Question about Garden
I was mowing and the engine stopped like you turned the key off. Now it will not start. It blows the fuse when the key is turned on.
    Sergeant:
    Champion:
  • 320 Answers
Hello Donald
My name is George. I am a repair technician at a local shop here in N.C. The simplest answer to your problem is that you have a short in the wiring. The hardest part is finding it. It is common for us in the shop to find loose connections and wires that are cut or pinched. I hope this will help you get started.
George
Posted on Oct 22, 2013
4 Suggested Answers
SOURCE: LTX1000 42" 18HP Kohler - Blowing fuse after 2-4 min mowing.
i hav a 18hp ohv eng. back fires and gas is coming out of muffler.
Posted on Jul 18, 2009
  • 138 Answers
SOURCE: Blown fuses when mowing
you have a wire that is shorting out somewhere, i would trace the wires from the clutch all the way back to the fuse including the relay and pto switch. You will more than likely find your problem in the control circuit between the fuse, pto switch and relay since this is what is fuse protected.
Posted on Sep 07, 2009
  • 146 Answers
SOURCE: Cub Cadet 1861 amp light comes on when the PTO is
Sounds like you have a short circuit, either in the PTO clutch, or in the wiring that goes to it. Inspect the wiring for any obvious spots where insulation has rubbed off or burned. Also look at the wiring at the back of the PTO engagement switch for these signs. Before buying an expensive PTO clutch, unplug its connector. Drive around with the PTO switch on (even though the PTO won't activate and the blades won't be engaged). If the fuse doesn't blow, the problem must be within the PTO clutch. If the fuse still blows, it must be in the PTO switch or the wiring from there to the clutch. Use an ohmmeter to trace and find the short. Good luck!
Posted on Jul 09, 2010
Having trouble with the fuse blowing...what could cause this?
need to look at wire harness and such start from battery forward or from switch to solenoid and look for debris /chaffed or loose broken wire but check starter may be hanging up and blowing fuse
Aug 01, 2016 | Garden
Mowing then deck stopped try to start 20amp fuse blows?
Hi Duane:
Sounds like there is too much load on the circuit.
Possible causes:
1) Grass jammed under deck stopping blade from turning. Unplug and clean.
2) Voltage drop due to too much electrical resistance. Is there any chance you are using a really long light-weight extension cord?
Cheerfuls.
Nov 26, 2015 | Garden
I was mowing with a timecutter 4200 the blades stopped and won't restart what do i do
check fuses and then start testing the wiring and clutch
Sep 12, 2014 | Garden
Simplicity Prestige tractor low oil pressure light is on and engine won't start
I have a 2006 simplicity it runs amazing and lows great however when I'm mowing an hour or so into mowing oil pressure comes across the digital screen on dashboard and then it just dies stops running after a minute or two it starts right back up and will do it as gain and again. Amy advice on everyone's experience or knowledge would be appreciated thank you
Jul 04, 2012 | Garden
20 amp fuse keeps blowing engine won't start, fuse
I am a mechanic,i had that same problem where my engine 20amp fuse were blowing....i fixed it...problem were a broken wire in the harnace on the side of the cylinder head....i made over $200 on that job...yahhh
Aug 01, 2011 | 2001 Mitsubishi Galant
My 1982 gs550 L will start fine but when it turns off the main fuse will blow every single time!
If you don't start the bike....just turn it on and off...does the fuse blow...or only if engine starts and stops?
If not starting engine still blows fuse, and it only blows shutting key off...I would inspect ignition switch for a short.
Mar 14, 2011 | 1982 Suzuki Gs 550 L
98 Ford F150 4.2 Liter Engine will not crank keeps blowing fuse #21 (15amp) as soon as I turn the ignition key. Was running fine just stopped to gas up and it wouldn't crank. Jumped the posts on the...
Sounds like there's a grounded wire somewhere between the ignition switch and the solenoid. When you bypass the switch with the screwdriver you don't ground out the line, but with the switch the ground shorts the circuit, blows the fuse, and then won't start the engine.
Apr 18, 2010 | 1998 Ford F150 Regular Cab
Blowing number 19 fuse in the dashboard fuse panel, car stops, constantley blowing, book says number 19 controls coil and pcm.??? any ideas that might cause the problem, engine stops but all other...
you have a dead short in the starting cicuit first thing is check any where you have had any other work done that might have pinched a wire.
Aug 14, 2009 | 1997 Ford Explorer AWD
Fuse blew, replaced with new, and now electric clutch will not work
sounds like you probably need a new clutch. they short out internally and blows the fuse
May 03, 2009 | Garden
Garden Logo
32 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
