Question about Necchi Sewing Machines
Can the feed dogs be dropped on a Necchi 215A-B-BS ?
    Champion:
  • 208 Answers
If you do not have a button or lever on the outside you may have a button or lever under the slide plate, if you have neither then you will have a raised plate in your attachments
Posted on Oct 27, 2013
  • 8 Answers
SOURCE: Dropping Feed dogs on kenmore model 19233
Remove extension table/accessory box by gentle pulling it away from machine. You are left with just the free arm. In the back of the free arm, lower left corner, you will fine the feed dog lever. Push the leaver to the right to lower the feed dog.Instructions for lowering and raising the feed dog are on page 48 of your owner's manual. Good luck!
Posted on Jan 01, 2008
  • 2976 Answers
SOURCE: Feed dogs do not come back up after lowering
Are you talking about the feed dogs or the presser foot. Either way, if you moved a lever to lower them, there is probably a screw that either fell out or has become loose that holds the linkage to the lever.
Posted on Jan 03, 2009
  • 3 Answers
Pull out the removable table and you will see the drop down feed dogs switch lever behind the back of the machine. Move that lever to the left or right to have feed dogs go back to normal sewing mode OR for embroidery mode.
Posted on Mar 07, 2009
raycolinashb
SOURCE: janome mermory craft 8000 drop feed dog
I hate to sound dismissive but: read the manual. Duh. It is not as written above: drop dog........
The feed dog is the toothed pieces in the sewing machine deck, under the needle, which move the material away from you when you push the operating pedal.
Dropping the dog - ie making it inoperative - (see manual for how to on your machine) means the material has to be propelled by hand under the needle. This is especially good for freehand machine embroidery as it means you can move the material in any direction whilst sewing.
It can be easier to freehand embroider if your material is fixed in to an embroidery hoop to hold it flat while you work.
Posted on Apr 24, 2009
  • 13 Answers
SOURCE: How to Drop Feed Dogs on Sewing Machine...
On many machines you tilt the machine back on its hinges to see the underside and there you will find a thumbscrew to lower the feed dogs...you also need to be sure that your machine is capable of having its feed dogs lowered...not all machines can do this!
Posted on Aug 28, 2009
Feed dog on Necchi 681c has drop,how do I fix it?
A lot of machines have a control knob/lever that raises and lowers the feed dogs. However, remember that when the control is activated, the feed dogs will not rise until the machine actually begins to stitch.
If the feed dogs do not rise, then there is most likely a problem and needs to be serviced.
Feb 14, 2017 | Necchi Sewing Machines
How do I drop feed dogs on jem silver 662?
Here's a manual:
Instruction Manual Janome Jem Silver 662
The following is for a 660, but it doesn't mention anything about darning or free motion quilting:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&ved=0ahUKEwih_NGBzpjRAhXKh1QKHbKIAvwQFggoMAI&url=http%3A%2F%2Fjanome.com%2Fsiteassets%2Fsupport%2Fmanuals%2Fcompact-models%2Finst-book-jem-gold-660.pdf&usg=AFQjCNEwCPZs5n8s4wdgIHMGHbN-GvDe-w
You can also contact a Janome dealer. If the machine does not drop the feed dogs, there should be a special plate accessory to cover them in order to do darning or free motion quilting.
Perhaps this is the accessory you need:
http://www.sewingpartsonline.com/cover-plate-elna-janome-necchi-825018035.aspx
https://tv-sewingcenter.com/products/janome-quilting-attachment-kit-for-jem-series
Dec 28, 2016 | Sewing Machines
I have a Necchi 537FA and I want to know what the knob (on the right hand side) with the dot and knit symbol does. This knob is the last one on the right hand side. Thanks in advance for the help.
I suspect the knob on the lower right hand side is the feed dog knob. The "knit" symbol is for the feed dog. One setting drops the feed dogs so you can move the fabric yourself, ie free motion quilting. The other setting raises the feed dogs so the machine will feed the fabric for you.
to find a manual, Search the internet:
Brand + Model + the word "Manual"
Aug 19, 2015 | Necchi Sewing Machines
How to free motion sew on Necchi 3537
Use the darning foot or the free motion foot, drop or cover your feed dogs and set your width and length to zero. Then test the tension. With these changes, sometimes the tension is off.
Apr 14, 2014 | Necchi Sewing Machines
Necchi 4595 feed dogs keep dropping
Tighten the screw under the plate near the feed dog
Sep 20, 2013 | Necchi 4595 Mechanical Sewing Machine
Feet not feeding and thread bunching up
the presser foot or what ever foot your sewing with does not feed the
fabric,, the feed dogs in the needle plate are what moves the fabric
to be sewed, the feet only hold the fabric against feed dog so the
machine can use the needle to sew the fabric.
if the fabric is not moving then the feed dogs have to be checked
can you see the feed dogs in the needle plate area are the up or
down?
do you have a manual for the machine?
a manual help to know where the feed dog lever is, I'm sending
you a link for a manual for the machine, so you can look for the feed
dog lever, if the feed dogs are up then there is something wrong
with the feed dogs & they need to be checked.
but if the feed dogs are down then look in the manual & see where
the feed dog lever is & put it in the up position & see if that brings
the feed dogs up to the sewing position, if the feed dogs do not
come up then the feed dogs need to be checked.
http://www.sewingpartsonline.com/instruction-manual-necchi-6015.aspx
Oct 16, 2012 | Necchi 6015 Mechanical Sewing Machine
I have a necchi model 575FA, and the needle will not advance any idea why?
if the sewing machine is not sewing & staying in one spot the that means the feed dogs are not working properly.
I also have a necchi sewing machine, check the needle plate area that's where the feed dogs are, if the feed dogs are up where you can see them & even feel them with you fingers when you rub your fingers over the needle plate area, if you can't see them good or feel them, then they are not up,,my instruction book shows that you have to remove the extension table, their should be a small door in front of the needle plate area to open that's where the feed dogs are if they are not in the up position, where you can sew, if they are in the down position move the lever to the opposite direction & see if that help the machine to sew, if it make makes no difference which position there in , then it's possible something is wrong with the feed dogs & the machine needs to be serviced
Sep 18, 2011 | Necchi 3101 Mechanical Sewing Machine
Necchi 215A Sewing machine Could anyone help I have a Necchi 215A which will not catch teh bobbin thread, I have tried a new needle and checked the bobbin is loaded and fitted correctly. The needle passes...
Make sure the bobbin has a 3-5 inch thread tail
Then make sure the top thread has a 3-5 inch tail
Then hold the top thread tail with your fingers (away from the needle)
& use the hand wheel on the right hand side of the machine to slowly
Lower the needle in the bobbin area & see if the bobbin thread will pick
Up that way
Sep 26, 2010 | Necchi Sewing Machines
My necchi mod.910 i cannot get the machine to do zigzag stitch, and straight stitching is a problem - i have to pull the material in order for it to move
The Necchi machine has a lever in the bobbin area that lets you move the feed dogs up and down. If you accidentally moved that, the feed dogs are in the down position and won't feed the fabric forward. Make s ure you can feel the feed dogs slightly above the plate. If they aren't move the lever until they do. :)
Jun 22, 2009 | Necchi 3101 Mechanical Sewing Machine
Sewing Machines Logo
70 people viewed this question
Top Necchi Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
