Question about Lands Phones
2005 GMC Sierra 1500 2 unrelated problems (1) speedometer started sticking at 30 or 40 when stopped then reading too high, finally flipped past 120 and stayed there. (2) drivers heated seat started shutting off after several minutes then gradually got so it would only stay on for a few seconds. It stays on longer but still shuts off if the back only is turned on. Is there a circuit breaker for the heated seats. Passenger seat works fine.
pazman
  • 81 Answers
SOURCE: RCA executive series
No ringer could well be a setting and light on 2nd line means their is No 2nd line and most 2 to 4 lines phones at least require 2 active lines for the system to work correctly
Posted on Mar 30, 2008
Tin-of-Spam
  • 27 Answers
SOURCE: brake lights stay on 07 hd fxdb
Have you changed your bars? Check the micro switch behind the brake lever in the housing. Might have moved a bit.
Check that both filaments of the brake light are good and one is not broken.
While you have the brake light cover off check the connectors into the main body of the light. On my Bob (same year) They all plug into there and can be unplugged easily and re-inserted. One might have not been put in all the way home on assembly.
Hope it helps.
Posted on Aug 15, 2008
fastboyz
  • 674 Answers
SOURCE: No Idle
sound like the idle controll isnt working or got stuck .
it didnt code which makes me wonder does it have the stock air cleaner?
Posted on Sep 16, 2008
SOURCE: Electrical Problem 2002 Harley Davidson Roadking police mdl
I had the same problem with my 2003 ultra, after reading this technical support, I did some checking, and my local Harley dealer said that the old main circuit breaker needs to be changed from a 40amp breaker to a 50amp breaker. I was told that there was a factory recall, and at fisrt the breaker was changed with another 40amp breaker. it was then found out that it needed to be a 50amp breaker. I bought and installed my own breaker for around $8, but I was told they would change it for me for free, if I brought the bike in! Due to time restrictions, I chose to do it myself. So far so good. Hope it works for everyone!!!
Posted on Sep 19, 2008
check ignition switch and wirring , may have a short. had similar problem on 84 ultra wirring at switch had shorted out on frame
Posted on Dec 05, 2008
Speedometer is reading faster than actual speed
You need to have someone with a GM factory tech2 scanner go into the computer an change tire size .
Jan 30, 2018 | 2009 GMC Sierra 1500
Today I started my 1997 GMC Sierra K1500 4x4 and the little light that moves under the P R N D 3 2 1 shift indicator did not come on. Neither the speedometer nor tachometer work and the truck drives...
1997 GMC Subburban 1500 loses Tach Speedo and Trans sticks in High Gear. I changed the ignition Starter switch which I read was the problem but problem is intermittant and still exist? AMMCO told me to try changing the Neutral Saftey switch first, but didn't say why?
Oct 07, 2010 | 1997 GMC Sierra K2500
Speedometer cable how a 1500 gmc siarria
They don't have cables, the speed signal is delivered electronically to the computer then to the instrument cluster. If your gauges aren't reading correctly it's most likely due to failing stepper motors on your cluster's circuit board, very common on all 03-06 GM vehicles. Check out this page to read more about it and see how to get it fixed - Sierra speedometer repair
Apr 07, 2010 | 2003 GMC Sierra 1500
My speedometer keeps bottoming out at 120. I have had to reset it by turning the ignition on and off.
Hi, your speedometer drive motor is wearing out, very common on these trucks. Your instrument cluster needs to be rebuilt to fix the problem.
I'm a specialist in silverado speedometer repair check out my site at www.DrSpeedometer.com
Feb 07, 2010 | 2003 GMC Sierra 1500
2005 GMC Sierra 1500 crew cab - speedometer not working
This is a well known issue with model years 2003 thru 2005. There is a chance GM will replace it under recall... Call the Chevy Customer Assistance Center 1-800-630-2438 to find out.
If not and you want it fixed, try Southern Electronics at http://www.instrumentclusters.com/.
Jan 01, 2010 | 2004 Chevrolet Silverado 1500 Crew Cab
The speedometer stopped working
sometimes you can play with the ign key and turning it off and on a few times it will go down, I mean on, then all the way to lock, like 10 times. you will need the cluster replaced. any good auto shop can get a rebuilt unit or send yours off for repair.
Sep 17, 2009 | 2004 GMC Sierra
2005 GMC Pickup speedometer does not go to zero
There was not a recall, but there was a class action settlement where GM agreed to extend the warranty on certain vehicles for this problem. Check www.gmspeedometerrecall.com to see if you qualify.
Mar 07, 2009 | 2003 GMC Sierra
I have a 2005 GMC Sierra Pickup and the speedometer stopped working, well actually it goes in between 90 and 120. What do i do?
Your instrument cluster needs to be rebuilt, your speedometer drive motor is wearing out, very common on these trucks.
Dec 04, 2008 | 2007 GMC Sierra 1500
Lands Phones Logo
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
