Question about Carrier XHB153D Air Conditioner
Front panel image
I have had this unit for 10 years. My husband has lost the front panel with the knobs to control it. Do you happen to have a picture of the front controls so I know which way to turn it? I called carrier and have searched the web and can't find anything.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 24 Answers
Carrier will not tell the general public alot of information that only technicians can get, most panel knobs are always clockwise to increase speed of fan and either heating or cooling
Posted on Oct 22, 2013
bobotfel
  • 236 Answers
SOURCE: Unit/control panel completely dead
Check your circuit breaker, "off" and "on" the breaker it my be tripped off. If it wont work may be some fuse blown in the control, or the control itself may be defective.
Posted on Jan 28, 2008
tborn6
  • 700 Answers
SOURCE: my carrier air con is only blowing cold air and i need the hot
It sound like the heating sequecer maybe have gone bad on the fan coil unit that you have. You need to call the maintenance personnel that does the work where you live or a service company out to repair the unit because since y0u only rent it is their responsibility to provide youp with heat and if by chance that you have a heat pumo unit then you definately want them to get on the roof to fix the problem. Remember to always change oyur filter inside when ever you get your electric bill because even though it's theeir unit it's your electric!
Posted on Jan 05, 2009
crouchdash
  • 83 Answers
SOURCE: Plastic knobs (off/on and fan speed) are broken. Need replacement
Only accredited service contractors carry them. You need to contact them for price and availability.
I hope this helps.
Posted on Jul 06, 2009
SOURCE: Carrier furnace burner will not on with front panel close.
If i recall right this is a combo gas pack that sits outside, there are no air intake vents on the front panel,but there are intake vents on the side. Make sure they are not blocked also check to make sure when you put door back on that its not crimping any wires.
Posted on Jan 10, 2010
  • 534 Answers
SOURCE: I have a Carrier 42G150H indoor unit for a split
Look on the back of the panel where the green light is located. You will need to remove the bottom panel of the furnace and on the back of the panel you removed there should be a breakdown of the codes as to what the flashing green lights mean. If the code list isn't there you should be able to obtain the code list online if not try to call a a/c company to see if they have a code list .
Good luck hope this helped you
Dave
Posted on Feb 25, 2010
How do I clean coffee from climate directional buttons?
i would recommend you remove the unit. Two of the control knobs are removable the rest must be accessed by removing the unit then the front panel of the unit SubaruWRX image
May 11, 2015 | 1997 Subaru Outback
How to install a center console on a pacifica
Hi Melissa, I'm glad to help, here is the instruction below I said I'd send. Have an awesome day.
23 - Body/Interior/CONSOLE, Floor, Front/Removal REMOVAL [img id=LOPTableImg src="https://w05.dealerconnect.chrysler.com/service/mds2002/common/images/collapse.gif"> Click to display a list of Labor Operations associated with this procedure 1. Remove shift bezel. (Refer to 23 - Body/Interior/BEZEL, Shifter - Removal) .
2. Remove transmission range indicator surround bezel Figure 1.
3. Remove two screws attaching front floor console to the lower instrument panel Figure 2. 4. Open cup holder and remove two attaching screws to bottom of cup holder. 5. Open bin and remove two attaching screws to bottom of bin. 6. Remove front floor console sidewall attaching screws, three per side. 7. Raise front floor console and disconnect wiring harness. 8. Remove front floor console from vehicle.
374297.jpg Figure 1 - TRANSMISSION RANGE INDICATOR SURROUND BEZEL 1 - INSTRUMENT PANEL 2 - AUTOSTICK SHIFTER ASSEMBLY 3 - TRACTION CONTROL SWITCH 4 - TRANSMISSION RANGE INDICTOR SURROUND BEZEL 5 - KNOB SET SCREW 6 - SHIFTER KNOB 7 - FLOOR SHIFT BEZEL 8 - WIRE CONNECTOR 9 - INSTRUMENT PANEL WIRING HARNESS 10 - INSTRUMENT PANEL WIRING CLIP
374299.jpg Figure 2 - FRONT FLOOR CONSOLE 1 - FORWARD CONSOLE CLOSEOUT PANEL 2 - CLOSEOUT PANEL PUSH PIN RETAINER 3 - INSTRUMENT PANEL WIRING 4 - FLOOR CONSOLE BASE 5 - FRONT FLOOR CONSOLE ATTACHING SCREWS TO LOWER INSTRUMENT PANE AND BASE 6 - FRONT FLOOR CONSOLE WIRING CONNECTOR 7 - FRONT FLOOR CONSOLE 8 - ATTACHING L-BRACKETS
May 17, 2014 | 2006 Chrysler Pacifica
My LTE5243D top load stacked washer is about 10 years old. How do you take the front panel off to access the washer's motor coupling?
To gain access to the washer components, the front panel between washer and dryer must be removed first.
Remove the two top screws securing thethis panel to the unit.Tilt the transition panel down and pull itstraight out.Remove the two screws located behind the washer top.Pull the washer top forward to disengage the top locks. Disconnect the washer lid switch harness. Lift the washer top off the unit.Remove the two screws from inside the top of the washer front panel.Lift up on the front panel to release the catches near the bottom of the panel andremove the front panel.
Apr 24, 2012 | Whirlpool LTE5243D Top Load Stacked...
Yamaha RX-V1000 volume control erratic, remote doesn't work. All was well then the volume control knob became erratic (volume would change erratically as knob was turned in either direction, remain...
sounds like you need to take it in to have it looked at. no simple fix unless you are an appliance technician. hard to walk a beginner through. i suggest calling an stereo repair guy.
Fix Ya
FixYa Support
Please accept solution and rate 4 thumbs up! Thanks for your feedback!
Aug 21, 2011 | Yamaha RX-V1000 Receiver
Have TDS320 SCOPE that powers on ok , but no panel control func.
Are any knobs in manual position? Rotate all knobs full clockwise / counter-clockwise and lock in place.
Sep 29, 2009 | X-10 PROB60 60M Hz Oscilloscope Probe...
I need no color code for 2006 ford taurus
+12V DC Battery(Constant) Red/yellow - Control unit in left side of luggage compartment 17 20 amp Junction box in front center of engine compt.
Switched Accessory Red/orange - In-line with the starter relay 27 5 amp Junction box in front center of engine compt.
Ground Black/lt.green
Remote Turn On(output) Brown/orange Pin 8 of CD changer. Also light green/black between rear control unit (C388B-2) and front panel (pin 4).
Illumination See notes *
Left Front + Orange/lt.green
Left Front - Lt.blue/white
Right Front + White/lt.green
Right Front - Dk.green/orange
Left Rear + Grey/lt.blue
Left Rear - Tan/yellow
Right Rear + Orange/red
Right Rear - Brown/pink
Notes
Information listed in the harness section refers (in this case) to the rear control unit in left side of the luggage compartment.
* Illumination is controlled from the integrated control panel, thru dark blue/white at pin 2.
INTEGRATED CONTROL PANEL has white/red for battery input (pin 11), with fuse no. 33 of 15 amps in the junction box under left side of dash; black/pink for acc. power (pin 6), with fuse 22 of 15 amps in the junction box under left side of dash; red/yellow for hot in start or run (pins 5 & 16), with fuse no. 32 of 10 amps in the same location.
AUDIO connections between the integrated control panel (front) and the rear control unit (rear) are as follows:
R+ dark blue/white wire between pin 9 of front unit & pin C388B-7 of rear unit;
R- gray wire between pin 19 of front unit & pin C388B-20 of rear unit;
L+ brown/light green wire between pin 20 of front unit & pin C388B-6 of rear unit;
L- white/pink wire between pin 10 of front unit & pin C388B-19 of rear unit.
AUDIOPHILE SYSTEM has right and left tweeter speakers branching to right and left front speakers with the same colors.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 12, 2009 | Car Audio & Video
I have an older unit need to know what the top knob does
One of the knobs controls fan speeds, cooling speeds and an off position. Center knob controls temperature and bottom knob more than likely controls air exchange. As for the front cover it would depend on the units age as to if it would be available.
Jul 05, 2008 | Fedders AEQ07FBG Air Conditioner
How to remove the washer cycle selection/start-stop knob on a Whilpool Heavy Duty Thin Twin stacked washer dryer
I believe the selector knob on a Whirpool just has to be turned counter-clockwise with the selector pushed in. It will spin off the shaft and then the outer indicator dial will pull off. The shaft also has a keyed slot that will only allow the dial to be removed and installed one way, so there should be no question as to how it goes back on.
Was there a reason as to why you are removing the washer selector knob? If this is a simple matter of replacing a broken water temperature selector, you shouldn't have to remove any of the control knobs to gain access to the selector. The entire front panel comes off by removing the screws holding it in place. That way you can access the broken selector from behind the front panel much easier. Just remove the panel right above the washer top (under the dryer) and it should expose the front panel mounting screws. Remove these screws and the front panel comes off. Just make sure the unit is unplugged before you begin. I hope this helps you. Let me know if you need further assistance.
Apr 22, 2008 | Whirlpool LTE6234D Top Load Stacked...
Carrier XHB153D Air Conditioner Logo
59 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
