Question about Hilti Drills
I found a screw inside my hilti hammer and this cause a short circuit, I want to know if this hammer drill have a reset button or fuse inside
  • 2,113 Answers
All motors have a thermal cutoff built inside but if the screw touched the windings and it arced then it needs to be rewound. It may be cheaper to replace it.
Posted on Nov 20, 2013
rowdy45176
  • 2176 Answers
SOURCE: Hilti TE-60 hammer drill
what I would do if you have a fax machine is call 1-800-879-8000 and request a schematic on this tool first. Some of their products are not that easy to disassemble. I never have worked on the TE-60 but have on some of their other products and they are all different. Hope this helps
Posted on Dec 19, 2008
  • 61 Answers
SOURCE: Hi, My hammer drill HILTI TE76-ATC has service red
Hi. It all depends on the age of it as there are 2 different types of electronics fitted to the TE76.
If you have an early model, the service light came on when the brushes were worn or it was in need of a service. Check your brushes 1st. then to reset the light, simply pull the trigger and hold it untill it resets.
If you have the newer type then you will need to reset the service light by attaching a data reader to the service light. this data reader plugs in to a PC, you will also need the HILTI ODA Software to go with it. Basicaly you need to send it back to hilti to have is serviced and reset. if your machine is less than 2 years old, this is FREE. just phone hilti and ask them to collect it. they will pick it up, service it and get it back to you in 3 working days. if you not sure how old your machine is simply phone Hilti and ask them, quoting the serial number. this is etched into the plastic on the left side of the machine underneath the white writing on the motor housing. Good Luck
Posted on Oct 11, 2009
Testimonial: "Thanks"
  • 61 Answers
SOURCE: hilti 76 p atc
Hi . The solution offered by rowdy (pull the trigger and hold it until light goes out) will only work on older machines, the newer machines have more complex electronics that need reseting using an optical reader which plugs into a PC , you will also need the Hilti ODA Software. this is not available to the general public. you may have to send it back to hilti for service and reset. this is free if the machine is less than 2 years old.
  • 61 Answers
SOURCE: I have a Hilti TE 905 AVR the service light came
If you have the old type TE905, which is the one with the square type handle at the back, the service light will come on for 2 reasons. Either there is a tight bearing which will increase the amount of current used to work the machine. Or more common the carbon brushes need replacing. To reset the light, simply cure the problem.
If you have the newer type TE905 with the large “D” Type handle at the back. It gets a bit more complicated. The service light will come on for the same reasons as mentioned above, but it will also come on after 200 hours of use. It will continue to work for another 50 hours with the light on, then it will shut down completely. This is to ensure that it gets regular service. Once serviced or repaired, it will require resetting. To do this you with need a Hilti optical interface, a PC, and Hilti ODA Software. This is not available to the general public. If your Hilti is less Than 2 years old, call Hilti. They will pick it up, repair it, and send it back to you in 3 working days FREE OF CHARGE. If it is older than 2 years there will be a charge for the repairs.
I hope this helped you. Please leave feedback
Posted on Dec 13, 2009
  • 123 Answers
SOURCE: HILTI TE 72
It could be that your connecting rod is broken. You can check by taking your shift lever off of the top of the gear housing and then removing the snap ring to remove the shift boss. That will allow you to look at the crankshaft and connecting rod. If it is broken I would check with Hilti to see if they still carry parts for the TE 72.
Posted on Mar 13, 2010
Hammer drill hilti TE 10 . Hammering parts broken. Replacement require.
Check the attached links, Contact Hilti and order parts.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Innovative Solutions for Construction Professionals Hilti Canada
Results for My preferred Hilti Centers
HILTI AUTHORIZED DISTRIBUTOR AND RENTAL LOCATIONS
Hilti Tool Repair Hilti Canada
Mar 10, 2016 | Hilti Drills
Hilti chuck won't turn
inside the chuck you will see a screw, remove the screw and chuck . A small punch with minimum forced with a small hammer to move the chuck dogs toward the end on the chuck . The chuck was opened to far and is a mechanical bind ..
Jun 30, 2012 | Hilti SFH 18A CPC Hammer DrillDriver
Reset service light on hilti te 706
I have one Hilti Mechie , TE 706 Avr, Now Red Light Only Blinking ,Mechine Not Working
Jun 12, 2012 | Hilti TE 70 Hammer Drill Performance...
Replacing brushes on a hilti te 7a 36v cordless hammerdrill
the fan probably exploded and you would need to replace the motor assembly. You can contact HILTI direct at 1-800-879-8000 for parts and breakdowns.
Jan 26, 2012 | Hilti Drills
Need locations in europe and asia for spares outlet and price for armature assy for hilti TE 2s drill - ( due to short in windings and comutator) purchased on 1981 from saudi arabia -
Go to Hilti's website and choose your country. You can find locations and parts. The TE2s was not introduced until the early 2000's. In 1981 a drill that size would have been a TE12s. If that is your model parts are no longer available through Hilti.
Dec 25, 2010 | Hilti 284228 UH 650 Universal 1/2" Hammer...
How do i replace the jacob chuck on a hilti hammer drill?
Open the jaws of the chuck all the way open. Inside the chuck you will see a slotted screw. Use a large flat head screw driver and remove screw. It will have left handed threads.
After you remove the screw put the end of the chuck in a vise where the 6 flats sides are. Put the drill in low gear and reverse. Hold tight and turn on the drill. This should run the chuck right off the spindle.
Jun 28, 2010 | Hilti Cordless Hammer Drill Sfh 151 A...
Cordless Hammer Drill Sfh 151 A 2.0Ah: Hi, How do you change the chuck on the Hilti SF 15...
Hi. open the chuck to the max. inside the chuck you will see a screw. remove it. put the drill in reverse. hold the chuck. a vice may be needed. pull the trigger. this may work, however in my experience, they are very tricky to get off. I have never had a faulty chuck but have had many faulty gearboxes. i have had to buy ney chuck to fit with the new gearboxes because i couldn't get the good chuck of the damaged gear box. good luck.
May 05, 2010 | Hilti Cordless Hammer Drill Sfh 151 A...
Hilti-284228-rw-98091-163317
to my knowledge you have to send it to a hilti service center. you can't buy parts nor can a local shop buy parts for them. you may just have a loose wire or the switch you move to change direction may have come loose inside.
Apr 13, 2010 | Hilti 284228 UH 650 Universal 1/2" Hammer...
Hilti TE 12. It will not hammer.
the rotory cam has been broken inside if not producing the hammer effect
Mar 11, 2010 | Hilti TE 7-C 120V Rotary Hammer Drill
Hilti 76 p atc
Jul 02, 2009 | Hilti TE 7-C 120V Rotary Hammer Drill
Drills Logo
55 people viewed this question
Top Hilti Drills Experts
woodzowl307
John Trevino
Are you a Hilti Drill Expert? Answer questions, earn points and help others
