Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
XP 205 PRINTER LIGHT FLASHING AND MESSAGE PAPER
XP 205 PRINTER LIGHT FLASHING AND MESSAGE PAPER JAM
techman
  • 3130 Answers
SOURCE: Print head jam
Iv'e seen these problems a 100000000 times with this printer and I found a little article you may wanna read before going farther with this machine!!!! Go to http://.i18nguy.com
Posted on Apr 23, 2006
jackboy
  • 2985 Answers
SOURCE: Red Paper light keeps flashing
Try to find thge combination of buttons that reset the printer. there are many possiblities due to the modles - but try pressing any 2 and whilst holding them down switch off and then on again. Also this utility could proce use full. When it is loaded -right click the task bar icon. www.ssclg.com
Posted on Oct 02, 2007
SOURCE: epson dx4000
tracing paper stuck in printer
Posted on Apr 09, 2008
SOURCE: Message Paper Jam MP E
The sensor at the back of the printer is either stuk or out of position open the back of the printer and see if there is a little black lever sticking out if so check it for movement if it sticks yuo have to remove the back paper guide and reseat the lever in its correct position
Posted on Dec 22, 2008
pineworks
  • 4041 Answers
SOURCE: Epson Stylus TX110 printer paper jam light flashing but no paper
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 28, 2010
Kyocera fS-920KX. Not printing
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
1) Green On, Red Off = Printer Ready.
2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
3) Green Fast-Flashing, Red Off = Printer off-line.
4) Green Slow-Flashing, Red Off = Processing Data.
5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
8) Green Off, Red Off = Printer power is off.
9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem
YBC (/\)
Jun 01, 2009 | Kyocera FS-920 Laser Printer
Paper jam flashing rx 425 did me best no paper in jam cant p0rint nothing
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Apr 22, 2009 | Epson RX620 All-In-One InkJet Photo...
! keeps flashing
Check on the error message that appears on both your monitor and printer....most of the time you run out of paper, a paper jam, or a low ink cartridge....whatever message that is it needs your attention!....cheers
Apr 11, 2009 | HP Photosmart D5160 InkJet Printer
Kyocera Ecosys FS 920
So what is your printer condition? Better know what is going on your printer so can solve the problem.
YBC (/\)
Mar 24, 2009 | Kyocera FS-920 Laser Printer
Paper jam that isn't
You could try a partial reset of the printer
Unplug the power cord
Reconnect power cord
When lights are flashing, press & hold On/Resume and PaperSize buttons
When only the On/Resume light is flashing, release both buttons
When On/Resume light is steady, reset is completed
Feb 21, 2009 | HP PSC 1210 All-In-One InkJet Printer
Printer not working.
i get a paper jam light but no paper is jam my printer is new whats up!!!
Nov 27, 2008 | Canon Pixma iP2600 Photo InkJet Printer
Hp psc 1219
dear szaszy
as per your information your printer paper jam sensor is having problem.Please get it serviced
Apr 04, 2008 | Office Equipment & Supplies
What do I do if there is no visable paper jam on the printer Canon MP 160 printer
The flashing code may be a sign that your printer needs servicing, it's most likely the mechanism that feeds the paper. If you tell me what printer it is maybe I can help you interpret the code.
Hope this helps
Dec 28, 2007 | Office Equipment & Supplies
Print head jam
Apr 19, 2006 | Epson Stylus C80 InkJet Printer
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
77 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
