Question about Pool & Spa
Need cross reference for hot surface ignitor: model number H3-0502B, serial number 0912303843. do not have tech manual for this boiler, nor identifier info for existing hot surface ignitor
  • 903 Answers
SOURCE: Identify the serial number
The NEC serial number is located on the Device Rating Label (DRL) and is clearly marked. The DRL label has the UL, FCC and NEC in bold type face and is located directly below the CAUTION sticker on the bottom side of the unit.
Posted on Sep 14, 2005
  • 2336 Answers
SOURCE: cross reference an engine serial number
Suzuki prints a publication that cross references vin numbers to engine numbers. They are sent to dealers.
Posted on Nov 10, 2008
  • 306 Answers
SOURCE: Need Carrier Part Number Cross Reference
Try these guys I live where they are and they have everything and they ship anywhere also. And you are right the part is only about 30 bucks I know a guy that bought one off of ebay also.
http://www.wsconet.com/HVACComRefrigeration/IgnitorsThermocouples/default.aspx
Posted on Jan 25, 2009
e-Guru
  • 3917 Answers
SOURCE: Magic Chef Range in camp trailer, pilot light in
The most common problem for gas surface burners is that they get gas but don't light. This is generally caused by dirt or grease splatters on the burner itself. Residential-grade range/stove burners are round and have small holes around their perimeter to allow gas to flow out and create a round flame. The gas coming from these holes is often ignited by a small vertical row of holes on the side of the burner. If these vertical holes are clogged or obstructed, the gas can't ignite.
The solution is to clean the burners thoroughly. Use a toothpick to clear the small vertical holes, then allow the burner to dry completely and try lighting it again. If it doesn't light immediately, repeat the procedure
or
May be the ignitor, replaced mine and it fixed it. A gas company guy told me that is common in Magic Chef ranges.
Thanks for contacting Fixya
Posted on Jun 14, 2009
  • 534 Answers
SOURCE: i have a transistor mx d362. need cross reference part number
If you know the input and output voltage, and the approximate current capacity just replace it with a commonly available regulator of a similar rating.
Posted on Oct 10, 2009
I have a power flex 50 gal power vent model number pvg625ot6onv.. Serial number, 0932t413742. I got a new lighting element, and installed just fine but the actual ignitor keeps dropping to vacation...
Sorry to hear about your wife.
Please copy following links for Intellivent troubleshoot resources:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
http://www.thetankatwaterheaterrescue.com/forums/forum3/
http://www.americanwaterheater.com/
Clean air intake located on bottom of heater using compressed air or feather duster. Use auto inspection mirror and flashlight to see under the unit.
Age of water heater appear on label on side of tank.
Look for serial number.
Powerflex is American water heater product (AO Smith)
First 2 digits of serial number is year of manufacturer, digits 3-4 are week during year.
Nov 26, 2012 | Water Heaters
Sears model 317 B6034 top burners work. also the boiler works. The oven (bake) does not work. How do I inspect for the fuse and what ignites the oven?
you have a bad bake ignitor.i don't know what number you sent but it's not the model number,open the draw below the oven door and look at the frame where the door closes into and you'll see a tag with the model and serial number,call your parts store,give them the model number and tell them you need a bake ignitor
Jan 20, 2011 | Ovens
I need ignitors for heater model number 3e219e
The part number for the ignitor kit is PP200 (new number) Old number was PN HA 1000.
Also from the parts list, this PN: 102548-03
Parts list:
http://www.bealsmotor.com/105553_219E.html
Burner head parts: (Ignitor is item 5)
http://www.bealsmotor.com/105553_burner.html
Actual Ignitor Kit:
http://www.amazon.com/Desa-International-Hot-Surface-Ignitor/dp/B000DZDPVI $39.95 + shipping
Downloadable manual: http://www.desatech.com/manuals/Construction%20Heaters/105553-01.pdf
Dayton Portable
Oil-Fired Heaters
PARTS:
Ph. 1-800-323-0620
24 hrs / 365 days a year
105553
2E510F, 2E511F, 3E218E, 3E219E
Please provide following information:
-Model number
-Serial number (if any)
-Part description and number as shown in parts list
102548-03 (part you need)
Thanks for choosing FixYa,
Kelly
Nov 19, 2010 | Dayton Heating & Cooling
I have a Raypak 147CHL boiler used for our house's slab heating. Started up this season 2 weeks ago but 2 days ago went off. Now it won't restart. Tried turning off & restart several times but no...
Check to see if there is voltage going to the Hot Surface Ignitor when you first try to fire it up. If you have voltage but it fails to glow, the hot surface ignitor has failed and will need to be replaced.
Also ensure you have proper flow through your boiler......make sure you have water flowing through the boiler and, if there is a flow switch, check the voltage across the two terminals of the switch......check each to ground for voltage. If you have voltage, then check the voltage reading across the two terminals themselves, you should read 0 volts across the terminals (indicating the switch is closed).
Hot surface ignitors are "wear-n-tear" items and should be the first place to check.
I hope you find this information to be very helpful to you moving forward.
Please let us know if you need further help. :-)
May 18, 2010 | Heating & Cooling
Mixer shower connected to combi boiler running hot and cold and also not much pressure
Mixing valves usually have a diaphragm inside that keeps the hot and cold separate. If the diaphragm is old it may be allowing the hot and cold to mix improperly at the back of the valve. This is similar to a cross connection (a hot water line tied into a cold line) in your plumbing. Cross connections interfere with the performance of Combination Boilers and Tankless Water heaters due to their having no water storage or a very small buffer tank. The brand of the valve will help as each one is different in their mechanical design. If this is the problem you or a licensed plumber can replace the cartridge in the valve. Refer to your valve's owner's manual for part numbers.
Mar 17, 2009 | Home
Need Owners Manual
If you have not done this go to sears parts direct. If I am not mistaken you model number should start with 917. Hope this will help.
Feb 23, 2009 | Heavy Machinery
Jan 25, 2009 | Heating & Cooling
Cross reference an engine serial number
Nov 10, 2008 | 2004 Suzuki VZ 800 Marauder
Pool & Spa Logo
18 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
