HOW TO CHANGE REGION CODE OF CED750 - Televison & Video
How do I change region code on dvd player?
I'm almost positive you can't change the region code, because it is in the firmware of the DVD player.
Jul 21, 2014 | Philips Audio Players & Recorders
Change dvd region code
Hi,according to your queation, I know you want to change the region code of your DVD, if you need, you can refer to this article How to remove region code from DVD disc. Hope it will help you!
Nov 21, 2013 | Computers & Internet
Change region code of my disk player
Go to device manager in control panel on pc
You will see list of devices
Click the tab by CD\DVD drives to expand tree
Right click on the CD\DVD drive you are needing to change region code
Second tab should be Region Code(Region 1 USA)
You can only change a limited number of times before it is locked to a region code.
Aug 07, 2012 | Televison & Video
Is there a code to change a Thomson TV DVD combo to multi region - Model L26D?
In a word....NO.
Only DVD's themselves can be multi-region (region code 0).
I always advise on this site that you NEVER change the region code on your DVD player! Here is why....
To prevent DVD copy piracy, every DVD player from EVERY manufacturer allows (if it is allowed at all) only TWO changes to the region code. A third attempt to change the region code permanently locks the player and turns it into a paperweight.
If you happen to be the rare exception to the rule.... that you have moved to a new place that requires you to change the region code to view locally purchased DVD's, then by all means change it ONCE to be able to use your DVD player. Please remember that you can only change it one more time after that though! You will unfortunately not be able to watch DVD's that are from your old region.
Feb 15, 2011 | Televison & Video
How can i change the region code on lg hl-dt-st-dvdram gsa- hion dvd burner on pc
You can only change the region code 4 times and on the 4th change the DVD drive will lock permanently on the last change.
To change the region code you can update the firmware in the DVD drive to region free (if there is one available) or install a region free software to defeat the region code.
Please click on this link and follow my instructions and the software solution method :-
http://www.fixya.com/support/r3559135-playing_dvds_from_other_regions
Jun 11, 2010 | Computers & Internet
My compaq laptop says i cant change the region
You only can change this setting 5 times, then it is locked. You can not change the Region code after this even if you reinstall Windows, or move the drive to another computer. You can try upgrading the Firmware for the drive from the Compaq / HP Support page for your product. If that does not work, you will need to replace the drive, or download and install a Region Free software like AnyDVD or DVD Region Killer.
Jan 09, 2010 | Compaq (158165-001) DVD Drive
Changing region code
you can change the region code with updates but its risky cos once you upload the update for the region code it may not let you play the other region coded games
Oct 01, 2009 | Sony PlayStation® 3 (60 GB) Console
Mac book pro is currently locked to region 1,
Home Index DVD Region Codes
In order for you to view a DVD's content, the region code on the DVD and the region code for DVD Player must be the same. Your DVD drive is automatically set to a region code the first time you play a coded DVD. If the region code for a DVD does not match the current region code for DVD Player, a dialog appears for you to change the code for DVD Player.
IMPORTANT: You can set the region code for DVD Player only five times (including the original setting). The fifth time you change the code, it will be permanently set. The following map and table indicate the code for the various regions. Some DVD discs can be played in any region, and are sometimes referred to as having region code 0. These discs can be played regardless of the region to which DVD Player is set.
Mar 30, 2009 | Apple Computers & Internet
Changing the DVD Region code
Legally, the only way to resolve your issue is a new drive, the region code in the drive has been locked in the firmware and cannot be changed by normal means (You can search google for DVD region Code Cracks, but it is not recommended no legal)
Antipiracy laws mandated a limit to the number of times the Region code can be changed (5) and if you are going to be playing a lot of media from different regions, then get another drive and set it to one region (and mark the region on the drive) and use this for the other
Jan 26, 2009 | Dell Inspiron 1300 Notebook
Changing the region code
You can only change the region code a few times (usually 5), so I wouldn't do it. You should leave the current player at region 1, and buy and install another DVD player and set it to region 4, then you will have 1 for each region you want.
Aug 15, 2008 | Samsung DVD-R155
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
Electro Med Services...
