Question about John Deere Seat For F710 F725 F735 Riding Mower
F725- sometimes I get ruff running-found week spark one cylinder-ckecked ohms on spark wire,coils-swaped coils(OK)-still low spark.The book said to ing.module is next-there is no test for module but replacement ($280.00)-replaced plugs
  • Bob White
    Bob White Oct 22, 2013
    All ansewers I get seem to talk about NO SPARK,Ihave spark but it isWEEK
    Novelist:
  • 212 Answers
They aren't cheap that's for sure. Have you tried taking the part number and doing a google search? You may be amazed at some aftermarket prices. Do you have part number, I can check too.
Posted on Oct 26, 2013
SOURCE: JD mower-only one coil firing
I just switched the coils around. The other cylinder went dead, so I knew I had a bad coil. Replaced the coil and mower runs great.
Posted on May 15, 2009
VinayT
  • 1884 Answers
SOURCE: My lawn tractor won't start
May be the coil is bad. have you checked the spark plug? If there is gas and spark then it will have to start.check the circuit breaker points. is there current in the cb points?
Posted on Sep 11, 2009
  • 100 Answers
SOURCE: 14 hp kawi fc420 as10
Have you checked stop wire or kill switch? disconnect stop switch see if you have spark then...
Posted on Aug 19, 2010
2strokeguy
  • 183 Answers
SOURCE: Kawasaki 9hp mower engine. Replaced the coil and
OK, lets back up. How are you testing for spark? Do you have an inline spark tester? If not, go get one from your local auto supply house ($10) and come back. You back?
On the ignition module, set the gap to the flywheel using the thickness of a clean business card. Make sure the module is on "right side" up...one side of the module should say "cylinder". Disconnect the kill wire from the spade connector on the module. Reassemble enough to spin the motor at least 250 rpms and check for spark with your inline spark tester. Spark? If no, then you either have a bad module (likely) or a bad flywheel (rare). If yes, reconnect the kill wire and retest. Spark? If no, trace the wire back to the switch. The switch will have a cable that activates the switch and connects to the upper handle. If the cable is binding or has stretched, it will not move the switch far enough to activate. If the cable is moving less than 1/2 inch, then it is damaged and must be replaced. If the switch is moving enough, trace the wire from the switch to the module and look for open/exposed spots in the wire that may be grounding out against the engine or frame.
Good luck.
Posted on Oct 13, 2010
  • 24 Answers
SOURCE: John Deere L 130 no
With a manual
Posted on Sep 14, 2011
One cylinder keeps cutting out and in and it is not the spark plug.
is this question about a two cylinder saw ? if so its an oldie but I like em !! seems that two cylinder 2 strokes can develop points issues that fire the coil twice on one cylinder only (sometimes saw will run , with little power) , ck points time, this assumes of course that you've got a single coil with two wires exiting it , dual coil saw? id ck the coil that doesn't fire with a ohm meter
Jul 23, 2015 | Garden
How to troubleshoot no spark
If fuel injectors are putting fuel into cylinders, then crankshaft position sensor is o/k as this sensor is used both for ignition timing and fuel injector timing. I would check for 12 volts at the middle pin of the connector on coil plug. If present, then ECM is more than likely at fault. You should have a low ohm reading between the center pin and either of the outer pins. As this is a single fire coil, both sides are unlikely to fail at the same time so this again points to the ECM or a common item, i.e. 12 volts supply to the coil.
By the way, spark plugs will not fire if engine is turned over with no plugs fitted in engine. These engines need to see compression for spark to happen. So to check spark, leave plugs in engine and fit a new one on lead and rest it on engine while operating starter motor.
Apr 07, 2015 | 2005 Harley Davidson FLHTC - FLHTCI...
95 toyota t100 3.4L extended cab check engine light
Hello, this engine has 3 ignition coils on the passenger side cylinder head, each coil fires two spark plugs, the spark plugs on thew other side have plug wires connected to one of the coils on the other side, the #6 cylinder wire connects to the #3 coil, try replacing the spark plug wires
Jun 10, 2017 | 1995 Toyota T100 Xtracab
1993 Ducati M900. On cold start up low power. Feels like dropped cylinder. After a few minutes returns to normal. My thoughts, one of the coils. Spark plugs appear ok.
if the plugs look ok and don't indicate a fuel mixture problem, it could be from a weak spark. You can check the resitance on your coil and plug wires with an ohm meter to see if they are within factory specs. Also, check for a possible vacuum leak around the carb & cylinder head on the cylinder that is missfiring. You can do this with some carb cleaner, spray it around the carb mount and vacuum lines---if the RPM's change it sucked some in. Hope this helps.
Jul 12, 2011 | 1993 Ducati Monster 900
I have a 2000 model hyundai lantra sportswagon, that is currently running on 3 cylinders only, very ruff idle and under powered, the spark plugs are ok and there seems to be adaquate power going to each,...
will let we look at simple one first---- you said you getting spark at the spark plug lead , ok , the plug is good ---- check the injector plug -- take it out and see if it have rust or dirth stuff on the injector pins --- if yes clean it ----if not , the injector might me bad . to know what you can inter change the injector and see what happens . reply. if alot of work to to change the injector see one to buy and the cost , which is the best
Aug 13, 2010 | 2000 Hyundai Elantra
Nissan 300zx 5th cylinder died
do you have coil over plug or one coil? if you have spark plug wires, swap one with the cylinder in question. swap an injector.
Mar 01, 2010 | 1990 Nissan 300ZX
1999 Land Rover Discovery II engine miss
Observe the engine running in the dark to see if there are any spark jumps from the wires or coil, you may have a carbon track.....
Feb 16, 2010 | 2001 Land Rover Discovery Series II
Apr 01, 2009 | John Deere 420,1020,2010,2020,2510,2520...
John Deere Seat For  F710 F725 F735 Riding Mower Logo
115 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
