Question about Honda Wb30x Water Pump Gx160
I set up my water pump to start to pump my swimming pool so i prime it and turned it on and nothing. its like the motor wants to kick in and start pumping sometimes you can hear the engine ram up but goes back. what to normal sound. what do i havde to do to find out to fix it
  • 740 Answers
SOURCE: 1996 Honda Odyssey strange, intermittent ABS problem
If you are absolutely sure that the all the abs sensors are good. Then the only other factors are the abs unit itself and the abs computer. Please have the system checked with a a scanner to make sure. Remember the only way to an ABS light will reset is by driving the vehicle and if every component of the system is fine the light will go out. Because your light is on there is a problem in the system and your abs is not functioning when the light is ON .Good Luck
Posted on Dec 09, 2008
  • 1810 Answers
SOURCE: 1986 sei 1200 goldwing It
check the fuel filter it sounds like it's pluged and causing too much back presure this is causing an over load in the fuel pump causing it to stop working or to presure lock
Posted on Aug 03, 2009
SOURCE: I have a 92 honda
HEY DID YOU FIX YET? I M HAVING SAME PROB, I CHANGED RELAY,PUMP,FILTER,AND CHECKED ALL FUSES, AND PUMP DOENTS TURN ON, CAR WILL IF I THROW CARB CLEANER IN THROTTLE BODY BUT WONT STAY ON CUS PUMP IS OFF.
Posted on May 07, 2010
mccoolstheat
  • 40 Answers
SOURCE: My vt1100cs runs for a
It has a fuel filter and a carburetor. It is possible that fule is barely getting by the filter to fill up the float bowl in the carb at idle, however when more fuel is needed at higher speeds it if can not pump fuel fast enough through the clogged filter.
Another possibility is that the gas cap is not venting fast enough. The next time it starts to sound like it's going to die, pull over as fast and SAFE as possible so you don't die, then open the gas tank listen. If it hisses like a soda bottle does then the gas tank is not venting properly. Usallly the gas caps can be cleaned, in some cases they need to be replaced.
Most motorcycle shops don't keep parts for bikes over 10 years old. check ebay or bikebandit.com or even old junk yards. If you buy from a motorcycle grave yard don't pay more than 1/4 of what it cost new, becuase that one might have the same problem.
The fuel pumps usually keep it at a specific pressure. inside the carbs there are little "bowls" that store fuel as well. they work just like a toilet. a little thing floats in this bowl and keeps it at a constant consistant level, only opening when the bowl gets so low. I attached a picture of your carb for your bike so you can see what the float bowl looks like you can also go to http://www.bikebandit.com/houseofmotorcycles/1997-honda-motorcycle-vt1100c-shadow/o/m9688#sch405015 to get any exploded diagram for your bike.mccoolstheat.gif Item (4) is the bowl. Item (3) is the little plastic floaty thing that keeps the fuel at the right hight. in between those two cylinder things that look like two hockey pucks is a valve that will open when it needs fuel. the pump only comes on when this valve opens. If the pump makes noise when you first turn the key in the on position it's probably not your pump. Don't tear the carb apart unless you have a rebuild kit. gaskets and o rings are one time use only. Let me know if you have any more questions I put this in simple terms as I could because I don't know your experience level. I can go more in depth if you need.
Posted on Jan 05, 2011
  • 8909 Answers
SOURCE: I am not sure it is a fuel pump problem but assume
I would check the electrical feed to the pump. A messy dangerous business to work on as it will pump fuel everywhere if you are not carefull
Hope it isn't the pump!!
Posted on Feb 07, 2011
Prime
Hi to prime your pump you fill the strainer basket with water and make sure all connections are tight with no leaks. Once you seal the lid turn on your pump and it should prime. If you have an issue you can force water through the suction line by putting a hose in the skimmer and force the water through your suction line. Time to Open the Swimming Pool
Jun 06, 2013 | Waterway 1 HP HiFlo Above Ground Pool Pump
1 hp water well pump hums but willnot start shaft to well is free
You may have an air lock/bubble. Try priming the pump with water before you switch on the pump.
Feb 29, 2012 | AO Smith Pool Pump Motor Hayward Swimming...
Will not prime
must have water in it to prime ,fill up the tank with about 4 gallons of water or may have the impeller is broke or it could be plugged with trash make sure you pump basket has no cracks , see picture on how 2 remove your pump .find your local pool pump motor repair guy and ask him how 2 take better care of your pump.. he can save you thousands of dollhair$ over the years .. jay pump guy longwood Florida9_30_2011_8_01_56_pm.gif
Jun 21, 2011 | Hayward 1 12 Hp Super Swimming Pool Pump...
Hello I'm trying to dismantle my hayward pump, but can't seem to able to remove the turbine... without forcing it too much....any tricks?
IT TURNS OFF TO THE LEFT, YOU NEED A 7/16 OR A 11 mm WRENCH TO HOLD THE ROTOR AT THE BACK OF THE MOTOR.. LOOK FOR THE NOTCH IN THE SHAFT UNDER THE SYNTRIFICAL SWITCH ASSEMBLY , BE CAREFUL NOT TO BREAK ANYTHING ON THE BACK OF THE MOTOR. REPLACE THE SEAL ! THERE IS A GUY SELLING SHAFT SEAL HAYWARD SUPER PUMP MOTOR REPAIR KIT & how to
ON EBAY .. HEY YOU .. PRIME THAT PUMP AFTYER ANY PUMP REPAIR !! THERE NOT SELF PRIMING UNTIL THERE INITIALLY PRIMED IN FIRST PLACE !!! AKA PUT WATER IN THE PUMP !.. IF I WAS OF HELP CLICK ON THAT (YES) BUTTON ON THE BOTTOM LEFT OF THE PAGE.. REMEMBER A CLEAN POOL IS A SAFER POOL .. JAY THE POOL PUMP MOTOR REPAIR GUY IN LONGWOOD FLORIDA ..
Jun 11, 2011 | Hayward Sp2607x10 Super 1 Hp Swimming Pool...
Pump motor will not turn over without manual priming?
All pumps need to be primed. The Self-Priming pumps still require water in the basket.
If water is not staying in the plumbing system when it is turned off, then you have a leak in one of the o-rings or the shaft seal.
Sep 04, 2010 | Hayward 1 12 Hp Super Swimming Pool Pump...
Not self priming itself. when it turns off the water pushes back out of the skimmer and pushes the basket up. it loses water and the pump cant re-prime itself.
PRIME PUMP, OPEN AIR VALVE ON FILTER. OR TAKE THE LID OFF YOUR FILTER AND SEE IF IT STARTS TO PUMP... YOU DO HAVE IT PLUMBED RIGHT? THE PIPE COMING OUT OF THE PUMP GOES TO THE FILTER !! I'M YOUR LOCAL POOL PUMP REPAIR GUY IN LONGWOOD FLORIDA. WHERE THE POOL IS ALWAYS OPEN
Aug 28, 2010 | Waterway Inground Pool Pump Champion No....
2 hp Swimming Pool - Jet / Well Pump Motor / Century B124: Water pump from swimming pool to filter lost it's ...
NOT THE MOTOR ,THE SEAL... JET PUMPS ARE NOT FOR POOLS.. LOW FLOW HIGH PRESSURE.. YOU NEED HIGH FLOW LOW PRESSURE ... IF NOT YOU MAY HAVE A SUCTION LEAK OR A BAD SHAFT SEAL... VOTE JAY
May 17, 2010 | AO Smith 2 hp Swimming Pool - Jet / Well...
My Jet Pump Looses it's prime at night.
I assume the pump is not running at night. If the pump is higher than the pool, and the inlet and outlet to the pool are both under water, then you have a small leak. This could be allowing the water to leak out of the line. Or, if the leak is higher than the pool surface it is allowing air to leak into the line, which allows the prime to run down into the pool. If you found this useful, please vote. Thanks.
Feb 16, 2010 | AO Smith 2 hp Swimming Pool - Jet / Well...
Hayward Self-Priming Pump with AO Smith 1 HP 56J frame motor. Stopped moving inground pool water. Added water to pump basket (low). Turned on pump, return jets sent "bubbles" into pool, stopped, then...
the pump must not have any air leaks in the suction side of it,, or it will just **** air and not water,,, water is very heavy you see, however i think its the impeller in the pump thats the problem,,,you should try to put water in the out let of the pump so you fill the pump with water first if its dryed out it may just wear out the impeller before it starts to **** water up, if this still dont work turn off the stop **** and strip out the pump to look at the impeller any wear on it and it will need a new one fitted
i hope this has help you, good luck
Nov 20, 2009 | AO Smith Pool Pump Motor Hayward Swimming...
Honda Wb30x Water Pump Gx160 Logo
26 people viewed this question
Top Honda Plumbing Experts
rlev_7
Level 1 Expert
Matt Olenzek
Matt Olenzek
Tony Crow
Are you a Honda Plumbing Expert? Answer questions, earn points and help others
