Question about eye-vac Professional Bagless Vacuum Cleaner
EyeVac Pro won't stop running. How do I clean the sensors? or is that the problem?
Light won't turn on Shark steam mop
I posted this video explaining how to clean the heater core of the S3501...it is likely a similar design as the Euro Pro.
http://youtu.be/S4NglGXVv50
Dec 09, 2012 | Euro-Pro Shark Steam Mop - Gray/ Purple...
I have a bissell pro heat 2x +and the water is not coming out of the hand tool or the carpet cleanerr
We are sorry about the issues you've run into.
This link gives detailed troubleshooting instructions for you: http://www.bissell.com/FAQDetail.aspx?id=1122&icid=ccrr
And this video shows easy maintenance items: http://www.bissell.com/how-to-videos/proheat-2x-machine/care/?icid=ccrr
If your machine continues to not spray, please take it to a BISSELL Authorized Service Center for warranty repairs. If you are experiencing difficulties other than no spray, the technician will let you know the cost for those repairs if your machine is outside of the one year warranty timeframe. You can locate a BISSELL Authorized Service Center at this link: http://www.bissell.com/service-centers/?zip=Enter%20your%20zip%20code&distance=50&icid=ccrr
One pointer that can help between uses is running water through the lines. First, put clean water in both tanks and set your unit to the heavy traffic setting for one pass. This will flush out any cleaning formula in the lines so your spray tips won't get build-up between uses, which can lead to a lack of dispensing the cleaning formula.
Jun 27, 2012 | Bissell 9500 ProHeat 2X CleanShot Upright...
My iRobot Roomba runs for about ten minutes, then shuts off. I can keep pushing the clean button and it will run for another ten minutes and stop again. Nothing seems to get clean.
Take the brush rolls out and you should see a copper disc. It is the dirt sensor. Clean it with Windex or some other cleaner. This works sometimes.
Sep 08, 2010 | iRobot Roomba 550 Vacuum
The shark mop just stopped working mid clean. The
It broke....
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Sep 25, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Stopped steaming only releases water into pad
heatman101
ag
Mar 22, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Roomba stops running after 2 minutes
First drain the battery completely and then take out battery and charger and hold power button for 30 seconds and then clean the roomba with compressed air take out all compartments and blow air thoroughly everywhere especially near the wheels where the wheel sensors are. Leave battery to charge for full day and try to run.
Jan 31, 2009 | Roomba Robotic Floor Bagless Vacuum
Roomba Pro Elite
The electronics have failed most likely. Not uncommon. If it is within the warranty period call the company ( good luck with that ) and they will send you a new one. These machines are not designed to be repaired other than brush replacement and filters, dust containers, etc.
Jun 11, 2017 | Roomba Pro Elite Bagless Robotic Vacuum
Program not working
i had the same problem. there are 2 little metal discs that are sensors. have you tried cleaning then? you need to remove the brush and roller and they are right there. very sensitive. i used windex on a rag ,put it together and it has worked ever since
Feb 23, 2008 | Roomba Pro Elite Bagless Robotic Vacuum
eye-vac Professional Bagless Vacuum Cleaner Logo
69 people viewed this question
Top eye-vac Vacuums Experts
JoeVacs
Are you an eye-vac Vacuum Expert? Answer questions, earn points and help others
