Question about Panasonic Lumix DMC-TZ2 Digital Camera
Horizontal lines in images Tz2 - Panasonic Lumix DMC-TZ2 Digital Camera
Hi, my Panasonic Lumix DMS-TZ2 is making horizontal lines over the pictures that I take. What is the cause of that?
Not sure it is on every picture you take, but digital cameras doe have problems with bright lights in a dark environment. From such a light bright lines can go horizontal. If in normal light, your camera does not have the problem, I guess you now have an explanation.
May 27, 2014 | Panasonic Lumix DMC-TZ2 Digital Camera
Image is all pink
I have have seen this a hundred times.. you have a bad ccd... the only thing you can do is send it to panasonic ... I would ask for a estimate first because it might cost just as much to fix it as to buy a new camera... sorry :(
Nov 14, 2012 | Panasonic Lumix DMC-TZ2 Digital Camera
I have a DMC-TZ2 that from today started to distort the image taken from the sensor. In mode "review" the lcd screen works perfectly so I guess is the sensor. When turning on the camara on...
You cannot fix this yourself as the sensor has failed.
If the camera is under warranty send it back for repair. If it isn't then write a firmly worded but polite demand to Panasonic anyway demanding a goodwill repair. The sensor is only about four years old and has certainly failed prematurely and there are now plenty of precedents in the digital camera industry for putting such faults right out of warranty.
Unfortunately this is and will remain a common fault with all digital cameras. Sensors can fail at any time from the day of manufacture, but on average should last an absolute minimum of five years.
Jun 24, 2011 | Panasonic Lumix DMC-TZ2 Digital Camera
My lumix dmc-tz2 is taking photos that are blurred with a purple haze and dsometimes with white lines throught them...please help
You have to change the lens assembly, if you are lucky enough to buy the parts cheap on ebay. If it is contact resistance problem, you can just pat it in any direction to see if the image is improved.
Dec 04, 2010 | Panasonic Lumix DMC-TZ2 Digital Camera
My Canon Camera Powershot A470 has been registering the shot images, showing them with horizontal lines across the image. The lines look like the ones on the start-up "Canon" image when you open the...
there is a recall on the Powershot family lens.
check this Fixya's tip:
http://www.fixya.com/support/t114938-canon_digital_camera_recall_defective
Oct 18, 2010 | Canon Cameras
Horizontal lines appear in newly saved images
the only thing i can think of is the sensor being misconnected or kaput. are you viewing them on the camera screen or a pc? it could also be camara screen...
Jul 05, 2009 | Sony Cyber-shot DSC-S730 Digital Camera
Horizontal line in images
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
May 25, 2008 | Canon PowerShot A85 Digital Camera
Taken pictures appear with horizontal lines
I have the same problem, this is my second cannon sent to me from them!
Nov 16, 2007 | Canon PowerShot A430 Digital Camera
Panasonic Lumix DMC-TZ2 Digital Camera Logo
18 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
