Question about Microwave Ovens
Sanyo, super showerwave, microwave has quit working. Clock counts down, lights all come on, but no microwaves nor does the plate spin...any ideas?
    Scholar:
  • 178 Answers
Hi William,
The secondary interlock switch is bad. You need an ohm meter to verify that the switch is not 'closing' electrically. Opening the door when the microwave is running is the primary cause of this switch's failure. The secondary cause of this failure is from constantly running the unit for extended periods of time, usually more than ten minutes or more. Be careful..
Posted on Oct 28, 2013
techman
  • 3130 Answers
SOURCE: microwave does not heat
What could cause this problem coud be a bad door switch, a bad HI Voltage capacitor, a bad power transformer, a bad Rectifier, a bad magnatron,or a bad circuit control board. Any one of these repairs could run from 65 to fix, all the way up to 200 bucks. You are probablt right, its time to buy a newer type with more lights, bells, and whistles. Good Luck
Posted on Aug 12, 2006
MicrowaveSvc
  • 9085 Answers
SOURCE: Microwave quit
I would suspect either door switches or an intermittent control circuit board, either of which can be repaired. Opening the door while cooking (without first hitting the STOP pad) is the primary cause of door switch failure over time. I have a text file on my site called "doorsw.txt" which helps in diagnosing and repairing door switch problems. You can find the file via a Google search. It will help you check and replace the door switches if you or an able friend is so inclined. In some cases, the problem is a bad connection or a bad relay on the control board. That's something we see fairly often, and we repair them for only $32.50 nationwide.
Posted on Oct 12, 2006
MicrowaveSvc
  • 9085 Answers
SOURCE: Microwave runs when door open
This is probably a a bad door switch or door switch mount. Chances are only the fan and light are running when you open it, but better safe than sorry. Opening the door while cooking (without first hitting the STOP pad) is the primary cause of door switch failure but not the only one. I have a text file called "doorsw.txt" which helps in diagnosing and repairing door switch problems, and a file called "safety.txt" which is of vital importance. You can find these files by searching at Yahoo.com (not Google) for this: microwave display safety.txt If you still have a problem, please write back with more detail. Be safe!
Posted on Nov 21, 2006
MicrowaveSvc
  • 9085 Answers
SOURCE: Displayd LOC Code
The first step is to unplug it from the wall for a few minutes then try again.
In case it helps, model EM-S5595 is unlocked by holding the Stop/Clear button as in the photo below.
If that does not do it, try Sano/Fisher Service at http://sanyoservice.com/ .
You may also have a keypad or control board problem.
Posted on Oct 22, 2007
  • 360 Answers
SOURCE: sanyo microwave clock reset
This is the generic instructions to set the clock. I have visited the sanyo site to aquire a owners manual with no success in locating one. This being said, here are the instructions.
  1. Unplug the unit for a minute then plug unit in.
  2. Press the clock (clock/timer) button once.
  3. Using the keypad, input the time you wish to set.
  4. Press the clock (clock/timer) button once.
  5. Press the stop/clear button, Time should remain.
Hope this works, if not, let me know.
Please take the time to give this solution a fix ya rating.
clarkco
Posted on Apr 12, 2009
Sanyo microwave windmill super showerwave EM-3490W. TOUCHPAD NOT WORKING
The touchpad may have failed but a defective connection should be considered.
Sep 12, 2017 | Sanyo Microwave Ovens
Model em-p672w. What caused it to stop working?
Sanyo EM-P672W Microwave Oven Repair Questions ...
www.fixya.com > Forum > Microwave Ovens > Sanyo
Recent Sanyo EM-P672W Microwave Oven questions, problems & answers. ... Mysanyo super shower microwave wave stopped working it shows on the display to press clock key but ... What would cause my Sanyo Microwave to not heat up?
Sanyo EM-P672W Microwave Oven Sanyo microwave fuse ...
Nov 19, 2015 | Sanyo Microwave Microwave Oven
Sanyo EM-SL20 Super Showerwave 900W Powergrill has stopped heating
see the informaton with carefully and use the common sense:
God bless you
When the microwave sounds okay, but there's no heat, one of the internal door switches, the high voltage circuitry, or the circuit board may have a problem.
Sep 09, 2012 | Microwave Ovens
How do i unlock the control key pad on a sanyo super showerwave
Try holding down the Stop button for approximately 5-10 seconds. This is the industry standard for locking and unlocking microwaves, although your Sanyo may vary. Please let me know if this helps!
Mar 01, 2011 | Sanyo EM-A5200SW Microwave Oven
Fuse
replace it with same current rating and voltage rating.just unscrew the case.
Mar 23, 2009 | Hotpoint RVM1435 Microwave Oven
My Sanyo 1000W microwave is shooting sparks!!!
you need to replace the cavity cover "the cardboard like",the antenna bearing set "the gun barrel like" and the gear motor.If the "gun barrel like" is stuck up because the gear motor is not rotating excessive heat will occur inside the microwave thus burning the cavity cover.
Mar 20, 2009 | Sanyo EM-A5200SW Microwave Oven
REPLACING LIGHT BULB
i have a cookwork microwave the light stoped working
Sep 16, 2008 | Microwave Ovens
Sanyo Super Showerwave out!
Sounds like a bad connection inside. unplug the power, take off the cover, look over all the connectors closely.
Dec 31, 2007 | Hotpoint RVM1435 Microwave Oven
Microwave Ovens Logo
80 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
