Question about Kenmore 77554 / 77543 Bottom Freezer French Door Refrigerator
The upper door gaskets on my 795.75193401 French door fridge have torn where they meet in the middle. I have replaced one of the gaskets before, but it looks like they have added an additional part to the inner edge of the gasket where the doors meet. The last time that I purchased a gasket, it was a single part. Are both parts needed for both doors?
fridgetech
  • 473 Answers
SOURCE: door not sealing
After putting a new gasket on you will usually need to form it. You can use a hair dryer to heat the gasket and flat screw driver to form it.
Posted on Nov 07, 2007
  • 1779 Answers
SOURCE: door gasket for Kenmore upright freezer model 2539239712
Go to sears parts direct website. It's part #3206261 and is in stock, $93.07. Good Luck! countrycurt0
Posted on Aug 08, 2008
  • 61 Answers
SOURCE: Kenmore Elite HE3t door leaking (Model 44936)??
If the unit leaks during use with a constant drip from the 6 o'clock location between the seal and the glass on the door the solution is to change tha door seal. it is quite difficult to do I would recommend you call a local service company.
Posted on Dec 18, 2008
  • 71 Answers
SOURCE: Side side door noise(fridge side door)
you need the lower hinge and cam kit. remeve the top hinge then lift the door off the hinge and replace the hinge and the cam on the door.
Posted on Dec 19, 2008
  • 2976 Answers
SOURCE: My front loading Kenmore H2 has a torn gasket.
You will have to take the door apart to get the gasket mounted properly. Although not required, a second pair of hands really helps.
Posted on Mar 20, 2009
The fridge door won't close all the way , is there an adjustment on the hinges
Check the bottom fridge door hinge. There should be two plastic cams, one that mounts to the door and one that mounts to the hinge. From your discription it sounds as if thoes cams have broke and need to be replaced
Sep 01, 2011 | Maytag MZD2766GES Side by Side...
The gasket on the right hand French door is slightly torn, so I bought a replacement gasket. It's arrived, but I have no clue how to replace the gasket.
The gasket is easy to replace. Remove bins and shelves set them aside. Next at the top right hand corner remove the door trim cover pull it straight out and set it aside. Note the tabs on the inside of the trim are fragile. Peel back the gasket at the top forward edge and bottom frward edge and you will locate a hinge. Use a small screw driver to pop these hinges out. Pull out the gasket on that side first and the whole seal comes on out of there. The hinge slides out of the old seal. Just snap yer new back in. Do on door at a time. The trim pieces for each door are different. Snap your door trim back and check for propah opening and closing of door. Then party on!
LG french door service manual
Aug 13, 2011 | Refrigerators
How do I repair the gasket on my LG refrigerator door?
Both door gaskets are torn at the top, doors not closing. Where can I get new gaskets? How do I install them?
Thanks
Apr 11, 2010 | LG LRFC25750 Refrigerator French Door
When I shut the left door the right door pops open, it is always open.... I need it to stay shut
put some heavy stuff on the door like soda or water bottles,also wash around the frame where the door gasket touches the fridge and wash the gasket too, there are magnets inside the gasket and if there's anything on the frame it could stop the gasket from making a good seal,how old is the fridge?what shape is the gasket in?if it's torn or lost it's shape it should be replaced.most likely you might just have to get some weight on the door to stop it from popping open
Mar 07, 2010 | Maytag MFD2561HE Bottom Freezer French...
Gasket on Rght side of French Door Fridge
well I suggest you and your neighbor both call Jenn Air as they now have 2 known complaints and perhaps more if others read this and check theirs as well
Jan 28, 2010 | Jenn-Air Pro-Style JFC2089H French Door...
I have a kenmore 795,7730 22.4cu ft french door
the little switch that is activated by door not working,it may be sticky from a spill, check it, it should be where door meets fridge, hinged side. plz rate -bozcro
Sep 16, 2009 | Refrigerators
Is it worth replacing a door gasket on a 25 year old freezer. It is a Kenmore 6. Upright. It does not seal tight anymore.
Is the door gasket torn?? if not try cleaning the rubber surface that makes contact with the metal portion of the fridge and clean the metal area also, because inside the rubber gasket is a magnet that helps the gasket seal properly.I've seen door gaskets range in price from $50.00-$100.00 so if thats the only problem it sure beats buying a new fridge for a whole lot more money.
Aug 25, 2009 | Freezers
I have condensation dripping right behind where the french doors meet on the ceiling of fridge, how can i solve this problem?
Possible that your door gasket is not sealing very well and therefore condensation forms in this area?
Jul 02, 2009 | LG LFC20760ST Stainless Steel Bottom...
Kenmore 77554 / 77543 Bottom Freezer French Door Refrigerator Logo
35 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
