Question about Krups XP7230 Compact Super Automatic Espresso Machine
Xp7220 service manual - Krups XP7230 Compact Super Automatic Espresso Machine
KRUPS XP7220. I need help to identify the tube diameter and properties so i can buy a new one. I will need too the reference/size of the metal screw clamps that hold the tube to both ends.
Hi Rui, why not just order the correct parts? The high pressure silicone tubes are all the same diameter but the service data does not say what it is . The part number for the longest tube is OAO1478 and the hose clips are part number OAO1451
Jun 20, 2017 | Krups Coffee Makers & Espresso Machines
Hello, i have a krups xp7220 and i have two problems with her.
A common place for a leak under the machine is the barista seal that goes in the bottom of the boiler around that eject rod. Barista seal part number is MS5002202, Seals on the tamping piston are MS5002040 (there can be 1 or 2 of these piston seals) If fixing the leaks does not fix error 6 then I expect it will end up being the distributor. Part number MS2A01500
Jun 17, 2017 | Krups Coffee Makers & Espresso Machines
How do i change the brushes in my kitchenaid mixer?
Solution for these KitchenAid Stand Mixer Models
  • KitchenAid Stand Mixer Service Manual - K45SS
  • KitchenAid Stand Mixer Service Manual - K5SS
  • KitchenAid Stand Mixer Service Manual - KP50P
  • KitchenAid Stand Mixer Service Manual - KSM50P
  • KitchenAid Stand Mixer Service Manual - KPM5
  • KitchenAid Stand Mixer Service Manual - KPM50
  • KitchenAid Stand Mixer Service Manual - KSM75
  • KitchenAid Stand Mixer Service Manual - KSM90
  • KitchenAid Stand Mixer Service Manual - KSM103
  • KitchenAid Stand Mixer Service Manual - KSM110
  • KitchenAid Stand Mixer Service Manual - KSM150
  • KitchenAid Stand Mixer Service Manual - KSM151
  • KitchenAid Stand Mixer Service Manual - KSM156
  • KitchenAid Stand Mixer Service Manual - KSMC50
Fix KitchenAid Stand Mixer Workshop Service Repair Manual Download
Jun 18, 2014 | KitchenAid KSM90 Ultra Power Series Stand...
Xp7220 has a machine fault of No OC
Faulty communication between the 2 pcbs or distributor is drawing too much current
Dec 16, 2013 | Krups XP7230 Compact Super Automatic...
Error code 3 on krup xp7220
Direct from repair manual for your model, these are the possibilities
- Fault in the actuator high
position switch (mechanical or
electrical)
- Distributor switch fault
- Faulty electronic boards
connection
- Actuator switch short-circuited
Dec 08, 2013 | Krups XP Coffee Makers & Espresso Machines
Krups xp7220 technical error 05
It cannot be an FNF2 and also an XP7220, they are entirely different machines.
Apr 15, 2013 | Krups Orchestro Dialog FNF2 Espresso...
I need a service manual for KRUPS xp7220
Hi Moti,
did you fix the problem?
where did you gave it to fix in our country?
Sep 25, 2012 | Krups Compact Fully Automatic Espresso...
I have a Krups XP7220.The waters commes out cold under the appliance. Is the boiler as the guy from service says ? Thanks Ovidiu
When you brew a cup is the coffee cold? Or is just the excess water that come out into the water tray cold?
Sep 20, 2010 | Krups Small Appliances Espresso Machine
How to remove casing of Krups XP7220
Hey there! I just got my XP apart. I need to replace my plunger due to leakage also. Can you tell me where you found one?
Do you have a service manual? Thanks, Trig
Apr 01, 2010 | Krups XP7230 Compact Super Automatic...
Krups XP-7220 Error code 01
Go to krupsusa.com and click on "instructions" they should have the manual to download.
Jan 02, 2009 | Krups Orchestro Dialog FNF2 Espresso...
Krups XP7230 Compact Super Automatic Espresso Machine Logo
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
