Question about Lochinvar ENERGYRITE 250K BTU NATURAL GAS POOL HEATER 88% -
500000btu boiler mn: h30502b, sn: 912303843... hot surface ignitor need sreplaced...no funding currently available..need cross reference for this part. proper id is not available for oem parts to this boiler. also a tech manual would be great
    Top Expert:
  • Lochinvar Master
  • 8,688 Answers
If current to unit check safety circuit if ok check gas and ignitor
Posted on Sep 15, 2017
2 Suggested Answers
  • 990 Answers
SOURCE: Lochinvar The boiler is purging, ignitor is getting hot, but
This could be something as simple as a gas valve turned off. First check all the gas valves, (one inside the heater, one outside and one at the source.) Also if this is LP gas make sure that you have enough gas. It takes at least 30% in the tank before the heater will fire. In many places their may be an earthquake valve. If this fails it will shut the gas down to the heater. Their are many reasons the heater won't fire and the fellow who told you to change the board probally works for Lochinvar. You might want to have a repairman look at the heater first before you spend that money. Good luck.
Posted on Feb 17, 2010
I have a mclain 68 boiler... I have no power going from boiler to thermostat. what can that be?
Could be a disconnected wire or failure of the thermostat power supply.
Oct 23, 2016 | Heating & Cooling
MY carrier model #58DHC with hot surface ignitor has quit working. Blower works, but no heat. If you turn the thermostat to on fan will run but no heat. Did preliminary testings with self test on printed...
If you suspect its the ignitor? The hot surface ignitor is powered by 120v. Inspect ignitors' hot surface for cracks or burnt spots. Uplug ignitor from board. Cycle heat on and verify 120v to the ignitor at the cannon plug on the board where the ignitor plugs in. If you have the voltage then replace the ignitor. If not, you'll need to verify all other circuits are working before condemning the board. Work safe and at your own risk! Hope this helps!
Mar 25, 2017 | Heating & Cooling
I have a Raypak 147CHL boiler used for our house's slab heating. Started up this season 2 weeks ago but 2 days ago went off. Now it won't restart. Tried turning off & restart several times but no...
Check to see if there is voltage going to the Hot Surface Ignitor when you first try to fire it up. If you have voltage but it fails to glow, the hot surface ignitor has failed and will need to be replaced.
Also ensure you have proper flow through your boiler......make sure you have water flowing through the boiler and, if there is a flow switch, check the voltage across the two terminals of the switch......check each to ground for voltage. If you have voltage, then check the voltage reading across the two terminals themselves, you should read 0 volts across the terminals (indicating the switch is closed).
Hot surface ignitors are "wear-n-tear" items and should be the first place to check.
I hope you find this information to be very helpful to you moving forward.
Please let us know if you need further help. :-)
May 18, 2010 | Heating & Cooling
I have a 90 plus Ruud furnace that will work when I light the furnce with a match when the furnace is calling for heat
Sounds like the ignitor. Your unit most likely has a hot surface ignitor. The hot surface ignitor is located in front of your burners and usually has two white wires leading you to it. It is a wear-and-tear item that can be expected to need to be replaced every couple of years or so. It would not hurt to keep a spare near your unit at all times.
How to test a hot surface ignitor
Mar 29, 2010 | Heating & Cooling
I replaced what I thought was a bad igniter.But still had no glow from new igniter. Must be something else.Where do I go from here?
Hello there: The oven bake burner and ignition components are located beneath the oven cavity. In most cases the oven bottom panel can be removed for access (check your owner's manual) but on some models the oven burner has to be accessed from below in the warming or broiler drawer area. If accessing from the top, a 'flame spreader' (flat metal plate) above the burner may also need to be removed to see the burner itself.Many ovens use a single oven burner in which case they only have a single gas valve and ignitor. The same burner is used for both bake and broil functions, the broil usually being in the drawer area below the oven. Higher-end models may have a separate bake and broil burner. On such a system there will be two ignitors, one for each burner. They may also employ a 'dual' gas valve (see illustration above) instead of using a separate valve for each burner.Some range models may have an additional broil burner located at the top of the oven cavity which may be referred to as a 'waist high' broil. If not, broiling usually takes place in the drawer area below the oven, which uses the same bake burner for the broil function. Most gas ranges currently available employ one of 3 basic gas ignition systems; pilot ignition, hot surface ignition system (which uses a 'glow bar' or 'glow coil' - aka an "ignitor") and a spark ignition system. The latter two being referred to as "electronic ignition" systems as they use electricity in one form or another to operate the oven heating system. Only the pilot ignition system has an actual "pilot" (which is a small but real "flame") which might need manual lighting.
If the surface burners of a range are a spark ignition type, the oven IS one of the possible kinds of electronic ignition systems and thus will not usually have a "pilot" which needs lighting. Be aware though that just because the surface burners might light via a spark doesn't necessarily mean the oven uses the spark type ignition system too.
There is one older style of electronic ignition system which does also use an oven pilot but it is very rare and such a system hasn't been used in oven models since the early to mid 70's. It is the 'constant pilot' *electronic ignition* system.
Making Observations
The oven burner's operation will usually need to be directly observed while in operation as the first step to troubleshooting problems.Ignition System Type Links
Ignition System Types:
  • Pilot Ignition
  • Electronic Ignition with Constant Pilot (rare)
  • Electronic Ignition with Glow Ignitor (most common)
  • Spark Ignition System
  • Is there continuity between the oven gas valve's terminals?
    Hot Surface ('Glow Bar') Ignition System (most common)
    This is the most popular system currently used for ovens and is comprised of a control mechanism (whether thermostat or electronic control), the oven ignitor and an oven gas valve.
    What happens in this style ignition system is that the thermostat or electronic control switches power to the oven ignitor and gas valve circuit which are connected in series (one after the other). As power flows through the ignitor it heats and draws current (measured in amperage). Once the oven ignitor draws a specific amount of current the oven valve opens to allow gas to flow to the oven burner where the glowing hot ignitor (glow bar) ignites it. Power must continually flow through the ignitor and oven gas valve for gas to be released into the oven burner to create a flame.
    It should usually only take in the area of 30-90 seconds for the oven ignitor to reach the proper resistance to allow the proper amperage to reach the gas valve to open it and for the ignitor to ignite the gas at the oven burner.
    Dec 30, 2009 | GE Ovens
    I have a transistor mx d362. need cross reference part number
    If you know the input and output voltage, and the approximate current capacity just replace it with a commonly available regulator of a similar rating.
    Oct 10, 2009 | Home Security
    Hot water boiler will not ignite
    Check all your limit switches on this unit. One of them is either tripped or bad.
    Apr 07, 2009 | Water Heaters
    Mixer shower connected to combi boiler running hot and cold and also not much pressure
    Mixing valves usually have a diaphragm inside that keeps the hot and cold separate. If the diaphragm is old it may be allowing the hot and cold to mix improperly at the back of the valve. This is similar to a cross connection (a hot water line tied into a cold line) in your plumbing. Cross connections interfere with the performance of Combination Boilers and Tankless Water heaters due to their having no water storage or a very small buffer tank. The brand of the valve will help as each one is different in their mechanical design. If this is the problem you or a licensed plumber can replace the cartridge in the valve. Refer to your valve's owner's manual for part numbers.
    Mar 17, 2009 | Home
    Oven will not light
    If the surface burners of a range are a spark ignition type, the oven IS one of the possible kinds of electronic ignition systems and thus will not usually have a "pilot" which needs lighting. Be aware though that just because the surface burners might light via a spark doesn't necessarily mean the oven uses the spark type ignition system too. spark-anim1.90x11.gif
    Nov 20, 2008 | Frigidaire Ovens
    Lochinvar ENERGYRITE 250K BTU NATURAL GAS POOL HEATER 88% - Logo
    41 people viewed this question
    Top Lochinvar Pool & Spa Experts
    Paul Carew
    rogerpaul3
    Level 1 Expert
    David Spradling
    David Spradling
    Are you a Lochinvar Pool and Spa Expert? Answer questions, earn points and help others
