Question about Garden
What weight oil for worm gear - Garden
  • 76 Answers
Gear Lube 80W90 for most Lawnmower
Posted on Oct 22, 2013
Testimonial: "thank you for the response but it's for a 32" snow blower"
IS IT DIFFICULT TO OIL THE WORM GEAR MYSELF? IS THERE SOME WAY I COULD LEARN ONLINE HOW TO DISASSEMBLE MY CAMCORDER AND KNOW WHERE THE WORM GEAR IS/ WHAT & HOW TO OIL IT?
U shure looking for trouble. Probably u will find how to take a camcorder apart, but putting it together thats an other problem. Good luck.
Jun 05, 2015 | Panasonic SDR-H40 HDD Camcorder
Not getting oil to blade tried the screw to adjust but still no oil getting throu !!
Your worm gear assembly is probably frozen in with sawdust and dirt. Take off the oil gear assembly. You will need to take off the clutch and the sprocket, the worm gear is directly underneath. Sometimes they are made out of plastic, sometimes of bronze. They use plastic for newer saws. If the gears do not turn easily, when you use your finger to turn them when they are off. then it is probably a good idea to buy a worm gear and then totally clean the assembly. Put in the new gear and it should work. Also check your chain bar check that the hole is clean. They also have a seal around the worm gear under the clutch assembly. It is good that you replace that too.
Nov 23, 2013 | Garden
How to adjust worm gear
worm gear on what as only ever seen a worm over wheel gear set up on a foden 32 ton 4 axle bulker ,they use a special oil as well as the gears are phospor bronze ,Now do you mean a hypoid gear like a modern car differential
Apr 21, 2012 | 1999 Chevrolet C/K 2500
For the Skil 77 worm drive circular saws what type of oil is required?
Use 90 weight gear/differential oil but if you use it outside in the cold weather it's too thick, use 40 weight oil then and switch to the 90 weight in the summer.
Jun 03, 2010 | Saws
I caught a spoon in my kitchen aid stand mixer. The mixer will not turn, and oil leaked out of the side
It sounds like you have lost some teeth from your worm gear. This usually happens when the mixer has been overloaded. The teeth on the worm gear are designed to fail first to prevent more serious damage. To replace the part you will need to open the head on your mixer. The gears are at the front of the mixer packed in grease. It should be obvious that the worm gear has broken once the head is open. If it is not the worm gear, with the head open it should be easy to spot the problem. The gears are available as spare parts from several places on the internet. search for "kitchenaid worm gear".
When you replace the worm gear, you should be able to see if you need more grease. This will have been the "oil" you saw escaping.
Jan 30, 2010 | KitchenAid Food Mixers
I am in Africa and the saw was shipped with little
drain out the remaining oil and if you can get just a clear mineral oil fine, otherwise standard gear oil would work also i.e. 80/90 weight
Nov 19, 2009 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
Bar oiling problem
Just a thought: Is it cold where you are? At this saw mill where it is my job to keep chain saws running, learned years ago that you cannot use "bar oil" in winter. Need thinner oil, like motor oil. ....preferably a "non-detergent" motor oil, plain 30-weight is OK, HD30W will work, but the HD part causes the chain to stretch more so than standard bar oil. The bar oil literally is so thick in cold that it stripped the worm gear out of a Poulan Pro oil pump (plastic gear, anyways, wasn't much to begin with.) But thought you may want to try thinner oil, if it is cold where you are. Oh yea we also have 2-Husqvarna 359's with 20-inch bar, and use thinner oil in winter. Our Husqvarnas have an oil adjuster located on bottom, on clutch side. Straight slot screw adjustment.
Nov 18, 2008 | Husqvarna Chain Saw 20" Bar
Plastic Gear
call royal spare parts department at 1800-222-2310 they will
ship you a gear for about $6 + shipping
Aug 09, 2008 | Royal Orca ASF5000X Shredder
Meade LX200 10" - RA Gears slip when mounted on wedge (Milburn)
The problem is the addition of the 80mm telescope to the assembly. The telescope is now out of balance, and places extra weight off-center as the position chages. Too great an off-balance will cause the main gears to 'jump' the worm teeth. The solution is to restore balance by adding counter weights as needed. Loosten the axis locks (carefully) and see which direction it wants to move. To balance my LX, I used a small bag with lead buckshot to determine how much weight was needed and where to achieve balance. Then I added fixed weights to the mount. Once this is done, the scope should track correctly.scopestuff.com has balance kits at reasonable prices.
Feb 03, 2008 | Meade LX200GPS Telescope
Garden Logo
15 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
