I have a P4 system I have built. I have bought a new atx power supply to put in an older case. With everything installed, the power goes on, then turns off. Fans spin then turn off. There is a green led on the mainboard that is on, indicating to me that there is power going to the board. Is it possible that an older PII/PIII case (I say case only with its on off and reset buttons) cant accomodate the off/on for an newer ATX style motherboard? Any ideas?
Comments:
Apr 26, 2009
- Thanks for that. The switch is in the 115v mode. I should add that I have tried switching the Mobo into two different cases, one with the new 450W 24pin ATX PS, and the the other case which only had the 20pin molex but did have the additional 4pin that plugs in near the cpu. The mobo docs claim it can run with either the 24pin or the 20pin molex connector providing the 20pin comes with that other 4pin plug for near the cpu. I have removed power from all the drives, and pulled all the ram. Still powers then shuts off. Even the monitor gets a brief signal and turns the power from amber to green then back to amber. You can hear the monitor click on then back off. Is it possible the mobos bad?
The case shouldn't have anything to do with power getting to the motherboard. Though there should be a switch on the power supply to increase or decrease the voltage move the switch to the other position and see if the machine stays on.
Comments:
Apr 26, 2009
- That is possible. The best way to test is to take a motherboard you know is working and connect it in that case, then see if the problem is still there. But it also sounds like your power button maybe the problem so if you have another case try the mobo in another case and you will know if it is the power button or the mobo.
Was this helpful?
Yes
No
Popular Solutions for HP Pavilion? a1630n PC Desktop
Whenever I attempt to log in to my Emachine T5026,im automatically logged out and can never reach...
(More)
Whenever I attempt to log in to my Emachine T5026,im automatically logged out and can never reach the desktop.Safe mode does the same thing.
Hi I have a packard bell Imedia J2412 and recently installed a new graphic card..Radeon Sapphire...
(More)
Hi I have a packard bell Imedia J2412 and recently installed a new graphic card..Radeon Sapphire HD4770, my problem is since i installed it and updated the drivers my on board sound card wont work, there is no driver installed and nomatter what i do i cant find the driver to make it work, the hdmi has taken over, i need the onboard sound card to plug in speakers. Also more a pain that a problem since a recent o/s install the builtin card reader does not show under my computer...it works just does not show as removable storage...fussy git I know. Thanks for any help you can offer. Regards Tommy
I have a hp compaq d350 sff and want to change the processor, but I need to know what type of...
(More)
I have a hp compaq d350 sff and want to change the processor, but I need to know what type of processors are compatible with the motherboard of this computer. Please help mE THANKS!
asus 1.2ghz 1.0 gb ram I added a usb2.0 card as winxp.sp3 prompted me my wireless modem spat it, and...
(More)
asus 1.2ghz 1.0 gb ram I added a usb2.0 card as winxp.sp3 prompted me my wireless modem spat it, and system unstable, (sort of hanging) device manager says o.k. re: drivers all installed. m/b has onboard usb1.0 and i've swapped pci slots? printer works o.k. thanks and hope you have an idea.
