Question about Dell Dimension Computers & Internet
Monitor stuck in power save mode. Zero button combo will unfreeze it. Tower flashing yellow at power button. Will not reboot
  • 3 Answers
My ac in block plz un lok
Posted on Oct 22, 2013
4 Suggested Answers
ghouliass
  • 105 Answers
SOURCE: my ibm desk top is stuck in power save mode monitor won't work
So the only way you have to act is, turned off and directly on the mainboard, so do it carefully.
You'll have to find out, where, on the mainboard is located the battery, (a small coin like
unpluggable metallic piece)
Remove it and let all static electricity completely disapear, so, let the cpu power unplugged,
battery removed, for 1h,
Then, place back, battery, try to start again if not working it's hardwaire failure.
Posted on Nov 20, 2008
Luisjhernand
  • 84 Answers
SOURCE: how do we turn off the POWER SAVING MODE on the monitor screen?
Try going into your Start Menu then going into your control panel...then clicking on your "power options"....then switching the options to 'always on'..if this does not work..(as it seems you may not be seeing this because the monitor is in power saving mode) try fiddling with the setup option on your monitor and find a possible powersaving mode enabled function and disable it. every monitor is different so I couldn't really help you here...if this doesn't yield results try another monitor to see if it's the monitor having the problems or the computers video card...the video card could very well be the culprit...
Posted on Apr 08, 2009
  • 199 Answers
SOURCE: when the computer turns on i get nothing on the
when yo uget power save on you monitor it is telling you it has lost connection with the computer signal. make sure it is pluged in really good to the comp and to the back of the monitor. if it is in good then your video port or card is having a problem
Posted on Jun 23, 2009
My flatron L1710S flat screen will not come out of power saving mode. When I turn on the monitor the power button/light is green for a few seconds, the screen indicated "power saving mode", then...
I switch on my PC, ensuring that all cables, leads and power supplies are connected properly. The tower powers up no problems at all. I switch the screen on, the green led lights up, the screen is completely black. A blue box appears centrally on the screen with the text 'power saving mode'. The green led light turns amber and then the screen just goes black.
Please don't suggest going to control panel, as I can't get that far.
PLEASE PLEASE CAN ANYONE SUGGEST ANYTHING give me
Mar 08, 2011 | LG Flatron L1710S 17" LCD Monitor
Our Dell Pc is stuck in power save mode. We can,t get it off. What do we do?
The issue is with the monitor itself. If a monitor does not get a pc signal then it will go into power save mode. Check the cables and see if the monitor is plugged into the computer tower. There might be two ports to plug into, try them all.
Feb 20, 2011 | Dell OptiPlex 170L PC Desktop
My monitor has gone to Power Save Mode
If your monitor is going in Power save mode it can be cause by following reasons.
>Check the data cable going from monitor to your Dell Dimension 4600 Tower is connected properly.The connector will be blue or white in colour.
>If the Dell Dimension 4600 Tower is powering on.
If still in power save mode then try to shutdown Tower and monitor,disconnect power cable from tower and monitor.Hold the power button on tower for 15 seconds.Then again try to connect monitor and check,if still nogo,and if tower has no lights then issue with motherboard or video card or power supply.If possible try connect spare known good monitor.
Thankyou
Sep 09, 2010 | Dell Dimension 4600 PC Desktop
I am running winows xp my moitor is stuck in sleep mode and I can not use my keyboard
Try restarting your computer, when you have the system up check your power management features.
Hope it helps!
Feb 14, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
My Dell E176FPc monitor seems to be stuck in power saver mode. There is no way to access the on screen menu. When the monitor is unplugged from the compouter, it shows a self test screen with 3 colored...
Try the monitor if you can on another computer and see if it stays in power save mode. If it does then the monitor is bad.
If you try the monitor on another computer and you get video then that means theres an issue with the original computer.
Aug 04, 2009 | Dell E176FPC Monitor
Display is flashing on and off
Since the display is flashing on and off, try it again on both computers and if the flashing stills goes on then you know that the monitor is bad cause there is no way to video cards from two different computers are going to have the same problem.
Aug 03, 2009 | Cornea Computers & Internet
Dell monitor dialog box says monitor is in the power save mode
Actually, it most likely is not the monitor which is in "power save mode", it is the computer itself.
When you cannot get a computer out of "power save mode" by any other means, typically the cause is that the button-cell-type battery of your computer, which is located on the motherboard, is empty.
Usually, this happens on a computer which is a few years old, since its batteries will have run out after such a long time. (The motherboard battery is used to store various settings when the computer power is off, such as date and time. When your computer detects this battery is empty, it goes into a low-power mode).
The solution is to replace the button-cell battery on the motherboard of your computer:
  • open the case of your computer;
  • visually locate the motherboard (the main electronic circuit board) of your computer;
  • visually scan the motherboard for a button-cell battery (it looks like a digital watch battery, but a bit larger);
  • remove this motherboard battery from your computer;
  • restart your computer: it should now power up normally (you may get some warning messages during the start-up sequence, but ignore them);
  • set the date and time of your computer using the "Date and Time" control panel;
  • you can now use your computer normally, but you will lose date and time settings when you disconnect the computer power cord, since there is no motherboard battery present to store them;
  • take the motherboard battery to an electronics store and get a replacement;
  • install the new battery in your computer;
  • restart your computer, and set the date and time again; the settings will now be saved using motherboard battery power.
Dec 06, 2008 | Dell Dimension 2400 PC Desktop
Monitor shuts off during boot. Let the machine boot full up, hit the power button, the monitor flashes windows for a split second, and goes back to power saving mode
Hey there Celius,
Chances are the 'Refresh Rate' somehow got set too high for the monitor. On flatscreens , the result is a black screen.
If you have an old monitor (crt type) hook that up temporarily and reboot.
  • Right Click the Desktop
  • Click Properties
  • Click Settings
  • Click Advanced
  • Click Monitor
  • Lower the refresh rate or set at optimal
  • Check the box 'Hide refresh rates this monitor can't display'
Shutdown, Switch back monitors and try it now.
Good luck
Mike
Oct 29, 2008 | LG Computers & Internet
Flashing yellow light on Dell Monitor - what does it mean?
It means the display is in power save mode. This status occurs when the display is on but not receiving any signal.
Aug 01, 2008 | Dell E173FP 17" LCD Flat Panel Monitor
Computers & Internet Logo
Alun Cox
