Question about Master Heaters Cordless Drill Driver 12v By Master Mechanic
Master Mechanic MMH 12 v drill, need Battery & battery charger #92900
I have a Black & Decker 12 volt cordless power/hammer drill. I think it needs a new battery & possibly changer. Can I purchase a new battery & charger or is the drill too old?
try this parts supplier
Black and Decker Cordless Drill Parts
see if your model has a parts list for battery and charger
if discontinued
look for tha same used drill in better condition
or toss in the bin
Oct 20, 2016 | Drills
Drill master, model 93440 battery needed
Your best bet might be to rebuild those NiCd batteries if they cannot be revived. It is possible to revive NiCds by using 2 good batteries or a high power DC source of about 40 Volts. The details for reviving NiCd batteries are all over YouTube. I suggest you watch a few before attempting to do this. Results are mixed. They may come back almost 100% or they may be done for. In that case you will need to rebuild with new cells. Harbor freight tools are throw away tools. They are cheaply made and have poor support.
Feb 17, 2013 | Chicago Electric Drills
I have a Makita 12v cordless drill which has a Fast Charger (DC1290A) and 1220 Ni-Cad battery. Problem is that the battery only charges for 4 seconds and the charger shuts down. I need some input to decide...
It sounds like the problem is the battery. It sounds like there are shorted cells in it so that it starts to draw too much current from the charger and the charger shuts down as a safety measure.
I hope this helps,
Happy New Year,
Mark
Jan 01, 2011 | Makita 12 Volt Cordless Drill/Driver Kit
There is a yellow light flashing and battery not charging. I bought a second hand battery charger and it doesn't seem to be working either as there are no lights lighting up. Is there any way of testing...
the charger has three out points the one on the left at the side combined with the point at the back should be putting out 14 volts if not the charger is dead as for the battery the pack needs to be pulled apart and a test done on them that needs a tech with the proper equipment
hope this helps please remember to rate me
Nov 28, 2010 | Panasonic EY6409NQKW 12 - Volt Drill/...
I have a Makita with 2 PA14 batteries and a DC1414F charger. When I turn the charger one the green light flashes once but no other lights show at all when I'm trying to charge my 2 batteries. Neither...
You stated you have a 12V Cordless Drill with PA14 batteries. The PA14 battery is 14.4V. The battery may fit in your tool and might work for a while but the motor isn't made for that battery. The way to check the batteries is to try them in another charger, any 14.4V to 18V pod/stick charger will work. The way to check the charger is to try another battery, any good 7.2v to 14.4V pod/stick battery will work. Unless the charger got wet or extremely hot the problem is usually the battery. Just check to make your tool and battery voltage is compatable.
Aug 08, 2010 | Makita 12 Volt Cordless Drill/Driver Kit
I have a mikita 12 volt and when I charge it it wont hold charge.
do you have a volt meter toi check the charger voltage? if so then read the voltage out of the charger, it should be 1 or 2 volts higher than the listing 12v would be 13 or 14 volts. if it's working you probally do have a bad battery. if the charger is out then you have a bad charger.
Aug 03, 2009 | Makita 12 Volt Cordless Drill/Driver Kit
WHERE CAN I GET A REPLACEMENT CHARGER FOR A GREATNECK DRILL?
I have to be the bearer of bad news. These are mass produced to give you the lowest price possible. They are made in Keorea/Taiwan and unfortunately do not make replacement parts. These are sold to any company that pays enough to put their name on it. Shop force makes the same drill and several other brands. So when something goes bad you have to replace the entire drill (only comes in the combo pk). You can't buy seperate pieces. Try shop force or Master craft. They're similar to what you have. Found one on Ebay. IF you keep looking you can probably find a seller with just the charger. Good luck
http://cgi.ebay.com/18V-Cordless-Drill-with-charger-battery-NEW_W0QQitemZ260460074195QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item3ca4a154d3&_trksid=p3286.c0.m14
Jul 31, 2009 | Great Neck 80125/79681 Cordless 18V Drill
Black/Decker 12 v drill charger will not charge battery. help
If the battery gets warm after being in the charger a while and still is not charged, then the battery is bad
if the battery stays cool in the charger then the charger may be bad
Chargers usually have a light code, I.E. on means charged, slow flashing means charging, and a quick blinking means bad battery
Some chargers have 3 lights and the code should be imprinted on the charger.
hope this was helpful, cb
Apr 15, 2009 | Black & Decker Drills
Charger for 12 volts 7 amp battery smf
you need to go to a **** smith store and bye a kit to do this cheers peter
Apr 18, 2008 | Ryobi Multi-Volt Battery Charger
Master Heaters Cordless Drill Driver 12v By Master Mechanic Logo
56 people viewed this question
Top Master Heaters Drills Experts
Are you a Master Heaters Drill Expert? Answer questions, earn points and help others
