Question about Pride Health & Beauty
Wiring connecter needs replaced - Pride Health & Beauty
    Scholar:
  • 90 Answers
Which one?
Visit a dealer or search for SouthWest Specialties on line.
Posted on Oct 29, 2013
My Emerson model k55hxjcp-2593 electric fan motor has 5 wires connecting to the motor. The replacement motor only has 4 wires. I need to know how to connect the new motor seeing there is only 4 wires
the motor should have wireing diagram on side. i would expect 2 of the wires go to a run capacitor & the other 2 are your 110 or 220 depending on unit need.
Jun 17, 2014 | Coleman Mach III Air Conditioner
I have a 2003 camry just replaced the battery and now nothing will turn on at all.
You need to check the connection cause that sounds like there is a wire connection problem. That is short circuited problem I would go and get a wire connection box they have them at auto zone and what you do is take the wire pin that is connected to the box and it will show if there is any connection going threw that wire. Like I said if one wire is bad you will have to replace the whole connector that connects to the battery
Sep 16, 2013 | 2003 Toyota Camry
Need help with a bad wire and connecter to the trunk fuse box in my 2005 Malibu? Anyone help?
There is such a thing called a quick connect crimp type wire connector you can get at your local auto parts store. If you are out with the car pull in and show the parts store guys or gals and they will set you up with what you need. They can even order you a replacement connector if they think you need one. You'll not have to replace all your wires.
Nov 23, 2011 | 2005 Chevrolet Malibu
What rewiring is needed to replace the overload relay with a universal kit, on an upright freezer? Kelvinator model VA16 W. There are two relays that connect to the compressor that need to be replaced....
The two pieces are Relay and Overload.
If you are using a supco relay/overload combination that has three wires with terminals and two wires with stripped ends the wiring is as such.
Red-Run Terminal, White-Start Terminal, Black-Common Terminal (Overload was wired to this)
Stripped wires are connected to line cord along with condenser fan wires.
Nov 19, 2010 | Frigidaire Freezers
What color plug where i ve got three colors blue,red,black
If I understand correctly, you are replacing a switch with the EJ500 timer.
You mention a 'plug'
The EJ500 has 3 wires: Black Red Blue.
If you are replacing a single-pole switch:
The switch has 2 wires, one of these wires is the Hot-from-breaker and the other wire goes to Load:
Timer-black connects to Hot-from-breaker.
Timer-blue connects to wire-going-to-Load.
Timer-red wire is capped off. Red is not used for single pole switch.
If you connect wires and your lights blink, then you put the red wire where the blues wire should go.
If you connect wires and lights do not operate, try reversing the blue and black wires.
I posted images of EJ500 wiring (the Intermatic EJ500 and ST01C have identical wiring
http://waterheatertimer.org/ST01C-program.html#ST01C
If you are replacing a 3-way switch, the wiring is more complicated.
The EJ500 can not replace a 3-way switch wire-for-wire.
Diagrams on link above show wiring for 3-way.
Add a comment if you need more help.
Nov 10, 2010 | Intermatic EJ500C - Indoor Digital Wall...
Need visual instructions for 600w-120v ac/c.a./ca 60hz
1) If you are replacing a switch that has two wires, and your dimmer has two screws > then Connect these wires to either screw.
2) If you are replacing a switch that has two wires, and your dimmer has three screws > then Connect one wire to dark-colored screw, and connect other wire to either brass-colored screw.
3) If you are replacing a 3-way switch that has 3 wires > and your dimmer has three screws > then pay close attention: One of the wires on your existing switch is connected to dark-colored screw. Mark that wire. It connects to dark colored screw on dimmer. The other two wires connect to either screw. The dark-colored screw is called the common terminal.
IF you have already removed switch and do not know which wire was connected to dark-colored screw >>> then connect the wires to any screw on dimmer >> turn on power and check if the circuit works >> keep rotating wires until they arrive in the right order >> the circuit simply will not work until the to correct wire is connected to dark-colored screw
THE dark-colored screw is the key
Oct 10, 2010 | Cooper Wiring Devices Aspire Smart Dimmer...
Installing a 7 day digital wall timer
Swylite LST100 timer has 4 wires. Red, Blue, Black, White
Timer has more wires than wall switch because timer has electric clock inside. And with + series Swylite timer, it also has led bulb that needs power.
Timer can replace ordinary on-off switch
-On-off switch has 2 screws, so 2 wires (plus ground wire) connect to on-off switch
-Three of the four timer wires are used when replacing on-off switch
-Red wire is not used, it is capped off
Timer can replace 3-way switch
-Three way switch has 3 screws, so 3 wires (plus ground wire) connect to 3-way switch
-One of the screws on 3-way switch is colored dark (it is crucial to identify the wire that comes off dark screw so timer can be wired correctly)
Lets replace on-off switch see diagram
Timer black goes to Hot wire
Timer blue goes to Load (light, fan, motor)
Timer white goes to Neutral
Timer red is capped off.
How to check which wire is Hot, Neutral and Load
Switch you are replacing has 2 wires > one is Hot, the other goes to Load
Remove these two wires. Separate wires so you can test. Turn on power. Tape tester leads to wood sticks so hands are away from power. Test each wire to bare copper wire.
When tester lights up >> that is Hot wire >> please connect this wire to Timer black wire
The other wire goes to Load >> please connect this wire to Timer blue wire.
Now test for Neutral. Test Hot wire to other wires inside box. Neutral should be white. When tester lights up, that is Neutral. Please connect Timer white wire to neutral. IF YOU DO NOT have a neutral, you can connect Timer white to bare ground wire until you have time to drop a Neutral into the box.
Replace a 3-way switch see diagram
Three-way switch has 3 wires.
Identify which wire connects to Dark screw on switch >> and then please connect this wire to Timer Black wire.
Timer white wire connects to Neutral
Timer blue and red wires connect to other two wires that came off switch ... they connect to either one.
Oct 01, 2010 | Solar Ivory Swylite Lst100+ Back-lit...
Hunter cieling fan switch replacement
My switch broke, so I'm in the process of replacing it.
Before taking it apart, I made note of the wire colors:
L=Black
1=Grey
2=Brown
3=Lt Blue
Jul 18, 2008 | Hunter 20761 52'' The Stratford II Brushed...
Replacing thermostat for central heat and air/ not humidifier
rh and rc should have a jumper between them.connect red to either.y=yellow g=green w=white and do not use the blue.your new stat will run on batteries.
May 26, 2008 | Honeywell Power Humidifier: Furnace...
Health & Beauty Logo
21 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
