Question about Cub Cadet 1.5 in. 173 cc Chipper Shredder Vacuum CSV 050
Mice have chewed the wiring at the engine and the chute for the bag collection. I don't know where to rewire the chute. can you help?
The grass collection tube keeps getting plugged up and will not pass into collection bins.
Tom, Grass chutes get rough on the inner walls of chute over time, try to wipe/scrub inner chute the best you can. After thoroughly clean and dry, try and wax and buff inner chute with car wax the best you can, so chute will be a little more slippery and expel grass better. You may have to do this once or twice a season. Good Luck.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
May 16, 2016 | Garden
What are examples of active cat toys?
Active cat toys include toys like small mice, plastic balls, paper bags, and fuzzy balls. These toys make the cat "active" (ex. Chase/chew the ball, hide in a paper bag).
Aug 23, 2012 | Alfred Cats
I have a zanussi DA 4552, a rat has chewed through most of the machines wiring, i need a wiring diagram so i can try to rewire this machine, please can anyone help me with this
No idea to be honest but you must be able to find the colour of the wires at the ends and then re-connect them i would have thought unless its all the same colour wires ,or look at the council scrap yards and see if you see a similar machine and take the wireing out of it but take plenty of pics on the phone so you know where they all go ?.
Jan 21, 2012 | Cars & Trucks
How hard is it to rewire a 2006 stratliner? A rat chewed up some of the wires in the bike and it wont start.
slice open the wiring loom where the rat chewed them and rejoin them with a soldering iron, use heat shrink over each wire to insulate, the wires are all color coded, so should be an easy fix.
Mar 12, 2011 | 2006 Yamaha Stratoliner
Car was parked & mice chewed on wires under hood on & around engine
That is not good. They will need to be replaced of course. The only problem is replacing them. It is hard to tell what all they chewed up. It could be more then what is shown.
Mar 05, 2011 | 1986 Toyota Camry
Have a 2005 18.5 hp poulan riding lawn mower, wouldnt start so i replaced battery and solenoid and 20 amp fuses, startyer was checked and fine. Finally got it started and now it won't mow, blows 20 amp...
most likey you have a short . how do you ingage your blades by button or lever. if the button type look for a shorted wire . look for a bad wire some times mice get in to it and chew wires .
Apr 09, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Tractor mower failing to collect grass
ok i need to know what kind of collection sys. you have.if there is an electric blower type system it may be that the blower isn't working. if the system works by the blade blowing the grass up the chute then you may want to check the blades to see if the up turned tabs on the back of the blades are still there and not broken off. also if your mowing too fast the chute gets clogged and the grass just balls up onder the deck ubtil rolled out.if a blower type set up check to see if there is a fuse to the blower motor.
Apr 22, 2008 | Karcher 2500 PSI Pressure Washer
Cub Cadet 1.5 in. 173 cc Chipper Shredder Vacuum CSV 050 Logo
37 people viewed this question
Top Cub Cadet Heavy Machinery Experts
Bill Boyd
Daryl Gleaton
Tom Chichester
Are you a Cub Cadet Heavy Machinery Expert? Answer questions, earn points and help others
