Question about Kicker ZX1500.1 Car Audio Amplifier
Have Kicker 12ZX1500.1 Played for five minutes, made unusaul sound and went into protective mode( RED LIGHT). How to get out of protective mode ? What could have caused it?
XRAYRON
  • 156 Answers
SOURCE: kicker zx750.1 protection mode
Ok a few things to check here. So get a checklist lol.
Is the amp well ventilated?
When it goes into protetion mode is the amp HOT? like too hot to touch?
Do you have the GAIN maxed out? Turn it down
What are the gauges of your ground/power cables?
A bad speaker or speaker wire can cause this also.
Incorrect wiring of speakers like 4ohm speakers wired in parallel connected to bridge.
Inadequate alternator or battery in car
Does your system have a Capacitor? If not get a nice digital CAP they aren't too expensive.
Posted on May 06, 2008
  • 14 Answers
SOURCE: i think ma kicker kx1200.1 amp is blown or ma kicker L7 are gone
that would be the amp. sorry to say. when a wire crosses over, it sends a shock through the amp, there are a few things to try just to see if you fried the amp. the first thing to try is to move your ground to a different location. second thing to look at would be the fuses. alot of times the fuses will blow at the slightest shock. the amp will still turn on if you have an amp with 2 fuses, it just wont be getting all the power it needs, which could be causing your problem. also, it is worth the hour and a half to mount everything down in your vehicle. you might check the kicker website, because i have herd rumors that kicker offers a lifetime warranty on almost all of their products. best of luck, and i hope you didnt fry your amp.
Posted on May 01, 2009
fixerdlt1
  • 18 Answers
SOURCE: kicker zx 1000.1 green light flickers and no sound
The first thing I would suggest is to check all connections to the amp and speakers, especially the ground. A loose ground can cause the problem listed. You can test this by temporarly running a ground from the amp to the battery neg. . If the amp fires up ok then that means your grounding point for the amp should be checked and cleaned and reattached firmly. If you have a meter(multitester) set it to ohms and check the impedances of the voice coils in the woofers. If one is cooked it may be shorted and tripping the amps protection. Always hook thing up with the sys off and then turn on and test.
Posted on Jul 22, 2009
Bennytechkid
  • 99 Answers
SOURCE: MY KICKER ZX 750.1channel amp "FLIP FLOPS" from
Are you getting any sound output at all from amplifier?
Is there a popping or banging coming from speaker?
It could possibly be a faulty output mosfet that is ocillating cause DC to leak onto the speaker output causing it to flip into protect.
please advise
thanks,ben
Posted on Jan 04, 2011
yates_michae
  • 4 Answers
SOURCE: goes into protection mode for no reason
if the amp is powering on the sub and playing and then turns in to protect mode it could be the amp is getting hot and its kicking into protect so you wont fry the amp
Posted on Jan 30, 2012
Kicker kx850.4 protection light stays on know power light
Check power make sure you have solid 12 volts. Disconnect speakers, shorted speaker can cause protection mode to engage. If still in protect mode will need to repair. Kicker does out of warranty repairs on kx series amps or try T.I.P.S contact at linearpower.com. Iirc Ray @ tips was one of the engineers at kicker back when kx series was introduced.
Jul 19, 2016 | Kicker Car Audio & Video
Kicker zx750.1 protection mode
Well, check again for lose wires and make sure it is grounded good and let me know what you find, Make sure you check ALL of the wires.
I will be more than happy to help you when you get back to me on this.
thanks
May 06, 2008 | Kicker 06ZX750.1 Car Audio Amplifier
Model cx600. Why is red protection light on?
The amplifier probably was being overdriven and went into protection mode to prevent the output stage(s) from getting smoked. The amp will have to be opened up to make repairs and get it working again.
Jan 08, 2016 | Kicker Car Audio & Video
Amp powers up red then turns green for a few seconds then shuts off power alltogether
My specker was working fine then the am went to on protection mode and backs power mode but my specker doesnt work but on when my volume is low
Sep 23, 2011 | Kicker (ZX750.1) Car Audio Amplifier
I have a kicker dx 500.1 amp and a kicker cvr12 sub. When I first hooked up worked perfect for a few minuted. Adjusted settings ont the side and it went out. Now When I power on it the protection light...
check the fuse on the power wire (+) not the ground wire .. i had a kicker 1500.1 on 2 l7 15\'s and when the bass would hit hard the fuse would vibrate and cause the amp to go into safe mode.. after re wireing the whole truck i then found out it was the 150amp fuse holder
Aug 07, 2011 | Kicker Car Audio & Video
MY KICKER ZX 750.1channel amp "FLIP FLOPS" from protected mode(red light) to normal (green light) every 2 seconds.
please advise
thanks,ben
Sep 27, 2010 | Kicker (ZX750.1) Car Audio Amplifier
No sound no protection light
u must have a faulty wire...recheck youre instalments....or get a professional to do it for you..
Feb 19, 2010 | Kicker ZX10001 Car Audio Amplifier
Kicker kx 800.4
Generally, if a Kicker amp has the power light lit and the protection light isn't lit, it's working. Are you sure that you have signal feeding the amp?
Are you sure your speakers are OK?
Nov 04, 2008 | Kicker KX800.2 Car Audio Amplifier
Kicker amps not working
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
Jan 10, 2008 | Car Audio & Video
Kicker ZX1500.1 Car Audio Amplifier Logo
Top Kicker Car Audio & Video Experts
Professor_V
Professor_V
Tygh Duval
Tygh Duval
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
