Question about Whirlpool Washing Machines
Where to find whirl pool Top loader model- 3LWTW4800YQ manual
jsrock516
  • 5911 Answers
SOURCE: no power
The following link explains how to replace the drain pump on a Whirlpool Duet:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
If you have questions about this repair, or need additional assistance, please let me know. I hope this helps you.
Posted on Sep 11, 2009
SOURCE: hi am getting e1 error in my washing machine
what is an E1 error message
Posted on Jan 04, 2010
  • 1796 Answers
SOURCE: it makes all the noises but dose not turn around
Hi!!
The noise is your loose or broken belt. Take the cover off the back to access it, re-install or replace it.
While you're at it, check and clean the exhaust pipe. It will work better and save you some $$$$$$.
Good Luck
Posted on Mar 30, 2010
jsrock516
  • 5911 Answers
SOURCE: it makes all the noises but will not turn around
It sounds like you may have a broken motor coupling. Failure to agitate or spin accompanied by the sound of the motor running with no tub action are some of the symptoms you can experience with this problem. Just to be sure...the following link explains the symptoms of a failed motor coupling and how to diagnose the problem:
http://www.fixya.com/support/r3965207-whirlpool_top_loader_no_spin_problem
If you determine the coupler to be defective, the next link explains how to access the coupler and replace it:
http://www.fixya.com/support/r3574231-replacing_a_motor_coupling
The part number is included with the instructions I provided. Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you need. If you do not wish to order parts on line, use the part numbers I provided and go to your nearest appliance parts retailer. The coupler is commonly sold as part of their in-store inventory. The average cost of a motor coupling is about $15.
If you have any questions, please post back and let me know. I hope this helps you.
rickead1
  • 1998 Answers
SOURCE: i have a whirl pool duet washer with error code
try this:
No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
  • If there is no water in the unit:
    1. Make sure that both valves at the water source(s) are turned on all the way.
    2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
    3. Verify inlet valve operation
  • If there is water in the unit:
    1. Verify Drain pump operation
    2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
  • Verify there is not a siphon problem
  • Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
  • Check all hoses for possible leaks
  • Verify pressure switch operation
  • Verify flow meter operation
  • Verify CCU operati
Posted on Apr 29, 2010
Clutch for whirl pool 5 speed 9 cycle top loader washer
only available from a whirlpool service agent spares or from the whirlpool parts web page
Feb 06, 2017 | Whirlpool Washing Machines
Can't find my operator manual. want to self clean oven. Whirlpool model RF262LXST
i have a whirlpool gobal accu bake system with microwave on top oven on bottom model number gmc 275pd56 serial number xp1006922 but went to whirl pool site to get manual cant find it but the oven works fine the microwave everything total works but dont warm noithing help please
Jan 31, 2011 | Whirlpool RF265LXT Range
It makes all the noises but dose not turn around how can i fix it. Its a whirl pool ultimate caire 11 top loader.thanks
Hi!!
Good Luck
Mar 30, 2010 | Whirlpool Ultimate Care II GSW9650LW Top...
My whirl pool washing machine no longer spins. I just stopped on day. I can hear the motor trying to turn the drum but it doesnt.
Hi. This is a possible broken belt. You will need to access the drive assembly to confirm. The symptoms you have posted will often lead to a separated belt.
NOTE(IF this is a top loader, and you are hearing noise during the spin attempt, this will lead to failed motor coupler. Please disregard this note if the unit is a front-loader)
Oct 08, 2009 | Whirlpool Washing Machines
No power
Sep 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirl pool washer bangs when in spin cycle
if new did you remove shipping strap in back..the unit cant lean more than 2 degrees..make sure clothes are even in tub..try to wash clothes alike..
Dec 25, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
F1 code
well they refuse to adress your issue under a warr. beacause of age , but im certain that a whirlpool auth. servicer will glady adress your issue. As for the F1 generally relates to a faulety control board. but would want( a serveicer ) to check in more detail before jsut askin you to replace the board
Oct 23, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing Machines Logo
54 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
