Question about Health & Beauty
My health I meter says lo so I changed the batteries twice and it still says lo
    New Friend:
  • 3 Answers
Clean the battery terminals with sandpaper or emery board.
Posted on Nov 30, 2013
3 Suggested Answers
SOURCE: mY bfm588dq-81 scale is malfunctioning. The
My Health O Meter BFM5955KD-60 scale is malfunctioning. The display keeps saying ''0'', when it proceeds to display my weight, then shuts off. I replaced the batteries several times, but it keeps displaying ''0'' and shutting off. This is a brand new scale.
Posted on Jan 28, 2010
  • 10 Answers
SOURCE: have a Health o Meter
I have not found a manual anywhere currently because the manual is no longer on Health-o-meters website, only the current supported scale. However, I have one and can tell you what I know on how to operate it.
First Remember you ALWAYS have to tap (slightly touch the middle of the scale to initiate it to calibrate ON to ready to take your weight) the scale and you then wait for the little lines at the top and bottom to flash on and off, and then show a 0 on the scale where the Weight will be once you have stepped on the scale. However, make sure your feet are slightly moist (if you just woke up and your feet are dry wipe them with a moist cloth first) for a good contact on the pads that will send the small signal through one leg and back down to the other to measure your body fat and hydration levels.
For those having problems with false readings or Lo readings after changing batteries (Lo means the batteries are low and to change if you haven't done so), make sure batteries are good even if you just bought them by checking them in a Battery Output checker, which you can get at the store...or check the expiration dates on the battery, things can sit around at the store for a while some times especially at small grocery or convenience stores.
Then if you are still getting false or Lo readings, you need to do a Factory Reset by flipping over the scale and look toward the top where you will see a small hole with raised letters, not colored, that show RESET under the small hole. Get a tooth pick or some about the same diameter and put it in the hole and press the little button. You can feel it when you get the toothpick--- or whatever you are using---in the middle of the button and it slightly depresses. Hold it down for at least a count of "One Thousand one to One Thousand ten," which means ten seconds. That should do it.
Then you need to make sure your settings are set by holding down the number on the front end that you will use to save your data, and hold down the Set/Save button on the top front at the same time. When it starts flashing the 5 for Feet in the Height either change that with the History button by pressing it until you get the correct number or leave it by pressing Set/Save button again. Use the Set/Save button to Save and Move to the next item to Set/Save and the History button to Change the number or item such as Gender from Female (the Default is 5Ft 3in Female who is 18 years of age and the Goal starts out at 100 but you can save a Goal Weight or not by choosing YES or NO then set the Goal if you Choose YES).
The Date and time are set by just holding down the Set/Save button until it flashes in the little yellow box in the bottom left of the screen. Then use the buttons the same way as you did above.
By the way when you see H with numbers after you have weighed Saved (To Save: hit Save while the numbers are on the screen) and once they disappear you just press your number again hit History to Scroll through your history... the H stands for Hydration percentage.
Hope this helps.
Posted on Feb 18, 2012
What does code E-9 mean on an Accu-Check Glucometer?
E-9 message "E-9" in the display means the battery is almost out of power. Change the battery now. If the message reappears after the battery has been replaced, reset the meter. To reset the meter, remove the battery, press any meter button, then reinsert the battery. Download the owner's booklet now and refer to Chapter 7, "Changing the Battery."
Nov 12, 2017 | Health & Beauty
I changed the new batteries but still digital display is not shown
if the batteries are new and the battery terminals are clean and not corroded or broken, and the battery polarity is correct when they were installed. There must be a fault in the internal circuits of the scale, and a technician with the right tools, training, and experience will be needed to repair it.
Maybe time for a new scale.
Oct 05, 2017 | Health-O-Meter Health o Meter BFM681DQ-63...
Need owners manual for Healthometer BFM588DQ-81
I have not found a manual for Model BFM588DQ-81anywhere currently because the manual is no longer on Health-o-meters website, only the current supported scale. However, I have one and can tell you what I know on how to operate it.
Hope this helps.
Oct 25, 2011 | Health-O-Meter Health o Meter BFM588DQ-81...
Have a Health o Meter bfm588dq-81. Getting a Lo lite - replaced the 4 1.5v batteries and still get the Lo lite????
Hope this helps.
Sep 08, 2011 | Health-O-Meter Health o Meter BFM588DQ-81...
Scale keeps showing lo no weight
Try taking the battery out and putting it back in, also there should be a small reset button. You will need a toothpick to push the reset button. Allow time for the scale to reset before stepping on it.
Apr 19, 2011 | Homedics Digital Scale
I have a Braun ThermoScan Type6013 have changed batteries twice but keeps coming up LO when try to read a temperature, any ideas?
Problem:
Temperature taken is not within typical human temperature range (93.2 °F - 108 °F / 34 °C - 42.2 °C).
Solution:
Make sure new, clean lens filter is properly inserted. Then, take a new temperature.
Feb 21, 2011 | Braun Health & Beauty
MY bfm588dq-81 scale is malfunctioning. The
Throw it away. The product sucks. I know, I'm throwing one away right now and I"ll NEVER purchase one again.
Aug 17, 2009 | Health-O-Meter Health o Meter BFM588DQ-81...
Health o meter-HDM562DQ-18, replaced battery, want to reset, no instructions.Help!
just inside the battery compartment, where the battery door latch goes, its about 3/4 on an inch down.
Jun 29, 2009 | Health-O-Meter Health O Meter HDM520KD 18...
Health & Beauty Logo
131 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
