Question about Symbol LS3578-FZ Barcode Scanner - P/N LS3578-FZBR0100UR Barcode Scanner
Symbol barcode scanner ls3578-fz wont work in windows 7
  • 25 Answers
SOURCE: Barcode scanner scans and beeps, but will not put the numbers in the computer
There is more than one way for that imager to send data to the computer. Are you using USB, serial, or is there a little box that goes between your existing keyboard and the PC that accepts the scanner connector?
Posted on Jan 05, 2008
  • 25 Answers
SOURCE: Symbol LS 4278 Barcode Scanner - 3 Clicks
Does it beep each time you pull the trigger while the beem is on the barcode?
Posted on Jan 23, 2008
  • 31 Answers
SOURCE: Windows Mobile Symbol Find WLAN error
Warm boot the MC55 if that doesn't help then cold boot it, if that doesn't help then reload the Operating system, if that doesn't fix it then send it back to Motorola for a warranty repair.
Posted on Jun 30, 2009
  • 31 Answers
SOURCE: Symblo Scanner not pairing with Base
If the bar codes are in good shape and can be read by other scanners then your scanner probably needs to go to repair. You try to reboot the scanner by pressing FUNC then *
If you need the scanner repaired let me know and I can repair it for you.
SOURCE: I need to turn off the beep on the Symbol MC9090 w...
Create a registry setting, putting volume to 0 will (almost) get of the sound ....
[HKEY_CURRENT_USER\Software\Symbol\SymbolPB]
"DecodeVolume"=2
"DecodeFrequency"=00FF
"InvalidDecodeFrequency"=0FFF
"DecodeDuration"=850
Posted on Jun 22, 2010
Programming ls3408-fz
We recommend you contact Motorola Solutions
http://www.motorolasolutions.com/support
Mark
Motorola Support
Jan 29, 2014 | Symbol LS3408 Barcode Scanner
How do i program the natural return or 'enter'
123Scan2 is an easy-to-use, PC-based software tool that enables the quick and easy set up of Motorola scanners.
Oct 31, 2013 | Zebra Symbol LS3578-FZ Barcode Scanner -...
Hi, how do i downgrade the firmware for LS3578? Thanks
The Symbol LS3578-ER has a "single flow" frimware system. Meaning you can inly upgrade.
You may be able to contact symbol and they will create a special file for you.
Mar 14, 2011 | Symbol LS3578-ER Wireless Handheld Barcode...
My symbol barcode scanner beeps 4 time while I try to scan. The Manual states that the battery is bad. I replaced the battery & it does the same thing.
This 4 beeps also stays for communication error. Please check the connection to the cradle and also the connection between the cradle and PC.
You can start by pairing the scanner with cradle with the Pairing barcode, then defaulting the scanner to the standard settings - use the barcode "Set All Defaults" from the manual. Then select the right host type USB, RS232 or another.
After this procedure should the scanner work.
Sep 07, 2010 | Symbol LS3578-ER Rugged Barcode Scanner
WILL NOT READ 2D BARCODES
That is correct this LASER scanner does not read 2D barcodes. It contains a long range 1D laser engine.
Light source: 650 nm visible laser diode
Datasheet can be found:-
http://www.motorola.com/staticfiles/Business/Products/Bar%20Code%20Scanning/Bar%20Code%20Scanners/Rugged%20Scanners/LS3578-ER/_Documents/Static%20Files/LS3578ER_SS_1208.pdf
If you want to read 2D barcodes you would require an imager. For long range try the Intermec SR61 it contains an EX25 imager.
If you need any more help then please do not hesitate to contact us:-
http://www.biastechnology.com/
or TEL 01202 620955
Dec 01, 2009 | Symbol MOTOROLA LS3578-ER EXTENDED RANGE...
How to add CR to ls3578
To set the scanner to do a CR you will need to scan the following barcodes:
Scan Options.
<DATA><SUFFIX>
ENTER
You will be able to find them on the product reference guide.
Me aware that if this is a wireless scanner, you may need to scan the barcode that says Send Configuration to Cradle.
I hope this helps.
Get back to me it you still need more help.
Mar 27, 2009 | Symbol LS3578-ER Rugged Barcode Scanner
Where is my barcode after I scan it?
Is the cradle connected to the pc via either usb, serial or keyboard wedge?
If so you will need to first, pair the scanner with the cradle by scanning the barcode on the cradle and second, configure the cradle properly so it transmits the data to the host.
Download the product reference guide from motorola website. You will get all the configuration information you need in there.
Mar 20, 2009 | Symbol LS3578-FZ Barcode Scanner - P/N...
Symbol LS3578-FZ Barcode Scanner - P/N LS3578-FZBR0100UR Barcode Scanner Logo
61 people viewed this question
Top Symbol Computers & Internet Experts
Michael
Oloyede Monsuru
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
