Question about Microsoft Office Standard for PC
Vb 6.0 and access conictivity
When we add a record previous record get deleted automatically
  • suju Sep 28, 2007
    hhhhhhhhhhhh
    Scholar:
  • 160 Answers
For solving this problem do the following
1. See that the database is in Dynaset or View
2. See that you had written the refresh inthe add new button
Let me know if your problem is solved and rate me as FIXYA!
Posted on May 14, 2008
SOURCE:
How do I retrieve recorded messages from an outside phone?
You can access the answering system remotely by dialing your home telephone number from any touch-tone telephone. To remotely access the answering system
Dial your telephone number from any touch-tone telephone. When the answering system answers, enter the two-digit remote access code (19, unless you have changed it). The answering system automatically announces the number of messages (new or old) if there are any. If there are new messages, the answering system automatically begins to play new messages only. -OR If there are no new messages, the answering system automatically begins to play all old messages. You can also enter the remote commands: Play all messages
1 Press to listen to all messages. If there are new messages, the system plays back only the new messages (oldest first). If there are no new messages, the system plays back all old messages (oldest first). Play new messages
2 Press to listen to new messages only. Delete a message 3 Press during message playback to delete the current message. Delete all old messages
3 Press to delete all old messages. Replay current message or previous message
4 To repeat the message currently playing, press 4 after the answering system plays the day and time the current message was received. To listen to the previous message, press 4 while the answering system is playing the day and time the current message was received. Stop
5 Press to stop playback and recording. Play help menu * 5 Press to listen to a list of remote commands. Skip to next message
6 Press during playback to skip the current message and advance to the next message. Record a announcement
7 Press to record a new announcement. Begin speaking after the long beep. Turn system on or off 0 Press to turn the answering system on or off. Exit
8 or hang up Press to end remote access (the call is terminated). 1. 2. 3. 4.5
0 Answering system Remote access Hang up to end the call and save all messages.
NOTES: If you do not enter a valid remote access code, the system answers the call automatically. If the date and time is not set when a message is recorded, the system announces, "Time and date not set" before the answering system announces the number of messages. If there are no messages in the answering system, the system announces, "You have no message." If there are no new messages in the answering system, when you press 2 to play back new messages, the system announces, "You have no new message." If you pause for more than four seconds during remote access, you hear a help menu listing all features and commands. If there is no command for another 20 seconds, the call ends automatically. If the memory is full, the answering system answers after 10 rings and announces, "Memory is full. Enter the remote access code." Enter your remote access code to access the messages and announcements. When the answering system is turned off, the telephone answers after 10 rings and announces, "Please enter your remote access code."
Mar 13, 2015 | Uniden DECT 6.0 Cordless Phone ID
Can I check my messages from a phone outside my home, is it possible to make a remote enquiry? And if so, how does it work?Thanks in advance for your answer. Regards, Joy
Remote Message Retrieval
You can operate your answering system from a remote location using any touch-tone
telephone or the handset.
Remote access away from home
You can check, play, or delete messages, even record a new greeting message when
you are away from home. Additionally, you can turn On or Off your answering system
from a remote location.
Remote access:
1) Call your telephone number and wait for the system to answer. If the answering
system is off, it will answer after about 10 rings and sounds a series of beeps.
2) During the greeting message (or a series of beeps when the answering system is off),
press 0 and enter your PIN code within 2 seconds (see "Setting a PIN Code" in your owners manual.
3) The answering system announces the current time and the number of messages stored
in memory. You hear "To play incoming messages, press zero-two. For help, press onezero".
You will hear a beep.
4) Enter a command within 15 seconds, each command there after must be entered
within 2 seconds. You may select a command from the following chart:
For your convenience
a remote operation
card is provided for
you to use while
away from home, it can be found in the back of your owners manual.
Command Function
0 then 6 Answering System On
0 then 7 Memo Record/Stop **
0 then 8 Greeting Message Record/Stop **
0 then 9 Answer System Off
1 then 0 Help Guidance
Command Function
0 then 1 Repeat a Message*
0 then 2 Playing incoming Messages
0 then 3 Skipping a Message
0 then 4 Deleting a Message
0 then 5 Stop Operation
* For Repeat a Message function, press 0 then 1 within about four seconds to
repeat the previous message, or press 0 then 1 after about four seconds to repeat
** For Memo Record and Greeting Message Record function, the first time you enter
the corresponding command, it starts the Recording function. If you want to stop
the recording, press 0 then 7 or 8.
5) After the command has finished, you hear intermittent beeps indicating that the
system is in the command waiting mode. You may enter another command at this
time from the chart above.
6) When you are finished, hang up to exit the system. The answering system
automatically returns to standby.
Your machine automatically has a PIN set of 80.
If you are trying to use remote access from a cellular phone and having trouble: Try changing your tone length on your cell phone to long.
May 25, 2011 | Uniden Cordless Phone
How can I save my recorded track in CASIO CTK 810 IN for future use. I can record one performance but cannot save it for ever, if I record another one track the previous one is got deleted. Is there any...
Recording a new tune automatically deletes the previous one.
Solution transfer the recorded song to your computer via USB cable.
It is also possible to store up to 5 additional tunes in the song bank
See page E50 and appendix 9 of the user manual available here. http://support.casio.com/pdf/008/ctk_810_01_e.pdf
Feb 22, 2011 | Casio CTK810 61 Key Keyboard
I wish to create my own message on the answer-phone.
The easiest way to gain access into an answering machine is to use it's preset access code. This is the access code set at default by the vendor on the given device. The best thing about this is that most users don't bother to change the access code to their device, if they even know that they have such a feature. Even worse yet, some of the manuals given for the device by it's vendor even tells the user that changing the access code is optional, not necessary. So of course since most people only do what they feel is necessary, these access codes are many times if not usually set at default. So what I'm going to do for you now is list the different popular vendors out there, and include their preset access codes, how to use them, and controls to use after gaining access. Keep in mind that if there is no model number beside the vendor, then that means that the information given works on most of their models. Likewise of course if there is a model identification beside the vendor name (placed in parenthesis) then that of course means that the information provided is model dependant. So let's begin, shall we?
1) AT&T - preset access code is 10 - when the answering machine picks up punch in the access code
7 - play messages
6 - play new messages
# - stop/pause
2 - repeat message
5 - skip message
4* - record announcement (push # to end recording)
41 - play announcement
* - record memo
33 - delete all messages
3 - delete selected
0 - turn system on
88 - turn system off
99 - change remote code
2) BellSouth - preset access code is 555, Mailbox 1: 555, 2: 666, 3: 777, 4: 888 - when the machine picks up hit * and then punch in the access code
0 - help (use this to get the commands available)
3) Freestyle - preset access code is 000 - when the machine picks up push in the D button and then punch in the access code
2 - play all messages
3 - play new messages
4 - skip back during messages
5 - delete during messages
6 - skip forward during messages
8 - play outgoing message
9 - record new outgoing message
0 - set answering machine on/off
1 - hear main menu
4) Vtech (VT650) - preset access code is 0000 - enter access code during announcement
#4 - repeat message
#5 - pause message
#6 - skip to next message
#7 - delete message
#8 - skip backwards
#9 - stop/exit any function
*8 - room monitor
5) Vtech (VT2650/VT2468) - preset access code is 50 - enter access code during announcement
#4 - repeat message
#6 - skips message
#5 - stops
#9 - delete message
#7 - review announcement (after beep press 7 to record an announcement and use #5 to stop)
6) Vtech (HK5886) - preset access code is 48 - enter access code during announcement
#1,2,3 - play new or old messages
#4 - repeat message
#6 - skip message
#5 - stop
#9 - delete message
7) Olympia (OL2410) - preset access code is 0000 - enter access code during accouncement
1,2,3 - select and play messages
4 - repeat message
44 - ignore message
6 - play next message
7 - delete current message
8 - record memo
9 - record announce (5 to stop)
0 - toggle answer on/off
* - play help menu
8) Doro - preset access code is 321 - enter access code right after outgoing message has played (or during)
1 - repeat/skip to previous message
2 - play/pause message
3 - skip to next message
4 - play current outgoing message
5 - record new outgoing message
6 - stop
7 - erase current message
8 - switch off answering machine
9 - switch on answering machine/select outgoing message
0 - (after playback) erases all messages
# - end playback
## - end call
9) Virgin Pulse cordless phone - preset access code is 123 - enter access code during outgoing message
1 - review current message
2 - skip to next message
3 - erase the current message
4 - play all or new messages
7 - repeat voice menu
0 - turn on/off TAD
10) Panasonic - preset access code is 11 or 1111 - enter access code during outgoing message
4 - new message playback
5 - all message playback
1 - repeat
2 - skip
9 - stop
7 - record new announcement (use 9 to end recording)
There are also a few random vendors that don't automatically preset an access code on the machine, forcing it's user to set one up him/herself. This is a small step forward as far as security is concerned, but every vendor I saw that did this still used a mere 2-digit access code. To test and see if your target has this type of setup press # when the machine start, and then press 0. If the machine returns to the annoucement then you know this is the kind of machine it is. Of course, in reality, this isn't all that bad of a scheme since you have 100 different combinations available for the access code. However, most users simply set these access codes as 11, 22, 69, etc. So yeah, just try it out. If it disconnects you after so many tries, call back from another payphone (which you should be using in this case).
Thanks for contacting Fixya
Jun 17, 2009 | Cell Phones
Microsoft Access query in VB
first you need to create a record set to do this, after creating a record set RS1. please follow the code below:
Update the code as per your requirement.
Rs1.Open "Select * from table_name where UserName = '" & UName & "'", Cn1, adOpenDynamic, adLockOptimistic
Mar 14, 2009 | Microsoft Visual Basic 6.0 for PC
How to add columns(Vertical) only in Msflexgrid from database table using VB.
you have to open your current project in VB then go to "add references" (its somewhere in the menu bar) then go find microsoft acess and add it as a reference. then go to object browser and you'll find all the functions you need to interface between your project in VB and MS Access.
good luck !!!
Dec 30, 2008 | Computers & Internet
Access-VB
Use this line below:
Private Sub CommandButton_Click()
Dim NumericValue as Integer
Dim StringValue as String
NumericValue = CInt(TextField1)
StringValue = TextField2
DoCmd.RunSQL "INSERT INTO NameOfTable ( [FieldName1], [FieldName2]) VALUES (" & NumericValue & " , '" & StringValue & "');"
EndSub
I Hope this work for you... God Bless
Jul 16, 2008 | Microsoft Office Access 2003 (077-02871)...
Vb.net2005 flexGrid
http://blogger007007.blogspot.com
Here you can get download links for 18 GB of engineering and programming books. Just do a search of "visual basic" or "2005".
Feb 15, 2008 | Computers & Internet
Ms access
Stored Procedures don't exist in MS Access. You do have the following options though. Queries, which are just select or action queries. VB Code, which you can write using Query Objects as if you were writing a Visual Basic application. These can be Functions or Subroutines. In these, you would use the standard programming techniques with while and for loops, etc.
You can create complex situations combining the two of these. A function in the VB code area can accept through parameters, the single values (line by line, record by record) in a query and act on them and manipulate the values.
For example: create a query that does a select phone from address. Create a function in vb called public function StripDashesInPhone(Phone as string) which then uses VB coding to strip dashes from each phone value passed in. To make it all work, in the query on one of the field columns put "NewPhone: StripDashesInPhone([Phone])" and for every record processed in the query, the function is called with the [Phone] field value passed in to the function and the action is processed and returned.
Other than writing a function that is activated by a form button click, which opens the current db and opens a table and process it, just like in VB, this is about as close to cursors and oracle procedures as you get.
I wish it was more, but ...
Oct 09, 2007 | Microsoft Office Standard for PC
Microsoft Office Standard for PC Logo
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
