Question about Hobart 84145 Food Processor
Need to change belt on hobart 84145 food processor
2 Suggested Answers
kel1guy2002
  • 3740 Answers
SOURCE: We purchased used 84145 Hobart can we get video
Here is one that does not have all the covers on it in operation.
Posted on Jun 23, 2011
Do you have a wiring diagram for this product?
holbart has cad drawings, free but you have to download a software to view them. here is the website hope this helps
those buttons should just have two wires on each of them.
http://www.hobartcorp.com/CAD-Libraries/
Jul 12, 2012 | Hobart FP100 Food Processor
When i turn on the hobart fp41 food processor nothing happens.But when i push on the contactor with a screw driver it works.Does that mean that the switch is bad or is there something wrong between the...
have you tried to replace the contactor and see if that helps at all? If there is another issue like a bad switch contact then you can still replace that becuase some of those parts are universal
Feb 28, 2011 | Hobart FP41 16 Cups Food Processor
Im trying to put a belt on a hobart 84146
I'll do my best to recall all the steps, I haven't done it in a while. Read instructions fully before starting, as step three may not be necessary, although if performed you'll have much more room for your hands during the remainder of the process.
1. Lay machine on side/back (so that the knife shaft is standing vertically) to access the bottom.
2. Remove bottom cover panel.
3. Remove motor. Two nuts are easy to access, the other two are quite difficult to reach. This step might not be necessary if only changing a belt because you should be able to slip the old belt off and the new one on without completely removing the knife shaft. If the knife shaft must be removed for some reason, the motor must come out to give you room to fit a puller onto the knife shaft (in order to remove the lower knife shaft bearing and lift out the shaft).
4. Take note of the knife shaft pulley. Notice how close to the casting the pulley is. When re-assembling, you'll need to position the pulley at approximately the same location for the black belt to track properly). Loosen two set screws securing pulley onto knife shaft and slide pulley down (don't lose the key for the pulley when you slide the pully down).
5. On the "outside" of the machine, remove the plastic cover where the knife shaft enters the casting.
6. Now visible is a special locknut and special lockwasher (sorry, don't know their names). One of the tabs of the lockwasher is likely bent upward into one of the slots of the locknut. Use a hammer & punch to bend the tab out of the locknut's slot, allowing the nut to turn.
7. Using a hammer and punch, position the punch in one of the slots on the locknut and spin the nut counter-clockwise with sharp blows with the hammer & punch. Have an assistant hold the shaft to offer some resistance to the shaft spinning if you're having difficulty. This may also be easier with the motor and belts still in position, using the motor to partially hold the shaft from rotating while driving the locknut loose.
8. With the locknut removed, spin it back onto the shaft a few threads with the flat side of the nut towards the casting (upside down compared to it's original, installed position). Don't spin it all the way on, you need room to fit a prybar under the flat edge of the nut.
9. Using two prybars, one directly opposite the other, under the now upside-down locknut, pry up evenly on each side of the locknut, and the shaft usually pops out fairly easily.
10. Back on the bottom side of the machine, slip off the belts and replace with new belts and reassemble machine.
11. Be sure to turn the locknut back around to it's proper orientation and be sure to tighten it with a hammer and punch just as during disassembly (special wrenches exist for those nuts, I don't know their name) and bend one of the lockwasher tabs into one of the locknut slots (even if you need to turn the locknut backwards slightly from it's fully tight position).
When everything is reasembled, be sure the flat black belt tracks properly, that is, make sure it doesn't walk off the pulley as the motor runs (just spin the shaft by hand at first to observe if the belt tracks properly.
Good Luck!
May 15, 2010 | Hobart 84145 Food Processor
Looking fora belt off my braun multipractic plus belt no 190XL037
i am looking for a belt for my food processor as it broke last week
belt number: 190XL037 model of food processor: 4243
can anyone help ?????
Feb 23, 2010 | Braun Food Processors
How to remove and replace a hobart slicer blade model 2712
PHIL SMITH HOW DO YOU CHANGE THE BLADE ON HOBART SLICER 1712??
Sep 09, 2009 | Hobart Food Processors
CAN I GET THE MANAUAL BOOK FOR COMMERCIAL MIXER MODEL84186
please e-mail onesharpstore@comcast.net and tell us what manual you need we will be glad to help
Jun 10, 2009 | Hobart FP400 Food Processor
Where can I purchase a spare main bowl for my Magimix 5100. I live in Hobart
http://www.maar.com.au/
Link for Magimix Spare Parts Page
http://www.maar.com.au/en-us/magimixparts.html
Link for Magimix Spare Parts for Model 5100
http://www.maar.com.au/en-us/magimix5100.html
http://www.kitchenandhome.com.au/catalog/information.php?info_id=7
Dec 30, 2008 | Magimix 5100 Cuisine Systeme Food...
Hobart 84145 Food Processor Logo
Top Hobart Food Processors Experts
Are you a Hobart Food Processor Expert? Answer questions, earn points and help others
