Question about Sony Audio Players & Recorders
DVD disc tray rotate were slow why 3 disc player
  • 91 Answers
Normally it will be dust or something has got stuck in the tray
Posted on Oct 22, 2013
3 Suggested Answers
SOURCE: dvd tray do not open
need help on how to get my tray to open
Posted on Oct 18, 2008
SOURCE: Open/close disc tray won't open
I have a Panasonic SC-HT810V home theater system and the dvd door will not close after inserting disc.
Posted on Jan 19, 2009
Hyundai 320-A dvd player codes
Hyundai DVD-320A / DVD-360A / DVR-510C
  1. Method 1:
  2. Turn on the player (without a disc inserted)
  3. Press 7, 7, 0
  1. Method 2:
  3. Press 7, 7, PLAY
  4. Select region (0 = multi-region)
  5. Press SETUP
  1. Method 3:
  2. Open the disc tray
  3. Press 3, 8, 0, 0
  4. Select RC (0=codefree)
  5. Press SETUP
  6. Close the disc tray
Apr 20, 2016 | Hyundai Televison & Video
Tv flickers on dvd playback on toshiba dvd recorder
Could be the usual problem of a greasy center-disc =
95% OF THE TIMES I could fix a problem like this was by cleaning with rubbing alcohol the rubber ring on the little rotating disc in the center of the drive mechanism. !!!! Because users always stick their index finger into the hole of all the CD'S for inserting a disc into the tray that a tiny amount of grease gets deposited onto the little rotation disc which touches the center of any inserted disc at about half an inch from its center hole. (underneath) When its greasy the discs slide and the inserted discs speed stays uneven and slow.
You must open the drivebox ( after unplugging the power-cable) to see and clean it.
Be careful to not look at it with power "on" because the laser will make you go blind (danger!!!!!!!
Apr 07, 2013 | Toshiba DR4 DVD Recorder
Hi there, My sony rdr hx510 will not open and is making a grinding rotating sound. Baby girl either put 1 one or 2 discs in incorrectly. Can you advise on how I can get it opened and renove the discs.
Must used a philip screw driver take out all the screws to the dvd player.Must take the DVD player aparts.Take aparts out the dvd player guard shield to the dvd drive to take out the dvd dic or dics out.Don't push the open button any more,the disc or discs is jamming ur dvd door tray.Will burn out ur disc tray motor,if u keep trying push the open button,trying opening it that way.
Sep 24, 2010 | Sony RDR-HX520 DVD Recorder
My dvd player won't read disc, the door keeps
change the motor belt charge it´s located downside the disc tray
Nov 09, 2009 | Apex Digital AD-500 DVD Player
I bought a Toshiba DVR about 3 years ago and ever sence I bought it, it has never recorded anything on any DVD+R OR DVD+RW that i could find and it will not even play already recorded dvd's or play half of...
Don't understand why you didn't take it back and ask for your money back 3 years ago? I suggest you go to an legal advice center and see if you can still do something about it.
It sounds like the lazer or lens could be faulty. However it could be just a bad soldering joint.
Jun 20, 2009 | Toshiba DR4 DVD Recorder
I would like to change regions on my portable Durabrand DVD player model PDV-722
Alright, just follow these steps and let me know if you have any problems or questions
  1. Power and switch on the Durabrand DVD player.
  2. Open the DVD disc tray tray or lid.
  3. Press Stop.
  4. Press 3 - 5 - 9 - 7 (3597 in sequence). Can be done on remote control.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control
  6. Press OK.
  7. Close the disc tray and press Standby on the DVD player front
Dec 19, 2008 | Televison & Video
Conia M580 DVD player has died, cannot open disc tray to retrieve DVD disc from player. Cannot unlatch the disc tray manually, as there's no pin-hole near the disc tray, unlike most (more expensive) DVD...
Easy... follow these instructions
  • unplug from the mains
  • take the cover off (3 screws on back panel, 1 screw each side, sticker on top front)
  • You will see the DVD disk in the player drive
  • Remove the plastic ******** top of the drive - 2 x small phillips screws
  • Lift out the DVD disk.... done.
Oct 31, 2008 | Conia DVD8500 DVD Player
Dvd do not loads
Our started doing the same thing about a week after the warranty ran out. It has to do with the alignment of the discs being loaded. here's a work-around that works for us:
Open the tray
Choose which disc you are going to watch and use the Change Disc button to push the selected disc to the back (ie, if you want to view Disc 1, discs 3 and 4 will be visible in the tray).
Look down the center holes of discs 3 and 4... manually move your tray left-or-right to align the holes with the tray.
Push the Direct Play button on the top right of the unit for your disc of choice (Disc 1 using the example above).
hope that helps... I've searched for a while and played around with the unit (with and without the cover on) trying to figure out a way to re-align the tray, but no luck.
--JeD
Aug 20, 2008 | Samsung HT-WP38 System
Need code for durabrand portable dvd player
  3. Press Stop.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control.
  6. Press OK.
The above unlock DVD player region code trick should works on models including Durabrand DVD-1000, Durabrand DVD-1005, Durabrand DVM1418c, Durabrand LCDTV *** DVD player model PVS 21175S1 and others DVD players from Durabrand.
If the above unlock region code hack doesn’t work, or if you’re using Durabrand Car DVD Player model PVS1966, Durabrand PVS1960, Durabrand PVS1680, Durabrand PVS1970, Durabrand PVS223, Durabrand STS75E, Durabrand Dual-7B or Durabrand Dual-7BL, try the following unlock code instead.
  1. Power on the DVD player.
  2. Open the DVD disc tray or lid.
  3. Press 8 - 1 - 3 - 2 - 8 (81328 in sequence) on remote control.
  4. In DVD region code menu, press Enter until come to region 9 (or 0)
  5. Press Play.
  6. Close the DVD tray or lid.
For Durabrand Dual-900, try the following DVD multi-region or region free unblock sequence instead.
  1. Press Open to open disc tray.
  2. Press Clear.
  3. Press 1 - 3 - 6 - 9 - 0 (13690 in sequence).
  4. Press Standby button. After pressing, the DVD disc tray will close and DVD player will switch off).
  5. Press Standby button again to power up the DVD player.
Note: To set back the DVD player to region 1 if you’re using above unlock hack, simply press 13691 in sequence. The 0 or 1, the last digit in the key sequence is actually the digit to determine which region code you’re going to set on the DVD player. You can set to other region code by changing the last digit to 2, 3, 9 or other valid region code number.
For Durabrand DP305, try the following DVD region code unlock hack instead.
  1. Turn on the DVD player.
  2. Press Open/Close button to open the disc tray.
  3. Press Setup.
  4. Press 8 - 8 - 8 - 8 (8888 continuously).
  5. Press Next.
  6. Go to “Version and select a region code. Select 0 for all region or 9 for region free.
  7. Press Play.
The below trick should be able to unlock the region restriction on Durabrand DUR1700 DVD player.
  2. Press Setup.
  3. Go to “Preferences”.
  4. Press Play.
  5. Enter 2 - 5 - 1 - 5 - 3 - 5 (251535 in continuous sequence of keys).
  6. Press Left, Down.
  7. The current region code will be displayed.
  8. Press 0 for region free.
Note that if you select “Region 0′ which allows DVD players to plays all DVD-Video discs from Regions 1-6, some DVDs which are incorporated with “Regional Coding Enhancement” or RCE protection system will refuse to play in such machine.
Jun 05, 2008 | Jensen JR400 Remote Control
No Disk
cheke rotation of the disc .suppose it"s slow speed or not rotate change the motor . before do this make sure the tray is in loading position . if ok proced the above suggetion. if not check the tray loading motor, belt and related things best of luck do with care by.
Jun 14, 2007 | Cyberhome DVR 1600 DVD Recorder
37 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
