Question about Canon PowerShot G2 Digital Camera
LCD screen turns off when back in body
When I turn the LCD around to face the front of the camera, the image is upside down - is this normal? Also when the LCD is pressed back into the camera body with the screen facing out , it turns the screen off. To me this seems bizarre, again is it normal? Anybody help?
  • 1 more comment
  • Ctara Nov 26, 2007
    My camera's LCD screen turns off when pushed back into the body of the camera, it hasn't always done this and sometimes will actually stay on. The screen will also blank out/go black while it is away from the body. Sometimes I can get it to show an image if I rotate it slowly, but usually it blinks in and out of showing an image. What part needs to be replaced to fix this?
  • terry-y Dec 22, 2007
    I have the same problem. When the LCD is positioned to face towards the front of the camera, the image is upside down. Also, when the LCD is positined so that you can return it to it's normal closed position but still see the screen, the screen goes blank. I tried to update the firmware,but its already current.
  • Arthur Jay
    Arthur Jay May 01, 2017
    I took the cover off where the screen is hinged,and use a little 'switch cleaner' (From an aerosol tin) Worked a treat...Everything back to normal.
We had a similar problem. If you remove the cover to the place where the LCD hinges, you will find two little wires broken off. These attach to a black touch sensor resting in the lcd screen. It comes out easily and without issue. WIth the two wires torn, the camera does not recognize that the LCD display has been turned around. It turns the screen off because it believes you have the LCD screen pointed inward towards the body of the camera. A small extension for the wires and a soldering iron solved that set of problems.
Posted on Feb 06, 2008
SOURCE:
The image is flipped upside down and won't go back I think the camera might have been dropped
THIS IS A REPAIR SHOP TASK
normally there is a micro switch fixed at the awivl head of the lcd panel. when the lcd is rotated to 180 the switch gets engaged thus turns the image upside down. iF IT IS PERMANENTLY UPSIDE DOWN yhen most probably the switch has worn out.and its not resetting.
You could try a few gentle taps to see if it releases the micro switch
Please rate my help++++Thanks for using FIXYA
Nov 20, 2009 | JVC Everio GZ-MG130 Camcorder
I have a sony dcr-sr82 camcorder and the lcd upside down
It might be the flex wire connecting LCD with camcorder responsable. What happens when you turn the LCD on the other side?
Sep 23, 2009 | Video Cameras
Sony DCR-TRV25 when opening LCD panel turning upside down
my camera used to do that too as a matter of fact its just how some cameras are i used to be in a video class with cameras in high school and college , if you have to turn the lc panel the other way for it to work so the lcd panel must be turned away from you when your filming then to watch it you can turn it around i hope this helps you if not reply to me at Jonk3y @aol.com
Sep 23, 2009 | Sony Handycam DCR-TRV25 Mini DV Digital...
Why does my phone take pictures upside down?
Hi
most Samsung phones have the ability to change the image orientation whilst camera is active. Turn on your camera as if you was going to take a picture. With the camera image on screen locate the up/down keys on the side of your phone (also used as volume control) using up/down buttons you will find that one button rotates image and the other inverts the image (back to front, like mirror image). This normally solves this issue on Samsungs but if this doesnt solve it (which I expect it will) there is a possibilty of the phone being faulty and may need factory reset? Hope that helps?
Apr 26, 2009 | Samsung SGH-e315
Hi, my camera is displaying the image upside-down on the screen! Any advice would be appreciated! Thanks
This is semi difficilt to repair. When you swivel the LCD around there is a cam that actuates a micro switch that flips the image upside down to view the image from the front.There is one small screw that holds it in place but getting to it is a little yime consuming.
Mar 02, 2009 | Olympus Camedia C-5060 Wide Zoom Digital...
Lcd won't work when it is flipped and facing out in the back.
The flex strip is cut and thats why you are facing that problem ... please use it the way it works till you can ,,,,, when it completely goes dead have it replaced by a repairman ....
Oct 14, 2008 | Canon PowerShot A630 Digital Camera
Sony handycam dcr-sr40 lcd display
flip switch is not working or stucked, a loose wire connected to this switch is also possible. you may open the unit and check for it. a pro fix is better.
Nov 06, 2007 | Sony Handycam DCR-SR40 Camcorder
Panasonic PV-GS35 Viewfinder screen connection problem in hinge joint
the hinge is definetly damaged and is going to need replacing. these hinges do need replacing if used allot because this is a moving mechanical part. This is not a easy thing to do, it needs to be done by a panasonic technician.
Oct 11, 2007 | Panasonic Palmcorder PV-DV53 Mini DV...
Mirror image
I would be interesting to discover a solution An E-500 has reported this too Suggest only Olympus will have the answers.
Aug 16, 2007 | Olympus FE-115 Digital Camera
Image won't flip when the lcd panel is fliped to 180 degree i.e when i flip the lcd panel towards the lense to do a self shoot the image, instead of appearing stright appears upside - down
normally there is a micro switch fixed at the awivl head of the lcd panel. when the lcd is rotated to 180 the switch gets engaged thus turns the image upside down. most probably the switch has worn out.
Aug 16, 2006 | JVC GR-DVL120 Mini DV Camcorder
Canon PowerShot G2 Digital Camera Logo
398 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
sathish kumar
sathish kumar
Are you a Canon Camera Expert? Answer questions, earn points and help others
