Question about Intex Krystal Clear Model 635 Pool Filter Pump 1500 Gph
How do I install my model 150 tiller attachment onto my Husqvarna 128 engine shaft?
  • 3,103 Answers
As you fit the shafts together may need to pullt he start rope slowly for the socket/shaft to line up then it all fits together and locks in place..
Posted on Jan 10, 2014
How do I change the tines
You have not shared which model and make of tiller you have, but many of them have a set screw or two holding each tine on.
You would need to loosen the screws, and maybe polish the shaft with sandpaper and oil it to get each tine off in order.
Some tillers use a different method of tine installation, since this can be patented or trademarked.
For example, some have the tines permanently attached to the shaft, so the whole shaft must be replaced as a unit.
God bless your efforts.
May 12, 2016 | Garden
How do I replace a flexshaft on my huqvarna 128 LD weedwacker.
I have a Husqvarna 128LD and love it. When using a tiller attachment the part of the shaft that has the knob comes loose. I have tightened the screw with allen wrench but it still comes off. or gets loose. Can I weld the bracket to the shaft?
Sep 14, 2013 | Husqvarna 128 LD Weedeater
Have a 28CC Husqvarna 2 stroke engine. Used it once, now the attachments won't slide far enough in to connect to the drive shaft and
Sounds like the upper drive shaft connected to the trimmer housing has slid down. Try holding the unit gas tank down, and turn the inner shaft until it drops back down into the unit, then attach the desired tool.
Jun 28, 2012 | Husqvarna 28cc Gas Line Trimmer
I have a Husqvarna trimmer model # 128LD.I want to get a tiller attachment.Can you give me the model I need for my model?
If you have the 128LD from Lowe's, Tractor Supply or Sears you can use TrimmerPlus attachments, any MTD manufactured attachments should work.
http://www.trimmerplus.com
May 26, 2010 | Husqvarna Garden
I just got a 5' KK rotary tiller and the pto shaft fits onto the tractor just fine with the button lock. The other end doesn't want to slide all the way onto the tiller gearbox drive shaft. It only goes...
http://www.youtube.cohttp://www.everythingattachments.com/Tractor
http://www.everythingattachments.com/Tractor-3-Point-Hitch-Tillers-Rotary-Tillers-s/76.htm
go to the second site first, it will explain your "problem.". Your problem is you need to adjust the length of the pto shaft to your particular application. not all pto shafts fit all attachments "out of the chute"
once the shaft is adjusted OR prio to modifying it, view the first video. both or very well presented. i've been there!
Happy tilling!!
steve wood
Rancho de Suenos
Albuquerque, NM
Mar 10, 2010 | King Kutter II Gear Driven Rotary Tiller...
I have an older Troy-Bilt Pony Garden Tiller witha
From what I read you need a new rewind clutch and the spring and cord go into the housing. Briggs is easy to fix. contact me at kerryjonjon@yahoo.com and I can send you what you need or you can send it to me and I will repair it very cheap!! Parts are available at almost any small engine parts place.
Jul 17, 2009 | Troy-Bilt Pony Garden Tiller
I need a new motor for horse model, serial no. 360331. which models fit this troy built.
Just about any engine with a 3/4" horizontal shaft that is internally threaded on the end and has the four bolt mounting pattern around the shaft will work. I have gone to Harbor Freight and purchased their 6.5 H.P. engine that is a Honda clone and it will work fine and only costs $100-150 dollars. The only difference is that it uses a metric bolt to hold the pulley on the shaft,the four mounting bolts are metric and you have to disconnect the low oil shutoff or the engine will die when you are tilling deep. It is a good low cost option for the Horse tillers.
Frank
Jun 10, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Changing Drive belt On Troy Built Tiller
You have to remove the engine (4 bolts, no big problem), then remove the bolt in the center of the pulleys, then remove the pulleys. Slip the belt(s) (2 if you have the Super Bronco model) onto the pulleys, re-attach the pulleys with the bolt, re-mount the engine, and you're home free.
May 20, 2009 | Mtd Troy-Bilt Bronco OHV Tiller
Intex Krystal Clear Model 635 Pool Filter Pump 1500 Gph Logo
19 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
