Supersonic tv codes remote
Have a supersonic 1311 which I am trying to program to work on my U verse remote---how do I do it?
  • 3 Answers
SOURCE: U-Verse remote for Digital Lifestyle
I use my Directv remote to change the channel. What you have to do is go the your direct tv remote go to setup then go to remote then look for tv brand Citizen then follow the direction the menu tells you to do. It works fine. You can use Tv Brand Citizen, Concerto, Luxman They work with any u-verse remote 4 digit code 0056 5 digit code 10056
Posted on Dec 17, 2008
  • 6 Answers
SOURCE: four digit code for AT&T u-verse remote,,,tv is an ILO
I think the code is 1342 let me know if this will work.
Posted on Apr 23, 2009
  • 34 Answers
SOURCE: My Sylvania LC225SSX tv won't accept a code for my UVerse remote
Try codes for both Emerson & Funi
Posted on Nov 08, 2009
SOURCE: Need remote control code for ATT U-verse
well i have a vizio 32' lcd hdtv and the code 1343 worked for me!! the 922 didnt.....1343
Posted on Nov 09, 2009
ALIENAMERICA
  • 88 Answers
SOURCE: U-verse remote code for a Vizio HDTV
1343 is the closest one I've found that works, it will turn the TV off and on, control the volume, and enables mute. The only other thing it doesn't do is change the video input, I'm still working on finding that. If this helps, please give me some kudos.
Posted on Dec 13, 2009
I can not program my AT&T remote control to control my SHarp DVD BluRay BD-HP20. I have tried the easy find feature and every Sharp code I have found on the internet and the AT&T website for Sharp...
Hi!
You may try these codes: 1311, 3163, 1312, 3164, 3176, 2174 and 3177
If none of these codes work try the steps bellow:
Programming with the Automatic Code Finder
The automatic code finder cycles through all possible codes for the type of equipment you are programming until the correct code has been found.
  1. To program your remote control with the automatic code finder feature make sure that the Sharp AQUOS Blu-ray Disc Player is ON.
  2. To control your disk player: With the equipment on, PRESS AND HOLD DOWN, the AUX Mode Key on the remote control. The mode keys are located across the top of the AT&T U-verse remote control. While holding down the AUX Mode Key, press and release the OK button. If done correctly the Mode Keys will blink twice. The remote is now ready to be programmed.
  3. The next step is to enter the code for the automatic code finder feature. That code is 922. Enter the code 922 using the Remote Control's keypad. You have 10 seconds to enter this code before the remote times out. When 10 seconds have elapsed the Mode Keys will flash once. If this happens just start over.
  4. The next step is start the automatic code finder search. Make sure you aim your remote control at the equipment. Then press and release the play button on the remote control. Now press the Fast Forward key multiple times until the equipment turns off. Then press Enter to save the code. Your remote now has the correct code. If done successfully the Mode buttons will flash three times. Press the Power button again to turn on the Disk Player.
  5. When the code has been entered correctly, the appropriate Mode Key will flash three times. To check to see if this code works, press the Power button. If the Disk Player does not turn off, then the code is wrong and we need to try another code.
Keep me posted for clarifications.
Thanks.
Lor04
Apr 06, 2011 | Sharp AQUOS Blu-ray Disc Player
Need remote codes for Supersonic tv model SC-1331
Supersonic doesn't use universal remote codes for most of their line...you can try 0096 and a few other listed on the universal remotes, but they don't work on most of the Supersonic lineup. If you have a working remote, you can buy a universal remote that has the "learn" function and you can "teach" it. Best solution: buy a new remote from Supersonic.
May 10, 2010 | Televison & Video
I lost the remote for my hts3151d, but could
Go to the U-verse web site or to your account page for U-verse, find "program remote" and go from there.
Dec 03, 2017 | Philips HTS-3555 System
Code for a supersonic Tv using a RCA universal remote
if supersonic is not listed in the codes section manual of the rca. then you have to program it manually.
Feb 08, 2010 | Televison & Video
I have ATT U-Verse and the LG LFD790 Home Theater System. I can program the U-Verse remote to turn the LG on/off, but can not control volume from U-Verse remote. Do you have any codes I can try?
well you have the right code, but you have to get the volume options so you can control it. Hold down at&t and the ok button, then let them go. put in code 955 then press enter(bottom right) now you should be able to select whatever device and control that volume source
Dec 30, 2008 | LG LFD790 System
Televison & Video Logo
76 people viewed this question
Top Televison & Video Experts
Electro Med Services...
