Question about Epson PowerLite 1760W WXGA 3LCD Projector V11H361120
Audio is not going out to external speakers, it remains in the internal speaker?
  • Epson Master
  • 4,018 Answers
Check the socket out it should go to external speakers when the socket is in use. the socket has a switch inside that turns off the internal speakers. but sometimes the settings in the menu are set to only internal you will need to check this on sound settings.
Posted on Dec 31, 2013
Sound will not come on the televison
Most televisions have a setting that controls whether the TV uses its internal speakers or sends the sound to the audio out jacks for an external amplifier or speakers. This setting will prevent any sound from coming out of the internal speakers.
Try going through the settings menu and follow through the audio/speaker selections and confirm that the TV is set to use internal speakers.
Best Regards,
Sep 01, 2017 | Televison & Video
External speakers won't work on HP T5570e Thin Client
Try to use earphones, plug them in to phone audio connector....
try if it works..... if so, disconnect them and plug speakers.... and try again.... if doesn't work, go to audio advanced setup and check if speakers are not muted, or set up voicevolume level is too low. Play with that setup....
Also some computers can turn on or off speakers in Bios.
If problem will not be solved, try to use USB speakers
Jan 13, 2014 | HP T5740 Thin Client Desktop PC
Internal speakers
If you go into the menu their should be an option for audio/sound once you enter that sub-menu there should be an option for the speaker internal/external or speaker on/off.
Nov 10, 2013 | Pioneer Elite PRO-940HD Television
To disable internal speaker in hp6000 pc
The internal speaker should be disabled when you plug in external speakers.
If not go to Start > Control Panel > Sounds, Speech, and Audio Devices
> Pick a task.......>Change the speaker settings >Audio tab.
[ Note* An internal speaker can be used for the BIOS Beep Codes. If it is this speaker should not be disabled.
BIOS Beep Codes are the way the computer tells you something is wrong, and an area to look into, for it ]
Regards,
joecoolvette
Jan 21, 2012 | HP Computers & Internet
My HP 610 laptop's inbuild speaker is not working,but with the external speaker it is working.I want to know the price of HP compaq 610 inbuild speaker.
Try the following steps:
Open your laptop carefully (look out for fragile ribbon cables) !
Check for a broken wire going to the internal speaker.
Check for a faulty contact at the audio output jack (these things have a contact which disconnects the internal speaker when a plug is connected).
Temporarily connect any speaker in the place of the internal speaker.
If the problem is still the internal speaker, remove it and go to any good audio components shop and buy an equivalent speaker.
Hope this helps.
Nov 25, 2011 | Computers & Internet
IBM thinkpad type 2647 - after installing external
Go to control panel / sounds / audio, and see if the boxes have greyed out writing, if so then the driver needs reloading, if they are all good check all settings.
Meant to ask if volume control icon is showing in the right lower task bar.
Dec 22, 2009 | IBM ThinkPad T23 2647 Notebook
Distored sound
distorted sound from external speakers or internal speakers?
isolate please. remove external speakers if you have one. just troubleshoot on the internal speakers alone.
uninstall the audio drivers. install the latest one. if fails. download then flashed the latest bios.
run diagnostics extended test to check the internal speakers. if also fails then replace the internal speakers.
Dec 05, 2009 | Computers & Internet
No sound from external speakers with toshiba dynadock
if using XP, go to start control panel , sound and audio devices.Under the audio tab make sure the C Media CM106 sound device is selected under sound playback. Then under the volume tab set the volume somewhere in the middle or at the top if you don;t have active speakers . Then Under Speaker settings advanced, make sure the speaker setup is set to Laptop Stereo speakers. Also make sure the speaker volumes are up on the speaker volume button. click ok. If no result check that the cm106 sound decvice was cemented in as I saw it dissaper when I thought i had slected it. I think the key thing here is the device and the laptop speakers setting.
Aug 26, 2009 | Toshiba Dynadock Port Replicator, Docking...
Speaker Problem
Nothing is wrong. Most computers automatically turn off the internal seakers after the external seakers are connected. Go to cntrol pannel and see what you can do under audio options or some such equivelent. Check back with more problems,
hope this helped/helps.
Mar 10, 2008 | Audio Players & Recorders
Speakers
Tvs are wired differently these days. Your old Zenith for example probably had a selector switch that allowed you to change from internal or external speakers, bandpassing the audio from the internal amplifier to the audio out connectors. Your Sharp on the other hand may be controlled by customer menu to perform the same function as the external switch. Go into the menu and sub-menu of the audio and see if it gives you any choices for selecting internal or external speakers... If it doesn't it probably will not bandpass the already amplified signal, which means if you want to listen to your Tv on those external speakers you'll first have to pass the audio sample through an amplifier.
Hope this helps.
Bill
Nov 14, 2007 | Sharp 25N-M100 25" TV
Epson PowerLite 1760W WXGA 3LCD Projector V11H361120 Logo
273 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
