Question about HP LaserJet Office Equipment & Supplies
I have a HP LaserJet 3053 printer that has been making a clunking sound everytime I print something out. Recently the toner has been smearing on some of the copies, also. Any advice will be helpful.
  • debrabri Oct 23, 2013
    I only use HP toner - it was making the noise before I changed the toner, too.
  • Gareth Monk Oct 25, 2013
    is the noise coming from the back of the machine or front - will be worth re-seating your fuser.
  • 63 Answers
Sounds like your toner cartridge is faulty. Has it been clunking since you replaced it - if so have you bought a 3rd party toner - some can be really poor quality. id reccomend getting a hp cartridge or a decent 3rd party
Posted on Oct 22, 2013
IB4G2008
  • 3587 Answers
SOURCE: HP Laserjet 1150 Ghost copy
clean the heads, re calibrate...do a test page, try again.
Posted on Feb 26, 2008
  • 48 Answers
SOURCE: HP LaserJet 2200 Series PCL huge dark smudge
Replace toner cartridge. If problem persist replace fuser unit. P/N # RG5-5559
Posted on May 25, 2009
CW Oly
  • 240 Answers
SOURCE: HP color laserjet 1600 wonte printe new toner color.
The supply status report is based on what the kill chip is reporting to the printer. If that particular color is not printing then it is likely that current is not flowing though a particular component in the cartridge. I would return the cartridge and get a replacement.
Posted on Feb 03, 2010
broyyce
  • 30 Answers
SOURCE: I have a HP laserjet
The problem is most likely with your fuser which is located in the rear of the printer. You may want to remove the fuser to inspect it for visible damage to determine whether it need to be replaced or not. broyyce.pngWhile looking at the back of the printer, pull the rear output door open. Push the door down to disengage the rear door stops (1). You will need a phillips head screwdriver to remove the two screws on each side of the rear cover. Lift the bottom of the cover first to disengage the alignment tabs at the top of the back cover, and then lift the cover away from the printer.
Remove the duplexer inlet guide by releasing two tabs (1) on the guide, and then sliding
the guide toward the back of the printer.
Disconnect two cables at the right, inside, of the device (callout 2), and then disconnect the fuser
power cable at the left side of the device (callout 3).
Remove three self-tapping screws (callout 4) and one grounding screw (callout 5).
Tilt the fuser slightly toward the back of the device, and then slide the fuser out of the back of the
device. Look at the two rollers inside the fuser and turn the gear on the side as you look at it. There may be something stuck inside the printer that is causing it to malfunction. If you see and damage on the fuser you can buy a new one from http://www.lbrty.com/
Good luck and I hope this helps!
Posted on May 19, 2011
MSG-CPC
  • 1325 Answers
SOURCE: hp laserjet 2025dn. Yellow smears mainly in the
hi
try cleaning the print heads with dry cotton swab.. clean anywhere wher there is excess ink
go to this link for further assistance
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=ca&taskId=110&prodSeriesId=3673580&prodTypeId=18972&prodSeriesId=3673580&objectID=c01773947
please send me 4 thumbs up
Posted on Jul 10, 2011
Testimonial: "Its toner that I used, but anyway I cleaned the cartridge and shook it horizontaly and it worked correctly. then in second use it appeared a very low "
Toner smears across envelopes when printed. I've cleaned the printer, cleaned the fuser many times (via 'create cleaning page' as suggested from HP) and still have the same issue. This used to not be a...
This might be a cartridge issue. You should also ensure that you have the media type set to envelope as this slows the pirnter down and provides best print quality. If the toner cartridge is not an OEM it might me the issue as well as toner quality on remans varies dramatically.
Mar 24, 2011 | HP LaserJet 4100 Printer
Printed pages are smeared with black
Sounds like a bad toner, or possibly the scanner is dirty. If you look where it pulls the paper through it can have a small speck, but since its on the scanner tself it will put black lines all the way down the paper.
If its larger and smeared the Toner itself is probably bad and you need a new Toner Kit, should come with new rollers and a new cartridge as well.
Mar 01, 2011 | Dell 5110cn Laser Printer
HP laserjet 5000gn when i print, output smears ink on 2 sides. not a toner issue cause changed toners already. someone says printer is telling me something and might be a warning of
If by smearing you mean the print is also rubbing off? Then you definately have a fuser unit issue. The fusing unit is the assembly that heats up and "fuses" the toner onto the page. When these start to go bad, usually on one edge or the other the print will smear/double image/wipe off of the effected area. One test you can do to verify a fuser problem is to print a page and then when the page is about half way thru the prcess, shut the printer off. Open the top and remove the toner cartridge, pull out the page and see if the lower part is not smeared. Basically what your checking is to see if the print is ok BEFORE it goes thru the fuser. Based on your description I would suspect your fuser is going bad.
Good Luck and Thank You for using Fixya.
Sep 09, 2010 | HP LaserJet 5000gn Printer
My printer worked very well until I changed the toner. I see dust around the back toner. I brought the generic toner. The store manager said that was the problem. Then I brought new HP toner. It is the...
Smeared output can result when you refeed a printed page into the printer to make a double-sided page. This happens because the rubber rollers that grip the paper to pull it into the printer can pick up toner from the first side’s printing and smear it. So before replacing parts, this is an easy thing to check. Printing multiple pages consecutively will make the pages print progressively cleaner or you can clean the rollers with rubbing alcohol.
Smeared toner also happens because the nonstick coating on the fusing roller is scratched or has baked-on debris. This can happen if the printer is in a dirty environment especially. If you are comfortable removing the fuser, you can try to clean it with a soft cloth and alcohol, but make sure you let it cool down first!
Finally, if this does not resolve your issue then make sure the fuser is heating; toner that is not heated properly will fall from the page and smear. If the thermostat is bad or the fuser not working properly, you will most likely need to replace the entire fuser assembly. This will be pretty expensive to repair so hopefully it's one of those other issues.
Apr 08, 2010 | HP Hewlett Packard LaserJet 2605dn Printer
HP laserjet P2015 is printing blank
Are you getting toner on the paper? To find out, print a test page. When you judge that the paper is under the toner cartridge, turn the printer off and look at the toner cartridge. Is your document displayed on the toner drum in toner? Is there toner on the paper?
No No Replace the toner cartridge. If that doesn't work you have more serious problems.
Yes No Replace the transfer roller.
Yes Yes If toner is smeared on the paper, replace the fuser.
Jan 08, 2010 | HP LaserJet P2015dn Printer
HP LJ 2600 "dirty" printing
If the toner cartridges are "refills" that might explain some of your print quality issues. Unfortunately, HP only has 2 replacement parts for that model, the fuser and the ETB (Transfer belt) both would require a technician to replace. Check the transfer belt of any tears or punctures. Careful not to touch it, oils from your skin can cause quality issues as well. If at all possible replace all the toners with ones that were working fine.
Jul 31, 2009 | HP Color LaserJet 2600n Printer
SMEARED PRINTING ON RIGHT-SIDE MARGIN
Ist I take it you have replace the toner/drum. If not do so. If you have then check the paper path to make sure there is nothing in the way, like a torn piece of paper or a label stuck in there? If you are 100% positive the paper path is clear there maybe something stuck in the fusing unit.
Feb 11, 2008 | HP LaserJet 3030 All-In-One Printer
HP Color Laser Jet 3550 Smearing Colors
Do you use original genuine cartridges or refilled ones. It sounds like you have had a leak and need to completely clean out your printer heads, rollers and perhaps do a deep claean as well. You can buy faulty cartridges and toners that have one leak, then the ink continually leaves traces as it prints. When you say callibrated, do you mean you ran print tests and setting tests. Running a print test can often help to diagnose ink issues an d narrow the results down a bit. After a thorough clean, you could try uninstalling and reinstalling unit.
Aug 11, 2007 | HP Color LaserJet 3500 Printer
69 people viewed this question
Seeker5211
Seeker5211
