Question about Cycling
The quick release rear wheel has does not operate as well as it used to.Leaver not back.Tighten up,will not hold wheel in place,why ?
The quick release rear wheel has does not operate as well as it used to.Leaver not back.Tighten up,will not hold wheel in place,why ?I know you should push back leaver hence leaver not back.Originally there was no problem in tightening up,now after tightening up will easily dislocate,why.The wheel sits well back,any ideas.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 12 Answers
Try putting a couple drops of oil on the lever pivot. The tighten the nut on the opposite side about a half turn. That should allow you to tighten the QR a bit more and hopefully that will hold your wheel. If it doesn't, remove the nut and look at the side that clamps against the drop out. There should be visible teeth that bite into the dropout to hold the wheel in place. If the teeth are worn smooth, you need to replace the nut. A steel one will hold up better than an aluminum one.
Posted on Oct 22, 2013
4 Suggested Answers
  • 21 Answers
SOURCE: No Rear Quick Release
Some less expensive bikes do not come with quick release skewers. You just unscrew the bolts like you would any other using a wrench or socket. The will probably be really tight so you may need to bear down or use a cheater pipe. Unfortunately, these bolt on wheels tend to be solid axles and cannot take a quick release skewer. You would need to replace the wheel.
Posted on May 20, 2010
  • 1138 Answers
SOURCE: trying to fix back breaks on diamond back bmx.
Try this site:http://www.bikeguide.org/how-to/brakes/brakes.php
Posted on Sep 11, 2009
Coachphil
  • 347 Answers
SOURCE: Hi, Not a
Take a little trip to www.schwinn.com They have instruction manuals, videos and most importantly a customer service line with someone that can walk you through their specific product.
It should not be that difficult for someone who is not a novice to put the trikes together, something is definitely wrong. Double check on the schwinn site that you have the correct assembly manual and parts list. You still have time, don't panic yet.
Posted on Dec 18, 2010
How do I fixed if my car hand brake stuck 2001 toyota coralla manual
There are several things that can make a hand brake stick on. It possible the cable attached to the leaver has come off it guide. There is a cable running from each rear wheel to the handbrake leaver , a inner cable running through a outer housing , chick that the inner cable is free to move back and forward . if all the cables are free to slide adjust the rear brakes and hand brake as instructions . Slacken off the hand brake cable adjustment. Jack up the rear wheals and adjust the brake shoes till the brakes lock, then back off till the wheels are free to turn. Then pull the hand brake leaver on two clicks and adjust the hand brake cable till the rear wheels just start to bind, release the hand brake leaver and check the wheels are free to turn.
Nov 27, 2014 | 2001 Toyota Corolla
I changed the cables from the parking brake mazda protege 1999 and does not work properly
First make sure the brake shoe linings are ok and the shoe adjusters are free . slacken off the handbrake cable then adjust brake shoes ,then pull handbrake leaver on three clicks tighten cable to feel a slight drag at the wheels, release brake leaver and check wheels are free to turn.
Apr 21, 2014 | Mazda Protege Cars & Trucks
Is there a wing nut available to replace the front axel wheelnut
Replace wheel with a quick release wheel or just bring correct wrench with you. Wing nut would need to be very big to get proper torque to hold wheel correctly
Dec 16, 2012 | Schwinn Meridian Adult 26-Inch 3-Wheel...
My insignia hand brake has locked on how do i release rear offside only
you need to take off the rear wheel and there is a hand brake hole in the drum on the disc. you locate the hole with the adjuster.. make sure the hand brake is not on. the leaver for the hand brake take the cable off if the brake is locked the leave will let you take it off. then get a peace of wood and put it on the leaver and hit it back with hammer on the wood not the leaver. then take the screw out for the locator of the disc. and hit the disc with rubber or plastic hammer going round the disc. not to hard just to get it to move when of find out why the hand brake is locked in the first place. ( prob be the shoe's pins ) change the parts. while parts off give good clean and put some copper grease on the parts that move. huck back up the cable and check disc drum part for damage. screw the adjuster back down and refit. when disc back on adjust the brake with the hole lined up and move back and forth until the brake is locked then turn back one point on the adjuster check the disc turns and then use the hand brake. if still an bit hard to move after hand brake off nock the adjuster back down one more and test again. if all well put wheel back on.
Jun 04, 2012 | 2003 Vauxhall Vectra
How do I get the rear spindle off so I can replace the emergency brake shoes on my 2006 chrysler pacifica?
Adjustment
  1. Place parking brake lever in -full released- position.
  2. Raise and support vehicle.
  3. Remove plug in parking brake shoe support to access adjuster star-wheel.
  4. Through the access hole, rotate the adjuster star wheel in the following direction to expand the shoes outward against the drum:
    1. Left brake - Rotate star-wheel toward rear of vehicle.
    2. Right brake - Rotate star-wheel toward front of vehicle.
  5. Using an appropriate tool, turn adjuster star wheel until wheel will not rotate (dead lock).
  6. Back off adjuster six detents (teeth).
  7. Rotate wheel, checking for light drag. If drag is too heavy, continue to back off adjuster one detent at a time until light drag is present. Do not back off star-wheel more than 17 detents from wheel lock.
  8. Install access plug.
  9. Adjust opposite wheel parking brake shoes using same method.
  10. Lower vehicle.
  11. Apply and release parking brake lever once to ensure proper operation of parking brakes.
Removal & Installation NOTE The following procedure may be used to remove shoes on either side of the vehicle.
  1. Lock out automatic adjuster in parking brake lever.
  3. Access and remove rear hub and bearing.
  4. Remove parking brake cable bolt at knuckle.
  5. Completely back off parking brake shoe adjustment.
  6. Remove parking brake shoe adjuster spring.
  7. Remove shoe adjuster.
  8. Remove upper brake shoe hold-down clip and pin.
  9. Remove lower brake shoe hold-down clip and pin.
  10. Remove upper and lower shoes with return spring from shoe actuator.
  11. Remove return spring from shoes.
    Fig. View of the actuator (1), support (2), adjuster spring (3), return spring (4), caliper adapter (5), shoes (6), hold-down clips and pins (7) and adjuster (8)
To install:
  1. Install return spring between upper and lower shoes.
    NOTE Before installing shoes on actuator, make sure actuator hooked to rear cable is positioned with word -UP- facing outward.
  2. Install upper and lower shoes with return spring on shoe actuator located on parking brake cable.
  3. Install lower brake shoe hold-down pin through rear of support and lower shoe, then install hold-down clip.
  4. Install upper brake shoe hold-down pin through rear of support and upper shoe, then install hold-down clip.
  5. Install shoe adjuster. Place end of adjuster with star wheel upward.
  6. Install parking brake shoe adjuster spring.
  7. Install bolt securing parking brake cable to knuckle and tighten bolt to 21 ft. lbs. (28 Nm).
  8. Using Brake Shoe Gauge, Special Tool C-3919, or equivalent, measure inside diameter of parking brake drum portion of rotor.
  9. Place Gauge over parking brake shoes at widest point.
  10. Using adjuster star wheel, adjust parking brake shoes until linings on both park brake shoes just touch jaws on gauge. This will give a good preliminary adjustment of parking brake shoes, before a final adjustment is made at end of this procedure.
  11. Install hub and bearing with wheel speed sensor as well as all components necessary to access it.
  12. Lower vehicle.
  13. Unlock automatic adjuster in parking brake lever.
  14. Perform final adjustment of parking brake shoes
  15. Adjustment This vehicle is equipped with permanently sealed rear wheel bearings. There is no periodic lubrication or maintenance recommended for these units.
    1. Raise and support vehicle.
    2. Remove wheel mounting nuts, then tire and wheel assembly.
    3. If equipped with AWD:
      1. Remove cotter pin, nut lock and spring washer from half shaft.
      2. While a helper applies brakes to keep hub from turning, remove hub nut and washer.
    4. Remove brake caliper and rotor from hub and bearing assembly.
      Fig. Hub assembly
    5. Disconnect vehicle wiring harness connector at wheel speed sensor connector.
    6. Unclip wheel speed sensor connector from spare tire mounting support.
    7. Disconnect two sensor cable routing clips on rear suspension crossmember.
    8. Disconnect two sensor cable routing clips along toe link.
    9. Disconnect sensor cable from bracket on brake support.
    10. Completely loosen, but do not remove four bolts fastening hub and bearing in place. Once loosened from threads in hub and bearing, push bolts up against rear of hub and bearing to keep brake support plate in place when hub and bearing is removed.
      Fig. Rear hub and bearing mounting bolts
    11. Pull hub and bearing off knuckle and half shaft (if equipped with AWD), then thread wheel speed sensor cable through hole in brake support plate as it is removed with hub and bearing.
    To install:
    1. Position hub and bearing bolts though rear of knuckle and parking brake support just enough to hold support in place as hub and bearing is installed.
    2. Install hub and bearing by first feeding end of wheel speed sensor cable through hole in bottom of parking brake support. As this is being done, if equipped with AWD, slide hub and bearing onto half shaft. Place hub and bearing through brake support, onto knuckle, lining up mounting bolt holes with bolts and placing wheel speed sensor head at bottom.
    3. Install four bolts fastening hub and bearing in place. Tighten mounting bolts to 60 ft. lbs. (81 Nm).
    4. Place wheel speed sensor cable routing grommet into bracket on parking brake support.
    5. Route wheel speed sensor cable along toe link and rear suspension crossmember connecting routing clips where shown.
    1. Connect vehicle wiring harness to wheel speed sensor connector.
    2. Install brake rotor and caliper.
      1. Install washer and hub nut on end of half shaft.
      2. While a helper applies brakes to keep hub from turning, tighten hub nut to 180 ft. lbs. (244 Nm).
      3. Install spring washer, nut lock and cotter pin on end of half shaft.
    4. Install tire and wheel assembly. Install and tighten wheel mounting nuts to 100 ft. lbs. (135 Nm).
May 18, 2011 | 2006 Chrysler Pacifica
How to change rear barke shoes
Brake Drums & Brake Shoes Removal & Installation To Remove:
  1. Raise and safely support rear of vehicle.
  2. Release parking brake.
  3. Remove rear wheel assemblies. NOTE: If brake drum is stuck, install two 8 mm bolts into threaded holes and tighten evenly.
  4. Remove top return spring, front and rear shoe spring clips and hold-down pins.
  5. Remove anti-rattle spring and adjuster spring. NOTE: Note position of operating lever prior to removal.
  6. Remove bottom return spring.
  7. Remove clip and washer and detach parking brake cable from rear shoe.
  8. Remove brake shoes.
To Install:
  1. Lubricate all brake shoe contact points with appropriate grease.
  2. Place operating level into position on hub.
  3. Install rear brake shoe and connect parking brake cable to rear shoe with washer and clip.
  4. Install front brake shoe and install bottom return spring.
  5. Install hold-down pins and spring clips.
  6. Position operating lever and install top return spring.
  7. Install anti-rattle spring and adjuster spring.
  8. Install brake drum and screws.
  9. Adjust brakes and install rear wheel assemblies.
Jan 21, 2011 | 2003 Kia Spectra
I but a new handbrake cable on my 99 transit and shoes and the handbrake pulls up to far
Ensure parking brake is fully released.
Place transmission in Neutral.
Tighten cable equalizer adjusting nut until rear wheel brake drag is felt when spinning rear wheel by hand.
Loosen cable equalizer adjusting nut until rear brakes are fully released.
Spin rear wheels and ensure there is no brake drag. Lower vehicle, and check parking brake operation
Mar 05, 2010 | 1999 Ford Taurus
How do I release the lock on my Craftsman belt sander to lighten the belt. It's an old Model # 315.1172
I checked Searspartsdirect.com for that model number and they listed that number, but with an extra 0 at the right end. I couldn't find a belt release lever illustrated anywhere like that on my old Craftsman belt sander. On mine, you just flipped the lever either forward or back to release and tighten the belt. (still works great) There is a spring that pushes the front roller assembly forward when the lever is operated.
Dec 03, 2009 | Cars & Trucks
Rear wheel locks down
Have rear brakes checked for improperly adjusted, as well as emergency cables partially seized. Backing up and stopping quick, frequently, can also cause self adjusters to operate & tighten things up too much.
Oct 06, 2009 | 2002 Kia Sportage
Rear wheel problem on Raleigh X1 mountain bike
Three things come to mind when I read your question. First is the rear wheel bearings. Spin the wheel back and forth while holding onto it. See if you can feel any vibration or a rough feel in the wheel. I would think that if it were the wheel bearings you would hear or feel a grinding noise when you are riding.
If your rear wheel has a nut on both sides and you tightened them and that didn't work this means you must have the quick release system. You can tighten this by unclipping the wheel. Then hold the side that has the quick release lever. Hold onto the lever itself. Then turn the other end a little bit clockwise. Then put your wheel back on the bike and reclip the lever. It should now feel tighter. You may have to readjust the quick release lever a few times until you find the desired tightness.
Lastly the problem could be that your frame is worn out or broken somewhere. This would only show up when you are out riding because of your body weight and the strain put on the frame while you are pedalling. Also the part of the frame where your rear wheel sets may be chewed up. This would cause the wheel to never really tighten on the frame and could also cause the rear wheel to move.
I had a bike where the quick release wheel stystem went bad and it would not tighten on the frame. I believe the rod that went through the middle of the wheel hub was stretched and would just not tighten onto the frame.
I hope this has been helpful
Mar 17, 2009 | Crank Brothers Joplin Adjustable Seatpost...
Cycling Logo
252 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
