Question about Mtd Yard - Man 160cc, 21" Self - Propelled Lawn Mower
Riding mower---yard machine 742 RL shuts off when
Riding mower---yard machine 742 RL shuts off when shifted in reverse, no other problems
panilling9
  • 284 Answers
SOURCE: yard machine riding mower will not start
check all of your known safety switches!
Clutch has to be pushed in
seat switch (sit on mower)
blade disengage switch
Finally check your starter soleniod between the battery and the starter and look for fuses and check them out in the process
Posted on May 25, 2009
SOURCE: Yard Machines - Won't shift into gear
The problem most likely is the shaft on which the interlock slides back and forth on inside the transmission. The yardmachines have a continous spinning shaft which ends in a bevel gear. The is an interlock plate which is connected to the Forward Reverse shift lever, this plate slides back and forth and either engages the forward gear or the backward gear. This shaft is most likely galled up, preventing everything from sliding the way it needs to. This is not a difficult thing to fix if you are somewhat mechanical. Disassemble the transmission and check if everything slides
Posted on Jun 01, 2009
  • 8 Answers
SOURCE: where is the solenoid on yard machine 12.5 hp
hello....usually the solonid is behind the housing surrounding the steering wheel, if it's a front engine riding mower. Just follow the large red cable from your starter, this is connected to your solenoid....hope this helps...
Posted on Jun 07, 2009
  • 7 Answers
SOURCE: My yard machine Riding mower will not Start
might want to check your safety switch
Posted on Jun 25, 2009
bbreton
  • 437 Answers
SOURCE: riding mower will barely move
Sounds like it time for a tuneup. Air filter changed, Spark plugs replace and oil changed, plus sharpen the blades while you are at it.
Posted on Sep 26, 2009
My blades stay engaged at all times model # 917273012
if the blades are staying engaged all the time try and unplug the switch if they still stay on you have a short also try getting off the seat that should shut them off as well shifting into reverse should shut them off as well if they stay on threw all that you have a shorted wire in the system
Jul 09, 2012 | Craftsman 20 hp 42 in. Deck Yard Tractor
Riding mower surges in forward and not reverse. It
Ok first of all is not an automatic.Its a pedal operated transmission. The motion is accomplished by tightening a belt with a moveable idler and it is only shifted with a lever to forward and reverse. The belt probabley has a burnt spot in it and it hits that spot and it feels like a surge. Replace the motion belt
Mike
Oct 19, 2009 | Garden
Apr 22, 2009 | Mtd 22" Yard Machine Push Mower
I HAVE THE YARD MACHINE RIDING LAWN MOWER 742 MTD EVERYTIME I PUT IT IN REVERSE IT DIES OUT ON ME
I believe your reverse safety switch is shorting out when you shift it. Take off the cover where the shift lever is and remove the wire from the safety switch. If this cures the problem, replace the switch.
Dec 10, 2008 | Garden
Mtd Yard - Man 160cc, 21" Self - Propelled Lawn Mower Logo
41 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
