Question about Measuring Tools & Sensors
I changed the battery on my 547-520 Mitutoyo thickness gauge, how do I get it to power up?
    Master:
  • 683 Answers
ON button, if it does not power up check battery and if it's in correctly
Posted on Oct 23, 2013
Testimonial: "Thanks but I already tried that. There was a hand written note in the bottom of the case that refers to pressing the "preset" and then the "tol" button and that didn't work either. I'm going to try another battery even though this was a new battery."
2 Suggested Answers
SOURCE: How do I change the battery in my Mitutoyo digital?
The battery compartment is on the front of the instrument. The cover is round and has some symbols that resemble arrows pointing down. Slide the round cover down to access the battery.
Posted on Sep 28, 2011
How do I shut it off
Digital micrometers with LCD displays usually do not have a power on.off feature. Older units have an "on" button only that is used to turn them back on after a predetermined time-out or period if inactivity to conserve battery capacity but newer Mitutoyo mics cannot be turned off.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/dave_fb2c45146b845cea
Feb 26, 2015 | Mitutoyo 317-351 Digital...
Mitutoyo 543-256 linear error of 0.028mm over full 12mm stroke. Repeatability is perfect, mechanically is perfect. Is there a re-calibration procedure?
Ensure your testing procedure is perfect. If your testing procedure is proven, then you will need to send it for repair. At that point, either your scale or grid assembly is damaged or requires adjusting.
Canada's Gauge Repair Specialists
Precision Tool Works - www.precisiontoolworks.com
Jan 08, 2015 | Mitutoyo Measuring Tools & Sensors
How do I change the battery in a mitutoyo digital caliper
Find the little battery compartment on the back. Slide it open, tap lightly against your hand to drop the battery out. Insert a correctly-rated new replacement battery in the same orientation as the original battery. Slide the cover back on. They make it about as simple as possible.
Jul 24, 2014 | Mitutoyo 500 171 20 Digital Caliper
Getting message "Measuring tool doesn't respond"
Try cleaning contact pins of U-WAVE-T cable with 91% alcohol pads
If possible replaced batteries in gauges and U-WAVE-Ts
User's Manual:
http://www.mitutoyo.co.jp/eng/support/service/manual/pdf/99MAL110B5.pdf
Quick Manual:
http://www.mitutoyo.co.jp/eng/support/service/manual/pdf/99MAL216A7.pdf
Feb 21, 2013 | Mitutoyo 02AZD730D U-wave...
Mitutoyo digimatic false readings.
Try first no cable and also change battery as general solution. Second is to test does button for zero works well or give contact unpressed.
Mar 27, 2017 | Mitutoyo 293 831 Electronic Digital...
How do I change the battery in a digimatic model # cd-6
In mitutoyo digital vernier battry inserted upper portion side by display you battry cover theire is an arrow mark downward release you will find battery in side remove it and put new one battery code Sr 44 you will from marketor in mall try it
Oct 17, 2012 | Mitutoyo Dial Calipers
I have a mitutoyo digital caliper model 500-230. i replaced the battery but when i pressed the on/zero button the display keeps running like its counting down and will not stop. The in/mm button seems to...
Sounds like the new battery you installed is no good. Is the display also dim? When the battery is low that is one of the results on the Mitutoyo. Do you have another battery to try in it?
Jan 08, 2011 | Mitutoyo 500 506 10 Electronic Digital...
Model 293-348 can't zero without getting E--05. How do I fix this?
If someone was using the gauge and tightened too much you may get an error. Hopefully the gauge isn't sprung, or try replacing the battery or at least removing for a second.
Sep 22, 2010 | Mitutoyo 293 340: Test & Measurement...
Nov 05, 2009 | Mitutoyo 500 506 10 Electronic Digital...
How to measure surface finish at the bottom of a deep pocket?
Machinist, Inspector, Tool & Die Maker, for A.B.B Raymond Division, 1987-94
You need a Portable Surface Roughness measuring tool. Mitutoyo
is one maker of these. Be prepared for a $$$$$$$$ shock, as these babies aren't cheap!
SJ-201, SJ-301 and SJ-400, are three examples,
1.http://www.directindustry.com/scripts/IDPHeader.php?s=4906&URL=http%3A%2F%2Fwww.mitutoyo.co.jp%2Feng%2Fproducts%2Fkeijyou_hyomen%2Fhyomen_01.html&IDVisite=293213&MotCle=&RefCat=&IDProduit=12095&IDProdSource=&SourceType=Produit
(If the above link doesn't work for you, then try this one,
http://www.directindustry.com/prod/mitutoyo/roughness-tester-4906-30234.html
Scroll down the page, and click on -> Portable Roughness Tester)
May 05, 2009 | Mitutoyo Measuring Tools & Sensors
Measuring Tools & Sensors Logo
47 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
