Question about Plumbing
Savio 2220 trips gfi. this is the second pump to do this. when the first one did it, I replaced it. was told it could be rebuilt, but for only $50 more I could get a brand new one. But I cant keep buying new pumps. was told debris sometimes gets in and blocks the impeller. is there a way I can take the pump apart and clean it myself?
  • 3,382 Answers
I think you are chasing the wrong problem. A GFCI trips when current has found another path other then the feed wiring itself. It has found another path to earth that is conducting about 5 ma or more. I would suspect the wiring not the pump. If the insulation breaks down in the pump motor that would cause it to trip. The fault can be anywhere downstream from the breaker.
If you are not comfortable get an electrification and have him meg the pump motor to be sure where the problem is.
Posted on Jun 17, 2014
SOURCE: Pump trips breaker
If the seals are damaged, water will leak into motor section and cause GFI to trip and yet the pump will seem that it is running fine if plugged into a non-GFI receptacle
Posted on Jun 12, 2009
gbaker30
  • 4 Answers
SOURCE: fountain pump keeps tripping the GFI
install a standard outlet with a weather proof box and you will have no more problems
Posted on Jun 26, 2009
  • 18 Answers
SOURCE: Pump trips GFI when submerged
Check your power cable for any hole and damage, that might be the problem
if not
remove the 2 screw where the cable is connect on the pump, gently pull off the ruber from the cord and check if your 3 wire are wet ? and if any water can come out of the cable hole?
if yes you have to take most of the pump appart to make the stator and rotor get dry and also check for any black part on the stator, to make sure it not burn if you cant find any black spot on the part let it dry for a week and spray some air on the stator everyday and your problem will be fix,
At our big factory we use special oven to dry the part quicker
If you have no water that came out from the inside of the pump it has to be the power cable or your breaker the reason why the pump work fine when only the base is submerge is because the pump have less restriction (Water to push) so the engine work is very light compare when she is submerge and have to push so much water alll the way throught the hose.
I can help you if you need more info,
Posted on Nov 12, 2009
  • 560 Answers
SOURCE: Little Giant pump WGP-90-PW trips GFI circuit
You might have 2 problems. The GFIC might be wired wrong or the pump wirng might be compromised with moisture. The noise issue? Are you running this unit without submersing it? They will burn out if you do. To get a more accurate running sound, submerse it with a flexible pipe so you can run it in a 5 gal bucket without losing the water.
It's possible a bearing is burned out.
Ron
Posted on Jul 06, 2010
Asbestos 56
  • 191 Answers
SOURCE: I have a Savio 2220
It sounds like a seal has broken and water is getting inside, tripping the GFCI. it may be possible to get a new set of gaskets for the pump, but it is not really an easy thing to do. Three years if it runs all day is quite a lot of hours. You could try a local electric motor shop, and ask for an estimate.
Posted on Jul 23, 2011
I have a Savio 2220 waterfall pump that is acting up. I have been running the waterfall for 3 years without a problem. Recently the pump will run a short time and trip the gfci. After letting it sit for a...
Jul 23, 2011 | Savio Water Master Solids Handling Pump...
I have a GE two speed motor/pump for a hot tub that I have adapted for a type of therapy called underwater pressure massage (all of the hot tub jets are channeled through a single hose for the high...
Disconnect both hot leads from the breaker at the box. Using an ohmmeter measure the resistance to ground or the neutral bar in your box. If the resistance is LESS than about 50 K you have excessive leakage current. It is unlikely the motor is the problem. I would check the wiring and switching for the leakage. Now to the second problem: If you switch between speeds while the unit is running, the GFI will LIKELY trip. This is normal as you create a massive transient that the GFI PROBABLY can't handle. There are a couple things to try: One is using a two pole control switch and turn off the pump before "switching gears" ... as an electrical engineer I can't explain this unless you can understand electrical transients AND capacitive coupling between the windings and the case of the motor. I realize you may have a combination speed and on off switch so you MIGHT have to add a switch. Ideally I would want a relay for on/off near the breaker that momentarily disconnected before shifting gears. The next fix possibility involves a trick we use to control transients in electronics. This involves noise control by using a toroid around the pair of hot wires. This MIGHT take several turns through a good sized ferrite toroid with both the hots in the same direction, side by side. This forms what we call a "Bi-Filar" choke. Look that up on Google to understand the principle... it essentially helps balance the currents in the hots and isolates them from ground for transients.
May 08, 2011 | Bryant 50 Amp 2 Pole Br250 Type Br Ni...
WAS ACID WASHING POOL...LITTLE GIANT PUMP MODEL 8E-CIA-RFS STOPPED PUMPING...TRIPS GFI WHEN PLUGGED INTO OUTLET...TOOK OFF TOP OF UNIT...CAN SEE NO SIGNS OF SHORTING OUT...
With a megger or a decent multimeter you should be able to check the cord and motor for grounds. It is tripping a GFI though so testing at this point is redundant. The bad news is that a grounded submersible pump motor is never worth fixing. A new unit is about $200 and even a cheap shop at $50/hr would take at least a couple of hours to disassemble, clean and re-insulate the winding. That assumes re-insulating it will fix the ground which is often not the case. In short, your best bet for a unit that is no longer covered under warranty is to replace it once the electrical system goes to ground.
John
Nov 04, 2010 | Garden
Pump was tripping the GFI...now it wont work at all
My pond pump had to be replaced after three years. They said the fine grit out of my fish pond. got into my bearings and cut them out.
Nov 06, 2017 | Savio Water Master Solids Handling Pond...
My gfi reset everytime the savio pump plugin
I am assuming when you say GFI you are meaning GFCI, Ground Fault Circuit Interruptor. If the pump is throwing the smaller breaker on th plug than the pump is more than likly drawing too many amps for the plug. Make sure the GFCI outlet is rated for the same number of amps as the pump. That is a good sized pump and when it kicks on it draws a lot of power.
Mar 18, 2010 | Savio Water Master Solids Handling Pump...
The pump keeps tripping the GFI. We have cleaned
How long have you had this pump? Have you had it long enough for the bushings and bearings to go bad. Have you added anything else to that line that feeds the breaker. that feeds this pump If you tell me thies things i can give you a much better awnser
Aug 08, 2009 | Savio Water Master Solids Handling Pond...
Switching my hayward pool pump from 230v to 115v. I was told i could just move the jumper, line up the arrows for 115 and be fine but my gfi keeps tripping out?
Setting the pump for 115V wont by itself cause the trip. There is either a ground in the circuit or the GFI is bad. You may want an electrician to test any further than this.
Jul 03, 2009 | Hayward 3/4hp Super Pump Inground Pool...
Rule H53sp-24 pool cover pump trips GFI breaker
GFI devices are prone to degrade over time. Also, when used outdoors there are additional moisture issues that may cause sufficient current leakage to trip the breaker.
I had a similar problem this Spring. I was using a 20 amp GFI "master" outlet that protected two additional outlets 'downstream' of it (wired to the 'load' terminals on the GFI outlet- I'd have the check the doc. to see what terminology was used here). The pump was plugged into one of the downstream outlets.
Replacing the GFI seemed to solve the problem. I did ante up $20 for an 'outdoor' model of the 20 amp GFI unit, several bucks more than the standard 'indoor' unit - have no ideal if that represented additional value or not.
Note also, that this is the third such pump I have used for my pool cover. The other two failed to come on at all after about a year's use. The mfg replaced them under warranty (I may have had to send back the old pump - I forget!).
Curtis
Mar 22, 2009 | Rule H53sp 24mgra Swimming Pool Cover Pump...
GFI for pump keeps tripping...
no you need to put 60amp breaker in house panel box
Jan 15, 2009 | Beckett Water Gardening Beckett Statuary...
Plumbing Logo
50 people viewed this question
Top Plumbing Experts
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
