Question about Philips Coffee Makers & Espresso Machines
Heating element repair
Light comes on but does not heat water
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,632 Answers
Replace element .
Posted on Nov 02, 2013
SOURCE: Elektra KPGC 100NP
Your resettable thermostat turned off the high power heater circuit and the red warning light. The heater got too hot when the boiler became empty of water. This is to keep the heater from burning out if the boiler becomes empty. To reset the thermostat, turn the micro casa a leva over. There is a yellow plug near the center of the bottom which is easy to pry out. Stick a screwdriver, pencil, toothpick, chopstick or whatever else is lying around into the hole and gently reset the thermostat button. You will hear a click when it resets. You are then ready to go.
Posted on Jul 25, 2008
SOURCE: Gevalia CM-500 12 cup problem.
Underneath the hot pad that the carafe sits on, there are two thermal fuses that are inside tubes that are clamped to the heating element with spring clamps.
Remove the bottom of the unit (5 screws), unclamp the thermal fuse tubes, slide the tubes to one side and check the each fuse with an ohmmeter. If one of them is open, that's your problem.
Posted on Dec 02, 2008
jerryg50
  • 1667 Answers
SOURCE: HEATING ELEMENT IS RURNED OUT
You can order a new heating element from the manufacture. But, the crimp connectors and the thermo-fuse may also have to be replaced. You will need the crimp tool for the crimp connectors. You will also need a meter to verify the connections.
If you take the unit to an appliance center they can service it for you. But, you may find the cost of the parts alone to not be feasible.
Jerry G.
Posted on Jan 10, 2009
  • 131 Answers
SOURCE: the water is not heated when I put my Bunn coffee maker on
If you plugged it in before water started coming out of the sprayhead (about 2 pots full of water poured in) you might have burnt out your element, But lets start with a simpler answer. Did you check the main burner switch on the side of the tank?
If so, then I would suspect your main heating element
Posted on Feb 12, 2009
SOURCE: heating element on an lavazza expresso machine
you can call this number they will help you with your problem
1-866-526-6204
Posted on Apr 29, 2009
Red light's on... but no hot water!
HI,
OK, inside the unit there are three items, the heating element, thermostat, and thermal fuse.What has happened is the element got too hot and the thermal fuse opened.There is no reset button.In some cases you may run across a defective heating element or thermostat but its not common.The fix would probably be replacement of the thermostat and thermal fuse.For this, you would have to contact a small appliance repair center in your area.
Goodluck,
Please don't forget to rate the solution
Apr 05, 2008 | Braun WK600 Cordless Electric Kettle
Have a Miele G1220SC dishwasher. It recently developed a strange problem: when switching it on ALL program lights come on and the machine starts taking water. after a while it stops taking water and starts...
follow this steps and fix it. God bless you
Heating Element
If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Heating Element Assembly
If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Check Fault Codes
If the display lights are flashing and there is an error code in the display window, check the wiring diagram and tech sheet in the dishwasher that will provide information on the fault.
Drain Pump
If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective You'll need to replace it. Drain pumps are not repairable.
Touchpad and Control Panel
If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Jul 30, 2013 | Miele Dishwashers
Samsung DMT - 400 delicate light blinking
Heating Element
Check Fault Codes
Drain Pump
Touchpad
Jul 09, 2013 | Dishwashers
Dishwasher Siemens /se64m359gb tap light comes on in red on main display,what does this mean?
Heating Element
Check Fault Codes
Drain Pump
Touchpad
Jul 08, 2013 | Dishwashers
No light, no water heating
The heating element may have failed.
Sep 11, 2012 | Braun WK200 Electronic Water Kettle...
It is a Rowenta Professional. It won't heat, the light will come on but the iron does not get hot. When I put water in it the water pours out the holes due to it not heating. I have had it for about 5...
Possible that the heating element is open. You will need to check the continuity of the element, make sure that the thermostat is contacting if not remove and reset if the element is good. The power cord is good as the light comes on.
Feb 25, 2011 | Irons
Keurig coffee maker is on, lights lit, machine said it is brewing but no water is coming out
Even though the light is on, this does not mean the element that heats the water is working. After you fill the machine with COLD water, and the light has been on for a few minutes, unplug the machine and dump the water out into a bowl. Carefully, feel the water. Is it hot? OR just warm? Or still cold? If it is warm, the element is not heating properly. If it is cold, the element is NOT working. If the water is HOT, then perhaps the tube from the water storage reservoir to the brewing basket is clogged. If that tube is clogged, it needs to be removed from the machine and cleaned out. If the element is not working, or heating the eater hot enough, that element needs replacement. Chances are, the replacement cost/cost of repair would be more then a new coffee maker.
Feb 03, 2010 | Keurig Special Edition B60 Coffee Maker
Nov 06, 2007 | Kitchen Appliances - Others
Coffee Makers & Espresso Machines Logo
51 people viewed this question
Top Philips Coffee Makers & Espresso Machines Experts
Kolbrun...
Lisa
Lisa
Ross Keen
Are you a Philips Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
