modem) that has no power and no LEDs lit. the outlet still works to charge a cellphone. how do we fix the router?
Possibly the powersupply for the router is dead. Find another powersupply with same voltage output to try OR test the output tip with a meter. If the power supply does work then your router is dead. Replace it. If there is no power (5 volts or 12 volts etc) coming from the tip of the power supply adaptor then replace the adaptor / power supply.
Apr 28, 2013 | Computers & Internet
Zenith z50pg10 its dead no click, no led blink nothing !
Zenith Flat panel TVs usually only have two boards in them Plasmas have a few more, doing a visual inspection of the power supply capacitors usually reveals swollen or bulging capacitors.
If the capacitors look good, voltage checks would be needed to isolate the problem to either the main board or power supply. Check for 5 volts to the IR board (& or keyboard) , if five volts is present suspect the main board
If this TV has voltages from power supply , suspect the Z, X and buffers
May 26, 2012 | Televison & Video
Sharp AQUOS LC-42D85U tvgos does not work and hasn't worked for several months. What is the problem?
What is ur tv problem?No tv power LED light incation all or power LED light indication an OPC LED lights indication flashing togethers?Tries tv unplug,replug it back like about an hour later,for the tv to do a whole resetting.Tv might work again.Tv still have no pwer all?Yes.The tv power supply board it is dead,that the board where the power a/c cord plug into it.If the tv have both power LED and OPC LEDS lights blinks together.The tv main board Tuner signal board it is the cause and the problems it is dead.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board or a main Tuner signal board for the replacement.
Jul 03, 2011 | Sharp AQUOS LC-42D85U 42 in. LCD TV
I have a tv sharp lc 32sb24u dont turn on the green led is blinking i have voltage in both sides of the power switch 3.2 volts
power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this help in solving the problem, take care in handling the fault.....
May 25, 2011 | Sharp AQUOS LC-32D44U 32 in. LCD TV
The tv is completely dead. i check the power supply everything checks out ok, there is only 2.5 volts coming out of the supply module. the input of the computer module has the same voltage 2.5...
there may be some bad capacitors in the primary of the power supply. do you get any led lights the front? most polaroids will have a red led on the front if the standby supply is good. there will most likely be some smaller caps 47mf@50v 10mf@50v probably that value that are bad.
Dec 17, 2010 | Polaroid Televison & Video
Tv Wont turn on!
Check the power source?Yes,tv power LED light indication flashes or LED light indication totally dead?The tv power supply board is dead.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Oct 31, 2010 | Akai LCT3285TA 32 in. LCD Television
Tv won't power up after a storm
Now the tv have a flashing LED power light indication on the LCD panel or dead no LED light at all?Yes,than the power supply board it dead,that the board where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Jul 20, 2010 | Westinghouse 26" LCD Flat-Panel HDTV
Compaq dead after power company shutdown period
Sounds like a blown fuse in the psu, replace the unit and you should be good to go.
Nov 30, 2008 | HP ATX-250-12Z, ATX-250-12Z Rev. H1, HP...
Insignia NS-L42Q-10A LCD TV Logo
121 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
